Question about Garden
Need owners manual
Quantum Briggs and Statton Pressure Washer. Model 12F802 Type 1914-D1 Code 01050356. What size hose and wand does this 4.5 HP 1800PSI 2.0GPM 3600CP use and is the gas mixed. Must be a two-stroke.....I think. Got the unit but nothing else. What do I need?
  • 305 Answers
Hi, have a look on this site...it has just about every owners manual
http://manuals.syntigroep.nl/manuals.htm
Posted on Jul 23, 2009
Engine is blown what size brigsss &statton engine doi need
From what I can tell you have a model #212400 engine. Look for the model and spec numbers on the engine. They are usually either stamped into the top of the rocker cover near the spark plug, or sometimes on the housing that the recoil starter bolts to. You will need the spec number when you order an engine to make sure you get the correct one for that generator. I found all the information at this link which includes owners and parts manuals which may be helpful to you.
http://www.briggsandstratton.com/generators-pressure-washers/support/operators-manuals/?NTT=30242
Jul 19, 2011 | Briggs & Stratton 6200 Watt Electric Start...
I have a Briggs & Stratton Pressure Washer it was just working Fine THEN the water stopped coming out of the wand? Any Suggestion
Remove the tip and pull the wand trigger without the tip in. If water comes out then your tip is clogged. Clean the tip and reinstall. Or try a different tip.
Its also possible that there is a kink in the supply hose to the unit.
Try these first, it should solve the problem about 90% of the time
Jul 02, 2011 | Briggs & Stratton Pressure Washer...
Won't stay running
Pressure washer when you first try to start them that stop underload. We had the same type of problem with 11 hp Honda if you hold the trigger open the motor will be under less load we found by running the motor for about a minute it would work normally. Remember to make sure the water hose is turned on pull the trigger on, until water is coming out of the wand , now try and start the motor but also hold the trigger open, now you will not be building maximum pressure, after about a minute release the trigger and see if it keeps running.
Feb 19, 2011 | Briggs & Stratton 2200 PSI Gas Pressure...
Washer has low pressure. but can see pressure build up in hose. then when squeez triger motor stops.
Hello, W/D here.
Sounds like it may be air locked. Connect the hose to the washer. Connect the wand and hose to the washer. Open the supply water, and hold down the trigger on the spray wand. Be patient, this can take several minutes.
Now crank the washer.
Best regards, --W/D--
Feb 01, 2011 | Briggs & Stratton 2200 PSI Gas Pressure...
How do I winterize a Briggs and Stratton pressure washer
Change engine oil, add fresh stabilized fuel,start and run to circulate new fuel. Use a section of hose and pump som RV antifreeze (the pink stuff) through your pump and hose if you are leaving your hose and wand hooked up.
Hope this helped
Nov 03, 2010 | Briggs Stratton 020273 Elite Series...
Leaking at point of connection between tip and wand
There is a rubber o ring in a groove towards bottom of the snap in connector.This seals around the tip as you insert it. It will never seal without it. The ball bearings you mention are only to hold the tip in place. The sealing goes on down in the coupler
Jul 02, 2010 | Briggs & Stratton Briggs Stratton ORing...
I own a Generac power washer model 01292=1 type 6670CP GPM2.9 PSI 2300 and request the owners manuel for this model Thank You Al Bonfardino albonfardino@yahoo.com
Go to the Briggs and Stratton website and go to their generators then to Generac. You should be able to track down a link to putting in your model number. (4) PDF manuals show for that model. http://www.generac-portables.com/service_support/owner_manuals/owner_manuals.cfm?rd=1
Apr 30, 2010 | Briggs Garden
Ihave a tank mounted carby type Briggs and Statton
it should be right below the link to the choke rod
if not what is the engine number
Mar 07, 2010 | Briggs & Stratton Ignition Kit 2-8 HP...
I have a craftsman 4.5hp quantum xte pressure washer 1800psi/4.5hp/2.0gpm mod 580.761800. I have to start the washer before I turn the water on and just today started with if I let go of the trigger on the...
the pressure relief valve(bypass) is most likely stuck or clogged. take the relief valve off and check for broken or jammed parts..there should be a bypass hose that goes around the pressure valve
Jun 16, 2009 | Briggs & Stratton Garden
10 HP Briggs and Stratton Throttle assembly
www.briggsandstratton.com/maint_repair/manual_and_more/
Then print in model no etc. You should get owners manual as well as parts list.
May 04, 2009 | Garden
Garden Logo
531 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
