Question about Kitchen Ranges
Amana Range-Easy touch control 500 burners work nothing out of rest of buttons,had CAL on it this morning turned off breaker and now nothing buttons won't make any sounds now
  • 210 Answers
SOURCE: LG Kitchen Series Electric Range Smooth touch controls POSESSED!
The is a tough one if there is no tech there. I have not heard of this problem as yet. There could be a loose connection in one of the ribbon cables or it could just be a defective board.
You can try putting it in to test mode to see if it can self diagnose itself.
Press 'favourite' and 'settings' at the same time, 'diagnois' will appear, press them again and the prompts will appear. Note make sure the top surface is clear as well as the oven. If an error pops up at least you will know what is wrong with it. There is also a tech sheet on the back with the fault codes.
side note, do not put alluminium foil on the bottom of the oven cavity.
Sgt 48
Posted on Jun 01, 2008
SOURCE: Amana Gas- Easy touch 500
To cancel Sabbath mode:
1. Press the clock pad for 5 seconds
OR
2. After 72 hours, the Sabbath mode will end.
* SAb will flash for 5 seconds
* The time of day will return to the display
Hope this helps, I took it straightt from my owners manaul :)
Posted on Dec 06, 2008
jyackle5
  • 8197 Answers
SOURCE: kenmore range control panel not working
sounds like the control board blew on you replace it.
Posted on Dec 16, 2008
  • 9 Answers
SOURCE: After a power outage, my Amana Gas easy touch
Has it ever worked since the power outage? Have you tried unplugging it for about an hour and then plugging it back in. Sometimes that can reset the control board and solve your problem. I alway like to try the simplest things first.
Posted on May 17, 2009
shinn8
  • 85 Answers
SOURCE: We have a Maytag Gas Range, Precision Touch
Likely your oven igniter is bad. Part number 74007498
Posted on May 18, 2009
GE Stove tope range not working
If the phenomenon is intermittent, and you get it going and coming as you restart the oven, then it is likely a bad wiring or a bad connection.
Ensure first that the circuit breaker is ok and well in place, then proceed testing wirings.
Check connectors to buners, hobs, and controls panel.
If all wirings and connections are OK, the what reamins is a faulty control panel or a fault on some of the knob controls.
Sep 04, 2008 | Kitchen Ranges
On my Electrolux wave touch range, the burner buttons remain lighted, won't go onto sleep mode and when touched will not cause a burner to begin heating. It's as thought they are all stuck in the ligh
Hello friend, thank you for your post!
I understand that your Electrolux range burner buttons are remaining on. I have identified a few possibilities as faulty burner buttons, bad switches, or a disruption inside the control panel. Let's perform a reset on your range which can be done by flipping the household circuit breaker off for ten minutes. If that does not help correct the issue I would suggest consulting with a professional for proper repair. Hopefully this helps. -Matt
Oct 11, 2014 | Electrolux EW30MO55HS | 30" Built-In Drop...
I have an amana gas range easy touch control 500. the oven will not light every thing else is working fine
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or
Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Jan 19, 2011 | Amana Ovens
The on indicator light stay on all the time on Maytag touch 500
you have a bad switch, you need to unplug the wire going to the conector marked P on one switch at a time til you find witch switch is bad. if you have turned off the breaker to it and the light is still on then the power is not off to it there is not a batery in it, careful that glass breaks easy when out of it's can
Dec 25, 2009 | Maytag MEC5430BDS Electric Cooktop
Electric oven and stovetop do not work, clock and oven light do.
Sounds like you are only getting 120 volts instead of 240 volts. Either a house electical problem or wiring in range. First go to your breaker and turn it off and on three times and give it a little extra push each time you flip it. ( You can actually flip a breaker off and on without resetting a blown breaker if you doni't push it all the way off and all the way on. If the breaker throws itself off do not reset it. You have an elecrical short in your house or range. If resetting the breaker does not work then you need to test for 240 volts coming into the range. We don't recommend you do any electical testing unless you know what you are doing with electicity. If you have 240 volts going to the range then unplug your range and remove the backing panel off the back of the range. Look for burned wiring or terminal blocks. If there is nothing obvious then you need to know how to read a wiring schematic and use a electical tester to go any farther. Let me know if this helps. Good Luck, Appliance Specialists
Dec 15, 2009 | Amana AER5715QAS Electric Kitchen Range
Range/oven breaker won't reset
it may be a wire fried or came loose, and is touching metal. if an exposed wire is touching metal, you wont be able to reset the breaker. pull the range out, and remove the back, and if necessary, lift the top and check the wires to the burners also. it should be easy to spot the wire that's causing the problem from there. let me know if you have further questions, shane
Sep 13, 2009 | Kitchen Ranges
Electronic touch pad not working on my oven
Hello beachlady80,
Welcome
You said, It was working fine last night but when you woke up this morning the display has 3 vertical lines and none of the electronic touch pads work. The burners on top of the stove still work.
What is the model number and how old is the range ?
Try turning the breaker off for 10 minutes and then on again after this allotted time.
This may reset the system.
Let me know how it works.
Waiting for your answer.
Huuum
Please remember to leave a rating.
Hopefully it will be a solved!
Let me know
Oct 16, 2008 | Maytag MGR6772 Gemini Gas Kitchen Range
No heat at burners or oven
check your fuse / breaker box make sure you have power (sounds like you dropped a leg of power) make sure breakers/fuse is on/good flip it to off the to on if oven don't work then take a look at the cord to the range check power at the wall then open where cord goes into range check power or you may even find the cord burnt in there if so replace all damaged wires good luck
Dec 21, 2007 | GE JBP82 Electric Kitchen Range
Stove/oven gets hot then shuts off
Shut the breaker off! These are the exact symptoms that a tenant of ours reported for their range. I went to check the range and found that one of the power wires on the terminal block in the back of the range was burning itself up. It had actually started a small wire fire. You need to pull the range out of it's hole and unplug it. Remove the panel in the back above where the cable goes into the range. Examine the power wires and terminal block carefully, because I bet you'll find one of the wires is burning up and needs to be repaired. Please write back and let know what you find.
Aug 09, 2007 | Frigidaire FES367 Electric Kitchen Range
Kitchen Ranges Logo
238 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
paulcarew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
