Question about Gateway Essential 400 PC Desktop
Boot failuer and cmos error and not detect by bios
I hv pata harddisk. When I m start my pc he show bootfailuer. when i format my system. they show harddisk not detect. i did many time try format to my pc, bt didnt. I clean my ram nd chek another part of pc .
    President:
  • 1,188 Answers
Turn off your pc and remove all electrical contacts from casing. Remove and clean RAM contacts with paper. Reinsert RAM check pata cables: are the connected correctly and tightly. Also check that if you have one cd rom and pata drive on the same cable then one must be set to master and the other to slave (or if you have two harddisks). This is called jummper configuration. Please reply if you don't understand anything.
Posted on Jul 23, 2009
  • 416 Answers
You might have some jumper setting issue. please read the following link
http://www.wdc.com/en/library/eide/2579-001037.pdf
    Novelist:
  • 148 Answers
reseat your pata hard drive, take out the power cable on your system tower, press and hold the power button for more than 15 seconds and then take out the connections on the hard drive and put them back in and then using cmos setup to default values and now try to start your system and see if your hard drive is detected.
if not
swap the power connector with some other free power connector, and try if this also not work
swap your pata cable with another pata cable and if this also doesn't work
either your hard drive or your motherboard is bad.
If You think my solution was helpfull please do rate me
Regards
Ltoso
WIPRO LAPTOP MEMORY ERROR I have a wipro laptop that was inflacted by viruses.so i need to format it,and to reformat it i need to boot from cd. But when i try to open BIOS it need password that i am...
If you clear the BIOS password is anything help?
You can clear the BIOS password by remove the battery on the motherboard(which used to record date and time), and reset it a few minutes latter. Anything help?
Jan 07, 2011 | Computers & Internet
HP Workstation XW6200 starts to power up and then just stops - will not boot
First open cpu cabinet.
Then Refix your RAM memory .
Reattach ATX power connector from SMPS to motherbord.
Remove pci cards from PCI slot.
Pull cmos cell from motherbord for 10 minutes so all motherbord settings are defaults.
Reattach both connection to harddisk.
Make sure your harddisk is detected in bios.
When you power up the computer press F1 or F2 or "del" key to enter in bios.
Then check harddisk is detected.
Let me know if you need more assistance.
Thanks.
Oct 04, 2009 | HP CTO HP Workstation XW6200 Base...
Es2 300x not boot up
Open your cpu cabinet.
Refix your RAM clean all dust from circuit bord.
Reconnect power cable and ide or sata cable to harddisk.
Reconnect processor fan and processor.
Reconnect power supply from psu to motherbord.
Pull your cmos cell from motherbord for 15 minutes from motherbord so all settings are reset to defaults.
Check in bios your harddisk is detected?
For boot your computer with operating system your harddisk must detect in bios.
Aug 15, 2009 | Computers & Internet
After two years of use, no BIOS beep and nothing on screen.
Open cpu cabinet Reattch all connection to harddisk power cable and sata or Ide cable.
Then Pull cmos cell from motherbord chipset for 10 minutes so all bios settings are defaults.then Power up the computer press "del" or F1 or F2 to ente rin bios then check your harddisk is detected or not.
arddisk must detercted in bios for boot.
Also set first boot device as your harddisk.
then save settings and exit.
I cant get my pc to boot
Aug 03, 2009 | Office Equipment & Supplies
Hello Everyone, I have an old PC windows98 with maxtor 90840D5 hard drive. Sometime back I've removed the hard drive and attched it to the new PC, so as to access the old files.Today when I try reattach...
you need to detect your harddisk in bios setup.
For that when you power up the computer press "del" key to enter in bios.
Then check your harddisk is detected in bios.
If not cxheck power cable and ide or sata cable connected to harddisk.
Reconect both connection to harddisk then check.
Aug 01, 2009 | Maxtor DiamondMax 3400 (90840D5) 8.4 GB...
Hi my acer laptop is giving me a display saying it cannot find the operating system
Either your master boot record got hosed or the entire hard drive has failed. When booting the machine, enter the system BIOS and check to see that your hard drive is recognized. If it is not, you will need to replace it. If it is recognized, you will need to boot from your OS installation CD and try to repair your existing installation. It should automatically be able to detect the problem and fix it without any other kind of manual intervention. If that is not the case, post back here to this thread and I'll offer other suggestions.
Jul 11, 2009 | Computers & Internet
Black Screen with Blinking dash on upper left corner
It sound like you are on the right track. It seem so be a bios conflict. I had a motherboard that if set to boot form usb it would not look for any other device it the usb was not available. Double check your bios setting very carefully. It's easy to miss some something. If you have a "CMOS clear" option in your bios try that next. Can't hurt to start fresh. If that doesn't work let me know and I brainstrorm some more.
Jul 08, 2009 | HP Compaq nc6400 Notebook
Hp laptop and system
OK there could be many reasons behind it
1) If your CD is booting  and the harddisk is not  it means  that maybe your harddisk has moved  form its loacatio  try to place it in its location
2)U might be having a SATA hdd
   if that is the case maybe ur  BIOS settings have changed and you might have to enter the BIOS and  change the settings there.
If u cannot find the settings pls post back I would be happy to  provide the settings
Nov 04, 2008 | Computers & Internet
Hard disk I/O error cannot formate harddisk shows no fixed disks how to solve
Please try to check with your cmos system if it was detected, if not means your harddrive was absolutely damage.
Please rate me solved!
Best regards,
Philip
Nov 16, 2007 | Seagate Barracuda 7200.7 ST380011A 80 GB...
Computers & Internet Logo
90 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
