Question about Mitsubishi PD-5010 50 in. Plasma Television
Horizontal lines what is this ?
My tv pd 5010 have  3 horizontal lines what is this ?
Hi luigi what u are getting this lines because probably u arent supporting the best picture for your tv...set a 1080p on ur screen in order to avoid those lines they would go away once u have Hd on ur tv
Posted on Jul 23, 2009
My 42 in phillips LCD flat seen has a black horizontal line toward the bottom how can I fix this.
Samsung LN46B650 Thin Black Horizontal Lines - Forums - CNET
www.cnet.com > Forums > Samsung
CNETI'm experiencing thin black lines from the top of the screen to the bottom. ... by babes808gpa / January 15, 2010 1:42 AM PST ... lines are about 1/4 inch apart from top to bottom of screen. starts on the right and about a 1/3 of the way toward the ...have the exact same problem, my lcd tv has multiple lines are horizontal it ...
Faulty HD- LCD - LED TV - Horizontal Lines STRIPS on the ...
? 3:05
https://www.youtube.com/watch?v=KiqJuMiEiak
Jun 8, 2013 - Uploaded by Sameh Moustafa
Faulty HD- LCD - LED TV - Horizontal Lines STRIPS on the picture SOLVED .... I just have one black line ...
TV Repair Help for Vertical & Horizontal Lines on Your TV ...
? 2:47
https://www.youtube.com/watch?v=b0sI7LB4cZE
Dec 20, 2015 | Televison & Video
Thin black horizontal lines on JVC PD-42WV74 EDTV
horizontal line is an idication of a bad board known as a x driver board. Their may be a slight possiblitliy it can be a small ribbion cable that runs from the driver board to the plasma panel. Another possiblility it can be a bad panel... but from the symptoms you describe i would first have to look at that driver board. and the sympton that getting worse makes me lean toward a bad ribbion cable.. if that could be reseated....well that the first thing as a technician i would try. Carefull Television generate dangerous voltages.
Jan 03, 2008 | JVC PD-42WV74 42 in. Plasma EDTV
2 days ago, a narrow black horizontal line appeared in the middle of the screen.
CNETJun 11, 2015 - I'm experiencing thin black lines from the top of the screen to the bottom. ... my lcd tv has multiple lines are horizontal it starts from the right and fades too the left, ... Samsung LN55a950 - Horizontal lines on right side - Forums - CNET
Jun 11, 2015
Samsung 52" LCD TV black lines - Forums - CNET - CNET.com
Jun 10, 2015
More results from www.cnet.com
Plasma TV Repair Horizontal Lines - How to Diagnose ...
? 2:49
https://www.youtube.com/watch?v=h4XWCxUsSVU
Sep 2, 2014 - Uploaded by ShopJimmy.com
I have thin horizontal black lines on the top and bottom areas of my TV. .... Hi, I have a 2011 64-inch 3D Samsung PN64D8000 Plasma TV.
how to fix horizontal or vertical lines on lcd tv - YouTube
? 4:52
https://www.youtube.com/watch?v=k2QpYJp6MU8
Apr 12, 2014 - Uploaded by cr4zyw3ld3r
Hi my LG 47ln5700 tv set has thin greyish black horizontal lineson one side of the .... I hope this works good with Samsung LCD as well....
Dec 19, 2015 | Samsung HP-R5072 50 in. Plasma HDTV
Horizontal lines samsung lcd tv, then more horizontal lines, then complete static out, TV restartes itself. after a 5 minutes or so, it seems fine.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Sep 04, 2015 | Samsung Televison & Video
My Ultravision TV is now having horizontal lines. Do not know if it has a horizontal hold button hidden somewhere or is the TV going out? Can I fix it myself. Large screen
Can you try and see if it is your source that has the lines or the actuall TV that has the horizontal lines.
What is your source? Direct TV, Cable TV or even off air Digital TV.
If you remove your source do you still get the horizontal lines? If you do then what colors are they? Seems if when you remove your source input and you still have these H-lines then you have issues with your individual LCD palets. Especially if they are just Green, Red or Blue?
Nov 07, 2014 | Hitachi UltraVision CineForm 55VG825 55"...
Dear Sir, I have the same model, very nice pictures, but lately the pictures sometime it flickers and the are horizontal broken lines. Sometimes it is perfect. Kindly advise- T.Q - DAG
Turn off the plasma TV, wait for 10 minutes then turn it back on. Sometimes during first installation, the television can develop vertical lines. These lines are usually not the television but noise from a secondary device. This action will fix 50% of the plasma TVs out there.
Check secondary devices. Make sure they are disconnected and turned off. Secondary devices can cause noise in your TV, creating these annoying lines. A good example is the lines you see when you turn on your blender. Malfunctioning secondary devices can generate these lines.
Check your cable connections. Make sure that your coaxial and HDMI cables are connected properly. Bad connections can create noise in the television and cause these lines.
Go to your television's support website and download the latest version of the firmware. You can do this by transferring the program to a flash drive then using that flash drive to update your TV. There are corrective measures inside these firmware updates for the most common problems like vertical and horizontal lines. You can then put your flash drive directly into your television's USB port and update your firmware from the television setup menu. Once this is done, the vertical lines should disappear.
If they don't, then it means a display panel is failing. If that's the case, it may be cheaper to replace the whole TV, rather than just replacing the panel
Jun 05, 2014 | JVC PD-42V475 42 in. HD-Ready Plasma...
A horizontal thin black line has appeared across screen.
hi all .ive had the same problem,a thick black line down screen.sometimes it flickers from top to bottom and other permantly in view.but i have solved it.forget your ic boards and taking apart tv.have you got either a ps3 or wii connected to tv.if so unplug power lead from socket and relocate in seperate socket.make sure the lead is completely free of any other leads and you might just find this works.i think the power lead creates some sort of frequency that the tv picks up .good luck hope it works
Jan 27, 2010 | JVC PD-42V475 42 in. HD-Ready Plasma...
PD 150 will record but,during the play back you see several horizontal lines covering the image. What causes it? & How can we repair it? Please help. I used a brand new tape & I have used this...
The problem is of drum assembly which normally called Head of the camera, it needs replacement. When horizontal or vertical lines appears it means the drum start malfunctioning and it needs replacement. For this please see the link click here.
Thanks.
Nov 25, 2009 | Sony Dvcam DSR-PD150 DV Digital Camcorder
JVC PD-42DX6BJ plasma 42 inch black horizontal lines over the pic
Here's a link to order the original the JVC upper Y-buffer board and lower Y-buffer board for this model from a major parts distributor if needed:
JVC "PD-42DX6" Replacement Part Upper Y - Buffer Board (LJ41-02760A)
JVC "PD-42DX6" Replacement Part Lower Y - Buffer Board (LJ41-02761A)
Based on the symptoms: It is possible that the Y-buffers are faulty, which may require the replacement of the Y-sus board as well. You may want to get a local technician to diagnose the unit and provide a second opinion.
Apr 01, 2009 | JVC PD-42DX6 42 in. Plasma Television
SAMSUNG LCD TV horizontal lines
causing of horizontal lines is leaky or defective capacitors. check big value capacitors around the board at Horizontal area. check the filter capacitor as well. good luck
Mar 21, 2008 | Samsung LE26R73BDX 26 in. HD-Ready LCD...
Mitsubishi PD-5010 50 in. Plasma Television Logo
304 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
