Question about Kenwood VR-405 Receiver
Kenwood VR-405 Once the volume is turned up to a certain level the system goes into standby
  • M_D_SELF Mar 15, 2009
    once It urn the volume up it goes into stand by and the it just flashes
You have some wire touching or cross.
Posted on Jun 09, 2008
Kenwood vr-405 turns on only momentarily and then shuts off
your receiver has a bad audio output ic.replacing ic will take care of the problem
Apr 10, 2010 | Kenwood VR-405 Receiver
Does kenwood VR-405 play DTS-HD Master
I have the 405 and a Samsung 3600 which has onboard DTS Master/ Dolby True HD. Out of the 6 movies I 've watched, only 2 have given me Dolby Digital. Bottom line: If the movie doesn't have DD, you cant get DD on the 405. I thought just about all blu rays had DD but its not so. Its time for us to upgrade!
Oct 24, 2009 | Kenwood VR-405 Receiver
Kenwood VR-409 surround system clicks off when sound is turned up
Assuming you aren't turning the volume knob past half way before the problem occurs, you most likely have a damaged speaker cable or a bad driver in one of your loudspeakers. (Once your volume knob has reached about half way the amplifier is producing its maximum efficiency.)
Note the position of your volume control when the clipping occurs, then remove one speaker at a time and raise the volume. If you identify a speaker as the culprit, inspect or replace the wire running to it and try it again. If you aren't able to find a bad speaker, the problem is internal and will need to be fixed at a repair shop.
Good Luck,
Apr 30, 2009 | Kenwood VR-409 Receiver
Receiver works with digital signal input jack only.
Are you talking about the 6 channel input with all RCA jacks? Please explain a little better, it is very hard to know how you have it connected without a very good description since I can not put my eyes on it. You may need to check the settings, it may have the rears muted. More information from you will help me to be able to help you.
Dec 27, 2008 | Kenwood VR-405 Receiver
Buzzing in speakers
First, if the buzzing came in gradually, I would suspect the filter caps. If it started suddenly and goes up and down with volume control, I would think it is in signal path - maybe the dsp board.
Apr 23, 2008 | Kenwood VR-405 Receiver
Kenwood VR-405
Hi changeman5 Have you tried to do a full reset on the unit. Disconnect from the wall for 24 hrs. Then try again. If the problem persists, it may have power supply issues, or a DC offset problem shutting it down. If you are game, I could talk you through some more diagnostics...
Apr 01, 2008 | Kenwood VR-405 Receiver
Kenwood VR-405
more info would be nice. If you're using optical, make sure its securely in both the tv and your vr-405 receiver. I have owned the vr-405 since 2000 and i just purchased a sony 32xbr6. HDMI into the TV, optical out to the receiver, it sounds amazing!
Dec 01, 2007 | Kenwood VR-405 Receiver
Kenwood VR 208
It works sometimes, mostly the volume bottem
Nov 26, 2007 | Kenwood VR-506 Receiver
Shuts off
The unit is protecting itself from a high current situation on the output amps. Either you have a bad speaker or an Amp that is getting ready to give up the ghost. Check your speakers with an Ohm-meter for proper readings (ie 4Ohm speaker should read 4 ohms)
Nov 21, 2007 | Kenwood VR-405 Receiver
Kenwood VR-405 Receiver Logo
227 people viewed this question
Top Kenwood Audio Players & Recorders Experts
Don Hart
Are you a Kenwood Audio Player and Recorder Expert? Answer questions, earn points and help others
