Hotpoint wd860 code f20 - Washing Machines
  • 15,935 Answers
E20 is an error code for drainage failure.
Check where the appliance drain hose connects to the house drains for a blockage.
If it's onto a spigot under the sink, take them off and check both for a blockage.
If these are ok then it's likely to be a blockage in the pump.
You'll need to drain the water out manually.
Put a shallow dish below the filter and slacken the filter.
Tighten it to stop the flow of water while you empty the dish.
Once empty, take the filter out, clean out the debris and ensure nothing is left jamming the pump.
Before refitting the filter, put the machine on drain or spin and listen at the filter housing to see if you can hear the pump running.
If you do, fit the filter and try the machine again.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 11, 2010
3 Suggested Answers
SOURCE: F7 fault code on Hotpoint WD860
Fault code F7 is a heater relay fault
Posted on Sep 26, 2008
apart4u
  • 213 Answers
SOURCE: Hotpoint WD860
How to fit Washing Machine Drum Paddle Lifter
For all free video help on appliance Repairs visitour Video Tutorials
Here's our video guide to replacing a washingmachine drum lifter.
A broken agitator paddle can cause your clothesto tear. Don't let this happen when replacing one is relatively simple.
The plastic paddles in the drum on the later washing machines (WMA models) often come looseand come off altogether. They can be replaced. call them lifters. You usually insert a smallscrewdriver down one of the holes (it's the 3rd one on ) and gently press downwhile sliding the lifter out.
Washing trainers in a washing machine is reputedto damage the drum lifters and paddles inside the drum, particularly onnon-quality washing machines.
There are few types of drum lifter; drum Paddle lifters
On hotpoint, creda, Ariston ,indersit and someother makes see video
Posted on May 06, 2010
Hotpoint Ultima WD860 Washer Dryer not rinsing properly. Leaves white residue on dark clothes.
quit using powered detergent .we quit many years ago as it does not dissolve properly in our hard water .no problems with liquid .
Oct 16, 2015 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint ultimate wd860
First all all unplug it for 2 mins to clear error code. That error relates to heater or pcb fault. Check the wires on the heater then pcb make sure they are tight. Give the relays a tap on the pcb it could be stuck
Apr 25, 2012 | Hotpoint Washing Machines
Hotpoint wd860 fault code F8 what does this mean
Hello,F8 is simply a component failure and you need to replaced the electronic range control (ERC).
Thanks
May 23, 2010 | Washing Machines
Hotpoint WD860 - Fault Code F-07
F07 indicates heater relay stuck.
You need to check the heater to see if it is faulty, and fit new one if it is.
Please rate my solution.
Thanks.
Jul 10, 2009 | Hotpoint Ultima WF860 Front Load Washer
Hotpint washer will not spin
F 05 IS A PUMPING PROBLEM CHECK IF FILTER IS AT BOTTOM FRONT R H S.CLEAN OUT AFTER EMPTYING.IF NOT AT FRONT IT IS LOCATED AT BACK OF MACHINE IN PANEL AT BOTTOM . THE FILTER IS IN THE BLACK HOSE COMING FROM TUB. ++++ REMOVE PLUG BEFORE DOING ANY OF ABOVE +++++
Mar 23, 2009 | Hotpoint Ultima WF860 Front Load Washer
Flashing f - 05
Error f05 is a problem with the pressure system usually caused by a blockage. These are most commonly found in the pipe which is attached to the bottom of the drum.
Take off the access plate at the back of your machine and you can see it is secured by a large jubilee type clip.
Please be aware that there will be water in this pipe.
Hope this helps & thankyou for using Fixya.
Jan 24, 2009 | Hotpoint Ariston Aquarius WD420 Front Load...
Sep 25, 2008 | Washing Machines
Hotpoint WD860 problem
washer wf860 showing f07 error. why
Mar 04, 2008 | Hotpoint Washing Machines
Washing Machines Logo
165 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
