ERROR CODE FOR RISO RP 3700 T04-513 RECOVERY HAS FAILED
4 Suggested Answers
  • 1566 Answers
SOURCE: error code t04-513 on riso
Take off the drum screen and drum body. Inside, you will see these two antennas in the ink bead. Clean out most of the ink and make sure the small antenna has no ink on it. Reassemble.
To take of the drum, all around the two ends of the drum are small machine screws - you have to take the 4 out that hold the piece that clamps down the master, and remove the clamp - then all the screws around the two ends - 2 on each side have slotted holes in the drum body, so just loosen them - you need them to realign the drum body and screen when you put them back on. I kept the screen and body together when i did it. on the bottom is the big roller, covered with ink - if you look between that roller and the center of the drum, you will see the piece with two stiff wires, one short and one long - the short one needs to be cleaned completely of ink.
Posted on Sep 11, 2010
SOURCE: RISO RP 3100EP Risograph T01-520
T04-513
Posted on Jan 25, 2009
jas247
  • 844 Answers
SOURCE: I have accumulated several drums
Welcome to FixYa!
A pump motor failure is more likely in your issue. Sometimes the drum wire harness connector that connects the wire harness to the machine plastic parts (small finger-like) will break / and some of the contact points will no longer make connection.
You can contact ACM Copiers at Phone: (813) 300-9570 for the price of Pump Motor.
Thank you for using FixYa. Have a great day. Jas247
Posted on May 06, 2011
Riso RP3700 gives A17221 error msg
have you checked you master disposal unit if there were any masters jammed in it?
Jan 29, 2014 | Riso RP 3700
Riso RP 3700 T12-305
t12-305 The master compression sensor does not go ON within 6.5 s after the master compression motor operates in the return direction.
kindly try to check your master roll and respool it. the problem could also be because your master cannot be dispose the old master properly. remove the old master and respool your master roll and initiate your machine or turn it of and turn it on again. hope to be of help.
Dec 27, 2013 | Riso RP 3700
System error T01-521
Error type T01 [Main-motor lock]
T01-***
!!System Error!!
Press Reset Key
If Recovery has Failed, Call Service
Reset method Jam reset
Error point Error conditions
520
The main motor limit sensor does not go ON/OFF for more than 16 pulses while
the main motor is operating, even after the elapse of 100 ms.
521
The position-A sensor does not go ON/OFF, between two detections of position-B,
while the main motor is operating.
522
The position-B sensor does not go ON/OFF while the motor is operating, even
when 3033 pulses are received at the Main FG.
524
The clamp unit is not at the home position while the print drum is operating
(Clamp sensor C: OFF, except during master disposal).
536 The drum failed to stop at position A. (over-run)
537 The drum failed to stop at position B. (over-run)
538
The print
Sep 24, 2013 | Riso RP 3700
Riso rp error t98-526
526 Drum set safety switch is ON, but drum connection signal is OFF.
try to remove the drum and re-install it. hope to be of help
Feb 25, 2013 | Riso RP 3700
mon riso RP 3100 ep donne le code to1-521. veuillez me trouver une solution merci
Nov 22, 2012 | Riso RP 3700
T98-526
riso rp error T98-526
Oct 31, 2012 | Riso RP 3700
I need a driver for Riso RP 3700 and I can't find the site where I could get a free version since I lost the disk and the peripherals included in the sale.
Try this link and get back to me.
http://mydownloadhq.com/your-file.asp?PID=3cb89198-4f31-4c33-b686-576ae7cc197c&q=service+manual+riso+rp+3700+megaupload
Jan 03, 2011 | Computers & Internet
On riso pr 3700 can not get the full image on landscape mode when I make a master
Maybe you meant model RP3700 ...
These questions may help to find a solution or at least a better understanding of your problem:
Have you set the paper size right?
Is the print drum capable of the desired imaging size?
Mar 31, 2010 | Riso RZ390 Duplicator
ERROR CODE T04-513 FOR RISO RP 3790
riso rp 3790 no imprime, no copia, me dijeron que borrara errores pero no se donde, creen que sea eso
Feb 27, 2010 | Riso Office Equipment & Supplies
621 people viewed this question
k24674
