Question about Hitachi 42V710 42" Rear Projection HDTV
Black line on hitachi projection tv
My 3 year old daughter got ahold of a spray bottle of water and sprayed water on the front of the tv, now there is a 3 inch black line on the bottom. Is this from water or could something else be going on?
  • carleneontiv Jul 23, 2009
    how do u replace the lenses and do i have to have professional or can i do it. Is this expensive??
  • carleneontiv Jul 24, 2009
    the line is still there but not as black u actually can see thru it, is not as noticable. do u think it will go away??
    Scholar:
  • 174 Answers
Sounds like the water has went under the rim and dried there the line will never disapear
Posted on Jul 23, 2009
  • Stu Morris K Jul 24, 2009
    unfortunately yes it can be expesive but if you can contact a good repairer see what they say
  • Stu Morris K Jul 25, 2009
    it may do if its seeming to go away if the water wasnt contaminated you may get luck try having the tv on for a few hours and let the screen warm up and the rest may evaporate
    President:
  • 1,284 Answers
If this is a rear projection TV then the water most likely the water has been sucked up between the lenticular and fresnel lenses of the TV. You most likely will have to replace the lenses as a pair.
  • Don
    Don Jul 24, 2009
    email me the model tvtek(at)msn.com and I can get you the information you will need..
  • Don
    Don Jul 25, 2009
    It will dry up, but it will leave a white film behind as most hard waters do. The lenses are not for just anyone to replace as most Hitachi LCD projection TV's require allot of disaembly to replace the screens (lenses)
Son sprayed cleaner on tv.
I have not a clue what to tell you, but doubt the cleaner is the cause of this. In any case the TV is so old you will not be able to get parts.
Jul 09, 2017 | Televison & Video
Cleaning lenses on projection tv
Have the set unplugged please.
CAN BE DONE FROM REAR--from the front is a bit tricky and dangerous---from rear with rear cover removed locate the three large black lens( hard to miss them) and clean them with a lens cloth or a paper towel with glass cleaner sprayed on it.
Depending on how much dust===should be done one time a year.
Apr 28, 2012 | Hitachi 51F500 51" Rear Projection...
Children sprayed water on 46" lcd TV, and it looks
Oh dear! I would check your household insurance if it was an accident, just in case a replacement is required.
Most items that get wet rarely recover without problems.
The water should not be able to get into the screen as it is a sealed. If the water has not entered the TV, you may get away with wiping the screen with an almost dry cloth that has dilute detergent on it, (washing up liquid and warm water is fine). That will remove the streaks.
Nov 08, 2010 | Hitachi Televison & Video
Daughter sprayed water on samsung lcd 32 inch on the front panel
electric and water are a bad mix as you know my advice to you unplug tv put it in very warm room for about 3/4 days do not plug in hopefully it can be saved.adrian
Feb 15, 2009 | Samsung LTN468W 46 in. LCD Television
Black opaque line or bar
if its is viewable when off then yes its water or oil.between the screens.these screen don't normally come off from the front.
they have to be access from the rear.
could be big job.
only way to tell is to remove the rear cover.
Apr 13, 2008 | Hitachi 51F500 51" Rear Projection...
Tv and gum
get a bottle of canned air, about 10 bucks. hold it upside down, and spray the liquid on the gum(despite what the directions tell you to do). gently pell off from one side of the gum, constantly spraying underneath the gum so it stays frozen. follow up with windex, or a normal LCD screen cleaner. Be careful not to get the liquid on your skin, as it can cause 3rd degree burns, and in worst cases, FROSTBITE. Trust me I know(1 Freshmen + 1 bottle canned air X 1 senior = pain for both parties) What this does, is freeze the sugar molecules in the gum from contracting when it is pulled by freezing them to a near sub zero temperature.
Feb 18, 2008 | Televison & Video
Hitachi 57f710s
Sounds like a video board problem. May also be the convergence board. You might get some freeze spray ( a component cooler that comes in a spray can ) and while the set is on, spray the boards and see if the problem temperarly corrects. This is to isolate the problem. Once the problem is isolated, you can change the bad component. Good Luck
Ed
NC Electronic
Mills, Wyoming
Jan 02, 2008 | Hitachi 57F500 57" Rear Projection...
TV Screen
There should be 2 to 4 screws, depending on the model, to take out on the bottom of the screen assembly, then you lift the entire screen up and pull it out towards you. Good Luck
Aug 15, 2007 | GE 46GW945 46" Rear Projection Television
How to solution from behide my tv screen?
remove the front speaker grille, and then you will see a couple screws along the botton edge of the screen assembly. remove those screws and then grasp the screen assembly and slide it up to disengage the screen assembly retaining clips. Be sure to unplug the wire clip from the control buttons before completetly removing the screen frame.
Apr 09, 2007 | Hitachi 50GX30B 50". Rear Projection...
Hitachi 42V710 42" Rear Projection HDTV Logo
314 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
matt martin
matt martin
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
