Question about LG KS360 QWERTY Keyboard Phone BRAND FREE10 TOP UP
Switch off while typing n sms
My phone switch off while typing a sms and I have to switch it back on how can we solve this probleme?
Cannot receive sms
Make sure that the SIM card is correctly inserted into the phone. If it is, try to update the phone's PRL (this can usually be found in the phone's settings).
Jun 24, 2013 | Acer f900 quad band 3g hsdpa wifi gps...
Hi, I am receiving DNS failed in my CORBY GT-S3653 mobile while i m trying to connect internet (i m using idea network).....
first install the settings received from idea (sms SET to 54671) and then switch off the phone and then switch on...
your problem will be solved...
Sep 12, 2011 | Samsung S3650 Corby / S3650 Genio Touch...
Isend sms from my nokia 6760 but it is going to dreft . i checked my center number is coruct but than i have same problem. plz help me for sms sending
if your message center is correct check : 1-free space on phone memory 2-in message setting message type should be in TEXT 3-network selection ==> circuit switch 4-disable reply path
Aug 01, 2011 | Nokia 6760 Cell Phone
WHEN i switch on my mobile j750 whith any sim it automatically sends an sms to another mobile.that sms includes information about IMEI no.
The sms you are referring to, i believe, is the sms which is being sent to your service provider. If it is so, the sms won't get sent every time you switch on the mobile, but it only happens when you have taken out your sim from the phone and insert it back again.
If it is so, then there is nothing to worry. The sms will not do any harm to you or your device. Instead it is a message to the service provider so that you can access their settings and configurations.
Hope this one solved your problem. If you have additional doubts, please come back to us.
Regards
Sunny.
P.S: If the solution is helpful, please accept the solution.
Jan 10, 2011 | Samsung SGH-J750 Cell Phone
How do you text on a black berry 7290
Thanks for giving Fixya the pleasure to solve your problem.
1.In a messages list, click the trackwheel.
2.Click Compose SMS.
3.Click [Use Once].
4.Click SMS
5.Type the SMS-compatible phone number.
6.Click the trackwheel.
7.Click Continue.
8.Type a message.
9.Click the trackwheel.
10.Click Send.
If you have added contacts to the address book, you
can select a contact from the list after you click
Compose SMS.
To send an SMS message quickly from the phone, type
an SMS-compatible phone number. Click the
trackwheel. Click SMS<XXXXXXX>.
Check out the manual from this link.
Rating the solution is highly appreciated if you feel helped.
Good luck and have a nice day
Jun 17, 2010 | RIM BlackBerry 7290
Sms and mic problem on hp6515
From time to time I have both those problems.
SMS problem:
Remove the SIM card. Start the phone without the sim card. Try sending an SMS (still without the Sim card). The SMS will of course fail to be sent.
Now put the Sim card back in , switch on and try again sending SMS - it should now work. Sometimes you will need to repeat the procedure another time for it to work.
I've no idea why this works but it does for me.
Mic problem:
I found this to be a bad connection in the socket for the headset. Plugging and unplugging the headset a few times and perhaps wiggling it around a little has always solved the problem for me - at least until now. I suppose at some time or other the connector will break completely.
Aug 25, 2009 | HP iPAQ hw6515 Pocket PC
I cant open my sms inbox
virus affected. plz restore ur phone
Jul 18, 2009 | Nokia 5800 XpressMusic Smartphone
Can not receive sms until i switch off and o my
hey there
the problem has been solved! I have updated firmware to CDA 162034/39 R3A.
good luck
Mar 09, 2009 | Sony Ericsson W960i Cellular Phone
My sony ericsson p1i cannot send sms...sms send failed
take out your battery, sim and memory stick.. then turn it off for 5 minutes, then turn in on without inserting the memory stick. after that try sending sms again, if it delivered,then try it with memory stick. if u can send sms,then its ok..but if cant then your memory sticks got a problem.my suggestion is to format the memory stick..
Jan 30, 2009 | Sony Ericsson K618i Cellular Phone
Whenever I receive long sms, my phone goes off and say"insert sim" and says sim rejected.The phone hanged, I can restart by switching off the phone.Again within few minutes the same sms come in and phone...
I too have the same problem.
It is easy to solve :)
Its all bcoz of ur phone memory.
If u store more msgs,pic msgs,ring tones It will switch off automatically...
Jus clean up ur mobile by free up memory
Dec 30, 2008 | Nokia 1100
LG KS360 QWERTY Keyboard Phone BRAND FREE10 TOP UP Logo
88 people viewed this question
Top LG Cell Phones Experts
skiffy99
skiffy99
Level 1 Expert
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
