Question about Dryers
Aquarius ctd00 tumble dryer works fine for about 10-15 mins but then the drum stops turning and it makes a quiet growling noise. Heats up fine.
  • 3,037 Answers
A possibility is that it sounds like your bearings have gone at the back off your drum behind the small middle panel. Try turning it by hand if it starts scrapping straight away, if it does then you need to replace the bearings. Otherwise you may have a loose belt or a belt that came off and so you need to take the back panel off to check this.
The last possibility is a bad door switch but if the machine still sounds like it wants to run, then either bad bearings or the belt off/broken is probably it. Let me know how this turns out.
Benjamin
Posted on Jul 23, 2009
Hotpoint aquarius ctd00
The noise could be .... the drum sometimes has stick on metal pads for balance or heat shields that will come up and start smacking on the cabinet of the dryer. Remove or lift the top of the dryer and turn the drum and looks for these pads. if one has lifted either glue it back or cut the part off that has lifted.
As far as the not drying part ..... it could be that the dryer is just getting tired and the heating element is gong bad or it could be something as simple as cleaning out the vent going out of the house. You can do this by disconnecting the dryer from the wall and blowing it out with a leaf blower or having someone come in and do it professionally.
Hope this helps.
Nov 25, 2013 | Washing Machines
DLE2050 making strange spinning noise
I guess I wasnt clear enough. The dryer works ok, except for the rattling sound now. It will start when i push the start button, it heats, and dries the clothes. Just noisy where before the flow sensor went off, it was pretty quiet.
Jan 07, 2013 | Dryers
My hotpoint aquarius ctd00 dryer won t spin when turned on but makes noise and heats up
We have made a few videos on these dryers and there are some very good repair guides on these.
How replace the bearing kit
And if you have the type with a fixed Riveted Drum shaft then you will need this video
In our repair guides you will find help on all the tumble dryer problems
How to Repair
Jun 26, 2012 | Hotpoint Aquarius WD63 Front Load...
Hotpoint aquarius ctd00 tumble dryer...everything working but drum wont turn
it looks like you need to put the belt back on which is inside the machine. to do this open the lid with screws on back take lid off then you should see the belt inside the machine and where is was before on the drum of the machine. slip it back on and put lid back on and it should start turning again. hope this helps.
Sep 20, 2010 | Hotpoint Aquarius WMA42 Front Load Washer
My dryer heats up but does not tumble. I replaced
ALWAYS UNPLUG YOUR DRYER BEFORE ATTEMPTING TO DO ANY WORK ON IT.
Sounds like your problem may be the belt may have slipped off of the motor pulley, or idler arm pulley.
Sometimes the belt will slip off of the idler arm or motor causing the drum not to turn.
While you have the drum out, I would recommend that you lubricate the drum rollers at the shaft of the roller with a good grade of machine oil like 3 in One oil. This will save you a problem later with the rollers getting noisy, also check your drum rollers for flat spots, if they have flat spots on them this will cause a noise like a thumping type noise. You will need to replace the drum rollers if they have flat spots on them.
I will include these two websites for parts and further help:
http://www.partselect.com/
http://www.appliancepartspros.com/index.aspx
Both also have chat assistance 24/7.
Good luck,
I hope this helps
Please do not forget to rate me
Thank you
May 10, 2010 | Dryers
CTD00 drum does not turn,heating OK,belt OK,motor OK
you have a bad motor,most likely.
Mar 03, 2010 | Dryers
Hotpoint aquarius ctd00 condensor dryer drum not turning in reverse direction, belt seems to be ok
The reversing tumble action is controllerd by the timer, so it could be contacts in timer.
It is useable running in one direction.
Check for loose or broken wires to motor as well.
Hope this is off some help to you.
Dec 07, 2009 | Hotpoint Dryers
Tumble dryer makes whine noise but doesnt spin
Sounds like the drive belt has gone,and the noise you can hear is the motor going round.
The red glow you can see, will be the heater element glowing..
To check the belt, remove top cover, and you will be able to see if the belt is on or not, if you can see it round the drum, try to lift it up, if it has not broken,then you will not be able to remove it, and that means the motor or drum could be siezed, try to turn the drum by hand, it should be fairly stiff to turn, but not that stiff that you cannot turn it at all.
Please rate my fixya solution.
Thanks.
Feb 01, 2009 | Hotpoint NWXR473EV Dryer
Hotpoint aquarius CTD00 dryer
how many fuses are there in a hotpoint tumble dryer CTD00 aquarius I know one is in the plug is there another one if so where is it?
Aug 18, 2008 | Dryers
Aquarius 1200 wd62 - Dryer not working
Most likely it is some sort of blockage in the vent, although it could be a bad blower. Check the lint filter and vent openings for a blockage.
Jul 27, 2007 | Hotpoint Aquarius WD63 Front Load...
Dryers Logo
18 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
