Question about Panasonic KX-T7730 Corded Phone
I forgat my CODE to set my Panasonic KX-T7730 how I can resolve this we need to re-program the phone lines.
U forgot the code try an remember somthing that will help u remem the code
Posted on Jul 23, 2009
Panasonic KX-T7730, we have a 824 phone system and cordless handsets (kx-tg1711) we cannot make outgoing calls on these handests but can take incoming calls and can transfer calls. how do we programme
  • Locate the program and auto-store button on your telephone. You will be using these to customize many of the features on your KX-T7730. The program button is used to enter or exit programming.
  • 2
    Program your outgoing line preference, i.e., the line you prefer to seize when you go off hook. Press "Program" "1" "1" "store" for no line. Press "Program" "1" "2" "Store" for an idle outside line. Press "Program" "1" "3" "Outside Line Number" "Store" for an assigned outside line. The outside line number will be a single or double-digit number that is set through your phone system.
  • 3
    Program your incoming line preference, i.e., the line you prefer to answer when you go off hook. Press "Program" "2" "1 "Store" for no line. Press "Program "2" "2" "Store" for ringing line. Press "Program" "3" "Outside Line Number" "Store" for an assigned outside line.
  • 4
    Program your flexible CO buttons. These are the inner row of 12 lighted buttons. Your outside lines need to be programmed to these--you can choose any of these 12 buttons in any order. Press "Program" "CO Button" "0" "Outside Line Number" "Store." The outside line number will be a single or double-digit number that is set through your phone system.
  • 5
    Program any other unused flexible CO buttons for an extension number or any frequently dialed phone number. Press "Program" "CO button" "1" "Extension Number" "Store" or "Program" "CO Button" "2" "9 + Phone Number" "Store". A "9" must be entered at the beginning of a phone number to tell your phone system to seize an outside line before dialing, e.g., "9-1-212-555-1234."
  • 6
    Locate the programmable feature buttons (the row of 12 solid buttons on the right). These buttons are basically one-touch buttons that can be set for extension numbers or phone numbers. Press "Program" "(PF) Button" "Extension Number" "Store" or "Program" "(PF) Button" "9 + Phone Number" "Store." Remember to press "Program" again to exit programming.
  • 7
    Locate your "FWD/DND" button. This button is used for setting "Call Forward" or "Do Not Disturb" on your telephone. To set call forwarding, go "off-hook" either by lifting the receiver or pressing speakerphone. Make sure you go to intercom and not an outside line. To forward all calls, go off-hook, press "FWD/DND" "1" "extension number" (the extension number that you wish to forward all your calls to) "#". After you hear a confirmation tone, place the receiver on-hook. The steps to set call forwarding for busy/no answer are the same as above, except you will press "2" in place of "1". To cancel call forwarding, press "0" in place of "1".
  • 8
    Program "Do Not Disturb," which stops your phone from ringing--any callers will just hear a DND tone. To program, go off-hook, press "Program" "4" "#" on-hook, to set. Press "0" instead of "4" to cancel.
  • 9
    Locate the message button--this works in coordination with your message light at the top right of your telephone. If the light is lit, press "message" to hear a message left to you either by another extension or a voice mail system. The message button can only be programmed as a message or one-touch button. To program as a message, press "Program" "Message" "3" "Store." To program as a one-touch, press "Program" "Message" "1" "Extension Number" or "Program" "Message: "2" "9 + phone number."
  • 10
    Return your KX-T7730 to its default settings by pressing "Program" "#" "*" "Store."
  • Read more: How to Program a Panasonic KX T7730 ' eHow.com http://www.ehow.com/how_7159736_program-panasonic-kx-t7730.html#ixzz1eYPzbevZ
    Nov 23, 2011 | Panasonic KX-T7730 Corded Phone
    How to turn on caller id on Panasonic KX-T7730. How to set outside line on Panasonic KX-T7730 so that a Panasonic cordless phone can call out
    CID is part of the phone system and requires a -93 card and system programming. Panasonic makes different systems that the 7730 phone works on, but it was first delivered with the TA-824 or equivalent system. It also needs to be programmed to tell it how may lines are equipped. Then, when you dial "9" to get an outside line, it will grab the highest WORKING line, instead of just the highest line.
    FInd the model number on the system cabinet and do an internet search for the installation manual of the system.
    Carl
    Sep 01, 2011 | Panasonic KX-T7730 Corded Phone
    Panasonic KX-T7730 Corded Phone programmed speed dial numbers not working. will not dial numbers programmed
    When the system is installed, you need to make sure that only the lines equipped are in the access plan (program 400 in a TA series box). When you go to the intercom on a phone and dial "9" you should get an outside line every time. If that works, system and personal speed dials include that access code as part of the number. eg my test number is 914197845522 9+1+10 digits.
    Carl
    Apr 01, 2011 | Panasonic KX-T7730 Corded Phone
    How to set name and contact number on the telephone set for one touch dialing with right buttons? My set is Panasonic KX-T7730
    It depends on what happens when you dial "9" from the intercom. If it gives you a line, then that's your "access code". If it gives you a line that doesn't exist, then you need to fix your programming.
    From the idle phone, press PROGRAM, one of the right side buttons, and dial 9 and your number and STORE. You can program one or all 12 buttons at once. When you're done, pick up the handset and drop it back down to exit programming.
    That's it.
    Carl
    Feb 13, 2011 | Panasonic KX-T7730 Corded Phone
    I NEED TO STORE NUMBER ON MY PANASONIC KX T7730
    The mechanics of storing a speed dial number on Panasonic phones is the same, even if the phone can be connected to one of 18 different model Key Service Units. It involves pressing PROGRAM a button, an access code, the number, and STORE. In the U.S. our access code to get an outside line is "9". You may be using something different, like '0'.
    The differences are if you can dial "9" on the intercom and get a dial tone, which collumn of buttons you press, and/or whether you want this to be PERSONAL numbers or SYSTEM numbers.
    In a TA-824, lines are accessed high to low. If you have 2 lines on a basic system and dial "9" to get an outside line, you will land on line 3 if you have not told the system that line 3 is disabled (system program 400). So, the fast answer is press PROGRAM, a button on the right side, dial 9+your desired number and STORE. If it's a left side button, dial 29 instead of 9.
    System speed dials requrie access to system program 001.
    If this does not work on your system, please comment back with your actual system model number.
    Carl
    Nov 09, 2009 | Panasonic KX-T7730 Corded Phone
    Resetting the Panasonic KX-T7730
    go to menu .... settings.......rest. factory setting..
    your security code is 0000 or 1234
    try both code one by one.
    when u change the code remember the new code.
    Jul 28, 2009 | Panasonic KX-T7730 Corded Phone
    We want to transfer a call to a phone number (external party). System programming is required. Can you help me? Thanks, Gina
    Panasonic KX t7730 call forwarding function to external party:
    If you are using the Kx-TA624 pbx (TES 824 models) system, program your phone unit (t7730) as follows: lifet handset, press FWD/DND button, press 3, then the outside line access code, then phone number, then #, then return handset.
    If you are using the kx-ta1232 (higher models) of pbx system (usually with 9 or more CO lines cabable, use the following command:
    lift handset, press FWD/DND button, press 6, then the outside line access code, then telehone number, then # then return handset to cradle.
    Jun 11, 2009 | Panasonic KX-T7730 Corded Phone
    Programe my phone KX-T7730
    The phone you have (KX-T7730) requires a phone system to operate. This phone can be installed on a few different Panasonic phone systems. You need a "programming" manual for the phone system to do what you want (not a user guide) so you will first need to determine which system you have. Look for a part number on the system itself, it should start with "KXT" just like the phone.
    Sep 16, 2007 | Panasonic KX-T7731 Corded Phone
    Panasonic KX-T7730 Corded Phone Logo
    236 people viewed this question
    Top Panasonic Lands Phones Experts
    guyvstewart
    Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
