Question about Dell Office Equipment & Supplies
Paper jam. cleared jam but all lights are
Paper jam. cleared jam but all lights are flashing on the panal. unplugged but didn't help problem. what do you suggest now?
  • 42 Answers
you have to reset the device to make it detect the new status when unplugging didn't work. on resetting, the current status is detected again. this will remedy the situation.
cheers.
Posted on Jul 23, 2009
Paper jammed
Lift up the upper section of the printer (just like you were going to replace an ink cartridge) and look for the smallest torn piece of paper hiding in the gears. Then tip up and gently remove the top (black) paper tray assembly and remove any paper in the tray. Grab a flash light and check the "in" feed area.
Put it all back together and hit "start copy". If noting still clears the jam unplug the printer (power cord) from the wall, wait 30 seconds and plug it back in.
Hopefully that clears the paper Jam message.
If not call HP Support Center @ 1-866-408-5408. They're available 24/7.
Jul 25, 2012 | HP Officejet 6500 AllInOne InkJet Printer
Paper Jam
Hi Matt,
Here's how to:-
  • First turn the printer off and on.This is known to automatically clear paper jams by pushing the stuck paper out.
  • Remove all the papers from the feed trays.
  • Remove the cover from the housing of the printer to gain access into the inside of the printer.
  • Check for the jammed paper inside and gently pull it out.
  • Press on the flashing paper jam button to make the clearing easy.
  • If this doesn't clear the jam,unplug the printer from power and try removing the stuck papers firmly.
  • Plug the printer back and try printing now.
Check out these video tutorials for more on the same.
Hope this helps.Thanks!
Dec 16, 2011 | Lexmark X6650 4-In-One Wireless InkJet...
The orange light keeps flashing and it says there is a paper jam but I cleared the paper jam but the orange flashing light will not go off.
1. there is a sensor at the end of the printer which shows paper jam recovery. the sensor of your printer may be jammed. clear the jam and it will work. 2. if not, there may be a small piece of paper near the sensor of your printer. clear it.
Aug 30, 2011 | HP Deskjet 460c InkJet Printer
My sharp AR-203E photcopier is flashing a number then what appears to be the letter H, it had a paper jam but thats now sorted but it wont do anything!! help
on the control panel press clear button then interrupt button then zero button then interrupt button the display will change, then press 1 then 4 then start button then clear button (or power off) if you are blinking H then 5 it means you have had several jams in the fuser
Jan 07, 2010 | Sharp Office Equipment & Supplies
Error paper jam light still flashing after jammed paper has been removed and all covers are closed
Unpluging the printer for ten to fifteen minutes after removing the paper jam. This will clear all the memory in the printer and the error codes. If the error code still pops up contact the manufactor.
Aug 12, 2009 | Brother HL 2140 Laser Printer
Canon FC 120 Photocopier. Red Paper jam light keeps flashing
hi,clean any sensor & clear any hide misfeed sheet.send me result.
thank you.
May 31, 2009 | Canon PC-160 Black and White Copier
Paper jammed. pulled out. now yellow light flashes. runs, but no print
check the paper path, specially where the paper is being pickup. it might still have a small peice of paper stuck in the path. pull out the paper tray. can check the paper path in the front of the printer.
use a flash light if you can not see inside.
unplug it printer after you finished. wait 10 sec and plug it back in. that will clear the printer of any remaining print job, and rest the printer.
if this solve your problem, please rate the answer.
thank you
Oct 14, 2008 | HP DeskJet 5550 InkJet Printer
Printer won't work
How did you clear the paper jam? I noticed you must do it from the back.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=bpd09363&lc=en&cc=us&dlc=en&product=71896&rule=24789&lang=en
Either the back was not put back on correctly or something may have been damaged while clearing the paper jam. Please power off printer unplug it from wall. Wait 5 min the plug it back in. If heads don't recycle something has been damaged. Are there any lights flashing? Please let me know if this helps if not let me know the steps that you have taken and I will try to help from there.
Jan 08, 2008 | HP DeskJet 5550 InkJet Printer
Canon s520
The number of orange flashes between green flashes indicates the type of error, as outlined below. Check the cause and take the appropriate action. Two flashes: Out of paper, paper jam or paper feed error Replace the paper correctly and press the RESUME/CANCEL button. If paper has jammed in the printer, clear the jam and press the RESUME/CANCEL button. Three flashes: Paper jam If paper has jammed in the printer, clear the jam, replace the paper in the printer correctly and press the RESUME/CANCEL button. Four flashes: Empty ink tank One of the ink tanks is empty. Replace it. If all of the above won't help, unplug the printer from the power cable, wait a while, and plug in. If that didn't fix you, I guess it's time to get in touch with canon, or a repair lab you trust. Good luck
May 16, 2006 | Canon S520 InkJet Photo Printer
71 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
