Question about Dell OptiPlex 360 Desktop Computer
How do u un block you tube
I use it for my happy time
  • 202 Answers
Control panel,firewall, look under exceptions, you may have to add it if its not in list. you should be able to follow the instructions from here.you wll need to be looged as adim. to make these changes.
Posted on Jul 23, 2009
    Scholar:
  • 65 Answers
This can be caused by various issues.
-Depending on the Anti Virus application, it could be blocked through there. Some Anti Virus applications can be bypassed by using another Internet browser.
-If this computer is on a Company network, chances are they are blocking it and unless you are a system administrator you will not be able to get past this.
-Your router firewall could be blocking it as well.
Chances are its a built in firewall on your computer or Antivirus preventing you from going to youtube.
When you go to youtube.com. What shows up? What do you see on the screen? What Internet browser are you using?
Things to try:
-Open Anti virus application and make sure youtube is unblocked
-Try another browser like Mozilla Firefox or Google Chrome.
-See if the router is blocking Youtube.
Reverse button not working
What other buttons do you have available? What are you trying to reverse? Just a guess, put try pressing the "Pause" button (to un-pause) or the "Stop" button. Then try reverse again. It could be batteries, or something blocking the path of the infrared beam from the remote. Again, I'm just guessing since we don't know what device you are using. I hope this helps at least some.
Happy 4th! :-)
Jul 03, 2017 | Miscellaneous
Stop water overflowing in frIDGE FREEZWE
-You mean from the bottom of the fridge...? If so, the drain pan or the pan that catch the water must be off from the line. Take a look. If it doesn't sit under the drain tube, fix it (move to under the drain tube). So you won't see water under fridge any more.
-But if it's from the Inside. The drain hole is plug. Check and clean it.
Good Luck
Mai Lor
Dec 04, 2014 | Refrigerators
Blocked Brukit. Had it out a number of times...
Try this remove brewunit and find discharge tube from top shower screen. There will be 2 screws holding tube to brew unit, remove screws slowly and make sure you do not lose ball and spring that is under tube. Clean out that passage way and make sure water flows through, then reassemble and test.
Jul 12, 2011 | Saeco Royal Professional Espresso Machine
I am using Samsung Monte. How do i block a number from sending me messages for a perticular period? How do i un-block it again?
I am using Samsung Monte.How do i block a number from sending me messages for a perticular period?
May 17, 2011 | Samsung S5620 Cell Phone
How do you remove broken oil dipstick from a 1999 ford escort?
The dip stick tube is pressed into the engine block. Put a bolt into the top of the tube so that the body of the bolt goes into the tube and the bolt head rests on the tube (so it does not fall down the tube). Use a wrench (such as a Vise grip) to hold onto the tube at the bolt and gently work it back and forth, being sure not to deform the tube. Remove the tube and old dip stick. Replace the tube by forcing it back into the eng. block. Replace the dip stick - done :)! Some dip stick tubes have a gasket at the engine - others just **** up to a shoulder that is built into the tube. Let me know if this works. Thanks.
Dec 19, 2010 | 1999 Ford Escort
My 02 un-faired bandit wont run on reserve but does on "ON" any ideas
the reserve position on your fuel pet **** is no more than a pick up tube that sets lower in the tank. this makes it easier to block or plug.
Nov 26, 2009 | 2005 Suzuki GSF 650 S Bandit
2002 Sony KP53s75 is it worth repair?
Ok, 5 times is an akb problem, and without red, this tells me one of three things are most likley wrong either the red tube is too weak to produce return current to the akb circuit, or you have a bad driver on the crt board or you have a defective focus block. There are several diagnostics that need to be done to determine which one is the cause, if you are un familure with electronic repair it could be a little hazardus to do, so i don;t recommend it unless you are aware of the issues. If you swap the neck modules with the blue tube, and the set looses blue then it is not the tube. and might be worth repairing. but again if you don't have experience it may not be a good idea for you to try this yourself.
Sep 01, 2009 | Sony KP-53XBR45 53" Rear Projection...
My 2004 Trailblazers AC condensation water is leaking inside on the passenger side instead of draining to outside the vehicle. I assume I have a plugged drain tube? Can anyone assist me in finding this...
if you look on the engine side of the firewall you will see a rubber tube on the passenger side of the vehicle bent at a 90 degree angle that is the drain tube. very carefully try to insert something stiff into tube to see if it is blocked
Jul 15, 2009 | 2004 Chevrolet TrailBlazer
Pressure sensor manifold
There is a thin tube running from the sensor switch down to the pump area, this is the pressure tube. Pull this out carefully after un-clipping from the top, blow thru this, the air shd go thru, or it is blocked. Check for breaks in tube. This tube checks your water level in machine. Refit tube carefully when block if any is cleared.
If you have a similar tube you can fit it above to the sensor switch and blow thru it, you should hear a click when u blow, if you do, your pressure switch is working fine.
Pl rate if helped.................
May 27, 2008 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Full colour
bad tube so sorry have to get new tube
Feb 03, 2008 | Samsung TXG2746 27" TV
Dell OptiPlex 360 Desktop Computer   Logo
355 people viewed this question
Alun Cox
