Question about Maxtor Personal Storage 3200 (U01E200) 200 GB Hard Drive
Maxtor personal storage 3200 problem!!!
I just got the maxtor external hard drive and as soon as i hooked it up it worked fine, the computer recognized the harddrive so i transfered all my files onto the drive, than the next day i turned it on, and noticed that the computer did not show up on "my computer"....
So i thought maybe if i install the software it will show....but after luck
i changed the usb port to see and still the problem reoccured
to make sure i hooked it up on another computer it didn't recognize...
Re: Maxtor personal storage 3200 problem!!!
I will tell you how to solve it, but this will void your warranty!
I had the same problem. What i was intended to open the box take the HD and use it as an internal HD.
When I opened the box I saw the HD jumpers were set on Cable Select I picked the jumper and plugged it to Master. Plugged it back to AC power and USB. It works. I donno why but it just worked.
Good Luck!
Posted on Dec 05, 2007
    Problem Solver:
  • 11 Answers
I had a similar problem with my pc( OS=XP SP2) with the same external drive model. I was able to solve it by downloading and installing WindowsXP-KB908673-x86-ENU Hotfix Package from Microsoft Corporation. I hope it works for you.
from P.I.
Posted on Jul 11, 2008
0 characters
3 Points
Maxtor 3200 was working fine. Suddenly my
Try connecting it to another computer.
If it is not detected, then either the disk-drive "inside" the unit is dead, or the "adapter" (USB-to-Disk-Drive) inside the unit is dead.
If the latter, disassemble the case, remove the disk-drive, and attach it as an "internal" hard-drive to your computer.
Nov 01, 2009 | Maxtor Personal Storage 3200 (U01E200) 200...
My Computer does not recognise the Maxtor 3200 personal storage
hdd problem,, 50% can fix you hdd.. if you have inportant data just make recover.. you can't use that for install program and operating system just only for external, save data but dangeros also maybe someday it wil not work totaly..
try to change the board if could
Jun 16, 2009 | Maxtor Personal Storage 3200 (U01E200) 200...
First, try another USB Cable. If that does not work properly then I would suspect the box or the drive has failed. If you just bought it, return it to the store and complain. They may replace it. As for your data?
Now if you want to become techie you can remove the hard drive from the box and attach it to you computer either copy the files back if you do not have them on your computer or format the drive if you have your files. Then put the drive back in the box and try to get a refund or buy a different external. I like a metal box with an AC cord plug. Best of luck.
Jun 01, 2009 | Maxtor Personal Storage 3200 (U01E200) 200...
Maxtor 3200
Seagate troubleshooting Error Code 10, states that drive has failed. (Seagate bought out Maxtor)
Before you resign yourself to everything is lost on this harddrive, how about trying one more thing?
How about putting the harddrive inside in a new external enclosure, and see if it works? I suggest that perhaps the external enclosure it's in, is bad.
The harddrive inside is a 3.5 inch harddrive. Same width as used by a desktop computer. It is a Sata harddrive.
Here's an example of a 3.5 inch Sata, external enclosure,
Just pop the external enclosure open that holds it now, take it out, and install it into an external enclosure like the example above. Plug in the USB cable.
Don't know if this applies to your particular Maxtor Personal Storage 3200, but when I went to search for the type of harddrive it uses just now, I ran into thsi, and thought I would pass it along.
May 10, 2009 | Maxtor Personal Storage 3200 (U01E200) 200...
Maxtor and vista
Try some other USB device (memory-stick, printer, camera) in the USB slot in the Vista computer, just to "prove" that Vista will recognize _any_ USB device connected to that slot.
May 31, 2008 | Maxtor Personal Storage 3200 (U01E200) 200...
Maxtor storage 3200
right click my computer
select manage
select disk managment
right click on the maxtor drive then select change drive leter to "L" if you like.
Apr 27, 2008 | Maxtor Personal Storage 3200 (U01E200) 200...
Maxtor Personal Storage 3200 (U01E200) 200 GB Hard Drive Logo
1,927 people viewed this question
Top Maxtor Hard Drives Experts
Brian Sullivan
Brian Sullivan
Mark Taylor
Mark Taylor
Are you a Maxtor Hard Drive Expert? Answer questions, earn points and help others
