Question about Heavy Machinery
Troy bilt chipper will run if I put some gas down the spark plug hole but then after a second of running it stops. Had used c foam in the gas while it sat during the winter.
  • 132 Answers
Carb is clogged there is a little float that is blocking gas from continusly running
Posted on Jul 23, 2009
We have a Troy-Bilt chipper and every time we use it, we have to change the spark plug in order for it to start.
Check the gap on your plug when you put a new one and then check it after you run it normally. If it is smashed check your piston for a contact point where it was hitting the plug.
Check your manual for the correct plug type. They my have put the wrong on in and if you just keep putting in the same plug...
Call troy-bilt they are pretty good about service issues.
Nov 04, 2015 | Troy-Bilt Chipper Shredder 250cc 11.50 TP...
Have a troy bilt model # 47282 hard to start what could it be
is the gas any good?is it newer than 30 days old gas is only good for 30 days in small engines
Apr 24, 2012 | Troy-Bilt Chipper Shredder
I have a troy bilt trimmer...it is getting gas,spark,compression,and i rebuilt the carb.... what else could be the problem
You have all the elements of a running engine. Final items to check:
1. Muffler. Can become clogged with insect homes or carbon deposits. Restricts back pressure and it will not run or will run poorly.
2. Your spark could be insufficient in which your Ignition Module/CDI would need to be replaced.
3. Insure that the 4-screws holding the carburetor holder / lower crankcase are tight and that the gasket is in good condition.
4. Spark plug gap may be too large.
Insure the engine will run by putting about a tsp., of premix down the spark plug hole and pull over. If you are not getting it to run for about 5 seconds, you likely have an electrical problem at the Ignition module/CDI nothing out sufficient spark. This would likely be cost prohibitive to repair.
I'm betting on the muffler...
Sep 27, 2010 | Troy Bilt Tb70ss Gas Trimmer
I PICK UP A 3250 TROY-BILT GEN AND RAN IT 1 FULL TANK OF GAS OK. THAN WE GOT A SECOND STORM FILLED TANK AGAIN LET RUN FOR ABOUT 6 HOURS AND IT STOPRD. WHAN I THAUT IT RAN OUT OF GAS I REFILLED AND TRYED TO...
pull plug and try to pull start if moves than it was vapor locked clean plug and try to start if no movement with plug out than internal engine or pull cord jammed
Mar 03, 2010 | Troy-Bilt® Briggs and Stratton Chipper
How do I clean the fuel line on troy bilt 5hp chipper vac?
unscrew the nut on the bottom of the carburetor and remove the float bowl it must be emptied and cleaned , debree and water gets into the bowl and blocks of fuel flow reinstall the bowl and start, some carbs don't have a float bowl requiring you to remove the gas tank and carb which is a more involved cleaning.
Jul 14, 2009 | Troy Bilt 24b - 060f766 5hp Chipper...
10 hp Troy Built chipper pull start frozen
If a branch was already being chipped when it ran out of gas...you must clear the hopper of any chunks of wood in it. Pull the plug wire and use a metal pry bar to dislodge any pieces of wood. when the flywheel runs free, put the plug wire back on and the choke on. Try it now!!!
Jun 14, 2009 | Troy-Bilt® Briggs and Stratton Chipper
MTD yardman chipper wont start get spark need manual
I am successful too at using the starting fluid in the carb or directly into the clinder. That is how I start my MTD 5.5hp chipper. My problem is I have to hold down the primer bulb to keep it running. If not, the engine will stall.
May 12, 2009 | Troy Bilt Walk Behind...
Troy-Bilt Chipper Shredder won't start
It takes good gas, good spark, and good air for a gasoline engine to run well. The next thing I would do is put a new air filter in it.
Apr 23, 2009 | Troy-Bilt® Briggs and Stratton Chipper
Won't start
check the fuel line it could be pluged up. never leave gas in any thing when you put it up for the winter.
Jan 04, 2009 | Troy Bilt 24b - 060f766 5hp Chipper...
Heavy Machinery Logo
192 people viewed this question
Top Heavy Machinery Experts
Bill Boyd
Daryl Gleaton
Tom Chichester
Are you a Heavy Machinery Expert? Answer questions, earn points and help others
