Question about Microwave Ovens
Amana Radarange Microwave/Convection over the stove
We lost the booklet! Need to cook a 10 lb turkey in Amana Radarange
over the stove microwave/convection oven. How do I do this? Where can
I find one? thanks
  • 111 Answers
Re: Amana Radarange Microwave/Convection over the stove
What is the model number of your radarange? it should be found inside the microwave on the rim.
Posted on Nov 21, 2007
Aco1560ac is the model #.It is an araman I need to know how it hangs on wall
Posted on Feb 03, 2008
0 characters
3 Points
Fan is barely running. during cook, fan runs weak and vent fan does not run. tech said maybe a control panel? i can do the work but need a parts and service manual. are these available? does the weak...
probably a defective motor or slipping blade. i'm not sure how old your amana is. if it's the real old chrome metal '70's or early '80's vintage models, the part may not be available anymore.. they were very common to fail.
May 16, 2011 | Amana Radarange Microwave Oven
What temp for turkey done ?
Always use an oven bag is used to promote even cooking.
Microwave on MEDIUM (50% power) for 7 to 9 minutes per pound rotating dish every 15 minutes. Not recommended for turkey over 12 pounds
Use an instant-read thermometer after cooking. Turkey is done when thermometer reads 180 degrees to 185 degrees F for whole turkey or 170 degrees to 175 degrees F for turkey breast. Insert thermometer through **** in oven bag into inner thigh for whole turkey or into thickest part of breast for turkey breast.
For easy slicing, let stand 10 minutes after removing from microwave oven. To open, carefully cut or **** top of oven bag. NOTE Microwave directions were tested in 600 to 700-watt microwaves. Higher or lower wattage ovens may need adjustment in cooking times.
Nov 21, 2010 | Microwave Ovens
Steam gets in the door and how can we clean and prevent?
This is usually due to incomplete venting or impaired air flow.
Assuming your hood vent exhaust fan is running properly, be sure your grease filter is clean (or if you use a charcoal type, it must be replaced when dirty) and be sure the exhaust ductwork and outside flapper are all clear.
I recommend that you always run the hood vent exhaust fan whenever you are cooking on the stovetop, too.
You can find links to helpful exploded view diagrams and part ordering help here. You can get new filters there, too.
I recommend that you bookmark that link to your favorites.
Jan 09, 2010 | Amana Radarange Microwave Oven
Amana OTR Convection Microwave runs 59 seconds and shuts off
This sounds like either a thermistor or a damper switch/motor problem.
Amana's technical support line is 866-426-2621. This is the commercial side but they should be able to get you in touch with the domestic side.
Sep 12, 2009 | Sharp R-1850A Convection/Microwave Oven
We have an older Radarange over-stove microwave oven with touch pad controls. Whenever I boil something without a lid for a longer period, some of the buttons stop working. Usually, they begin working...
Call Amana customer service. Microwave ovens should be able to handle the high humidity you are talking about.
Here's the contact information:
Have your complete model number ready. You can find your model number and serial number on the label located on the upper or lower
front facing of the microwave oven opening, behind the door.
For assistance or service, call 1-800-843-0304.
If you need further assistance, you can write to Amana with any questions or concerns at:
Amana Brand Home Appliances
Customer eXperience Center
553 Benson Road
Benton Harbor, MI 49022-2692
Aug 05, 2009 | Amana Radarange Microwave Oven
Help setting clock on amana radarange microwave made in 1987
press Reset, then enter in the time of day (e.g. 0807 for 8:07 am or pm doesn't matter), then press Clock button twice. hope this helps.
Mar 17, 2009 | Amana Radarange Microwave Oven
We have this old Radarange Amana MICROWAVE from the 70's and dont quite know how to use it.
Normally the dials are the timer for cooking time plus cooking power level dial, for defrost, medium, high, etc.
It may also have a start button to start it cooking. If not, then you place the food inside, shut the door, then rotate the timer dial to however many minutes you want.
If this does not answer your question, maybe you can take a photo of the controller and post it.
We're happy to help and we appreciate your thoughtful rating of our answer.
Jun 04, 2008 | Amana Microwave Ovens
Amama 2.0 Cu ft. Radarange Microwave model# UXA3036BAB
This model does not list Stainless Steel as a feature. Stainless Steel is used in the interior (CAVITY) of a Microwave if it is a Combination Convection/Microwave Oven. The Convection Oven can reach temperatures of 400+ degreesF. This Temperature would MELT the paint off a painted interior.
Stainless Steel can be tested with a Magnet. It will not be attracted or "Stick" to Stainless.
Hope this answers your concerns!
Feb 05, 2008 | Amana ACM2160A Microwave Oven
Cooking in an old convectional microwave
Regardless of the model, the basic procedure should be the same in most Sharp convection models.
You can download several recent models here:,1083,5,00.html
Nov 22, 2007 | Sharp R-1850A Convection/Microwave Oven
Microwave Ovens Logo
515 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Barrett Palumbo
Barrett Palumbo
Are you a Microwave Oven Expert? Answer questions, earn points and help others
