Question about Gateway Computers & Internet
''BootMNGR is missing''
Alright. I had disabled the media card and got the screen working again. HOWEVER! Something popped on my LAPTOP'S Screen after the ''Gateway'' logo prompts...
Press Ctrl+Alrt+Del to reset. 8-[<
I don't have any disk included with it the refurbished product bought from TigerDirect. Is there any way to get the boot manager restored again? I don't want to lose any of files now by reformatting it, then finding out installing from Windows CD, will still not get the Boot from working.
  • 1 more comment
  • Kai Schroeder Jul 23, 2009
    Ok. Let's say I can use the PC's Window's Vista to use for my laptop. What to do then?
    BootMNGR is missing
    8-[< I don't have any disk included with it the refurbished product bought from TigerDirect. Though I have the disk for PC DESKTOP.
    Let me be CLEAR ON THIS ONE. IT DOES NOT PROMPT System Recover Options. What I'm trying to say is, it starts with the option of F8 or F10. After that it tells me boot manager is missing. No other options included.
    They are pricey. But that's not the case here when it comes to restoring my laptop. It's been my baby ever since. THANKS SO MUCH!!! :-D
    Novelist:
  • 117 Answers
Mindsynopsis, the bootmgr is a serious issue, it means the hard drive can not boot properly at all. this will lock any further attempts to restore unless you have the ORIGINAL Gateway disks. now here is a solution to get the machine and data back.
First you will need to pick up a usb to sata connector. You can get this off ebay for about 10 bucks or at your local computer place for about 20-30 bucks. pull your hard drive and get your data off by plugging this device to another machine. it will recognize the hard drive from your lappy as an additional drive.
The next thing is that even though you did not purchase the unit directly from the manufacturer you still have access to purchase their restore disks through the website.
http://support.gateway.com/support/srt/allsysteminfo.aspx?cmpid=topnav
there is the link, put in your serial and it will give you support options including purchasing your disks. they are fairly inexpensive and is suggested to order anyway. you will need these for future issues that may arise.
reload your machine with your new disks, and drop your previous data on it.
With the restore disks you can attempt to repair now if you decide and if you have important programs to save. If not a clean start with the restore disks is the best bet to correct whatever issue arose to cause the BootMgr to be corrupt or deleted. But all in all you still have your important data because you backed it up using the USB to Sata Connector
Good Luck!
Ruben
Posted on Jul 23, 2009
  • ruben barrera
    ruben barrera Jul 23, 2009
    Let me know if this helps you out, so we can close this out!
    Thanks!
    Ruben
  • 3,037 Answers
That's too bad you don't have a disc. If only you knew someone with one otherwise try the following
To resolve this issue, use the following methods in the order given. Method 1: Repair the Boot Configuration Data (BCD) store by using the Startup Repair option.
Use the Startup Repair options in the Windows Recovery Environment to repair the BCD store.
  1. Restart the computer. When the Gateway splash screen appears, press the F8 key.
  2. At Advanced Menu Options, use the arrow keys to select Repair Your Computer and then press the ENTER key.
  3. In the System Recovery Options dialog box, select the appropriate keyboard layout and then click Next.
  4. In the System Recovery Options dialog box, select the user account that has Administrator rights, enter the password, and then click OK.
  5. In the System Recovery Options window, click Startup Repair.
  6. Follow any prompts and restart the computer when prompted.
Method 2: Rebuild the BCD store by using the Bootrec.exe tool.
If the previous method does not resolve the issue, you can rebuild the BCD store by using the Bootrec.exe tool in the Windows Recovery Environment.
  2. At the Advanced Menu Options menu, use the arrow keys to select Repair Your Computer, and then press ENTER.
  5. In the System Recovery Options window, click Command Prompt.
  6. Type: Bootrec /RebuildBcd and then press ENTER.
    • If the Bootrec.exe tool runs successfully, it presents an installation path for the Windows directory. To add the entry to the BCD store, type: Yes. A confirmation message appears that indicates the entry was added successfully.
    • If the Bootrec.exe tool cannot locate any missing Windows installations, you must remove the BCD store and re-create it. To do this, type the following commands in the given order, pressing ENTER after each command.
        Bcdedit /export c:\BCD_Backup
        Ren c:\boot\bcd bcd.old
        Bootrec /rebuildbcd
  7. Restart the computer.
Method 3: Rebuild the BCD store manually by using the Bcdedit.exe tool.
If the previous method does not resolve the issue, rebuild the BCD store manually by using the Bcdedit.exe tool in the Windows Recovery Environment.
Note: In steps 8, 9, 10, and 11, be sure to type the brackets as shown. They are required for the command to work properly.
  6. At the command prompt, type: Cd /d c:\Windows\System32, and then press ENTER.
  7. Type: Bcdedit /enum all, and then press ENTER. Note: In the Windows Boot Loader section of the output for this command, note the GUID that is listed for resumeobject. You will use this GUID later.
  8. Type: Bcdedit -create {bootmgr} -d "Description", and then press ENTER. Note: "Description" represents the description for the new entry.
  9. Type Bcdedit -set {bootmgr} device partition=c:, and then press ENTER.
  10. Type: Bcdedit /displayorder {GUID}, and then press ENTER. Note: "GUID" represents the GUID that you obtained in Step 7 of this method.
  11. Type: Bcdedit /default {GUID}, and then press ENTER. Note: "GUID" represents the GUID that you obtained in Step 7 of this method.
  12. Type: Bcdedit /timeout Value, and then press ENTER. Note: "Value" represents the time in seconds before the Windows Boot Manager selects the default entry that you created in Step 12 of this method.
  13. Restart the computer.
Let me know how this turns out.
Benjamin
  • Benjamin Patri
    Benjamin Patri Jul 23, 2009
    Try the above steps I listed and if that doesn't work, then let me know, it should.
It says on the screen ipod is disabled what can I do to get it to work again
It depends, How long does it say its disabled? If it says something like 99999 hours, or some insanely high number like that, then your gonna need to get a new ipod.
Jul 01, 2015 | Apple iPod touch
My comp is an HP laptop with a nvidia 8400m graphics card. It's running windows vista ultimate 32. I was running with the laptop screen "disabled" and using a monitor instead. Connected through HDMI to an...
This is a very common problem with nVidia geforce 8400 and 8600 cards.
Serach google with this "Defective Nvidia geforce card" and you will see lots of user facing same problem in HP, Dell etc..
I too have an Hp laptop with nvidia geforce 8400. I have faced similar problems(screen got divided into 8 parts) in past for 3 times. Every time I have to replace my motherboard at HP service center.... It is caused by overheating of laptop that destroys the nvidia graphic card.
Go to the service Center and ask for a motherboard replacement.
hope this will help.....
Sep 25, 2010 | HP nVidia GeForce 8400 GS, DH PCI Express...
Black screen message BOOTMNGR MISSING
Repair the Operating System of your System Unit.
Nov 22, 2009 | HP Pavilion dv2000t Notebook
Monitor will not display
Your display app controls that, try updating drivers/ software for graphics card on laptop.
Or press the monitor button (usually Fn + something) till it comes right
Aug 08, 2009 | Compaq Presario 705US Notebook
Laptop won't boot
go to your bios set &check sata hard drive is it enable or disable change it to disable
May 01, 2009 | Computers & Internet
Hp dv1000 media card
Remove the media card while booting.
If there is no media in the card reader, press F8 after the laptop beeps during boot and this should give you a Safe Mode boot screen, choose Safe Mode and then your default OS listed. After you get your desktop, restart the laptop.
If when you press F8 you get a boot from what screen, choose your hard drive and then immediately press F8 again to get the Safe Mode boot screen.
You need to either remove the flash media or use Safe Mode and then restart to reset the Boot Ini information script.
Let me know if this works for you or not, as we may need to take another measure.
Regards,
Worldvet
Jan 05, 2009 | HP Pavilion dv1000 Notebook
Monitor problems
You need to change down the res. to a minor mode. i.e. 800x600 low quality. For Windows enter the protected mode - i.e. after POST (bootup) press F8 then enter with your account, or the administrator. Right-click anywhere on the empty desktop and enter "Properties" menu. Turn the screen resolution down in there (i.e. 800x600); also, check whether your current monitor is recognized by model in there. Re-adjust to a suitable working resolution. If all fails, you can also de-install the video card driver in admin protected mode to go back to basics. Of course You need to re-install it again afterwards when in your original Windows.
Jan 28, 2007 | ViewSonic VP191b 19" LCD Monitor
Computers & Internet Logo
57 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
