Question about Tally Serial Matrix T2155 Printer
PRINTER SPEED JUST WONDERING IF ANYONE KNOWS THE EXACT CPS SPEED FOR THE T2155. OURS OF 12 YEARS HAS JUST BROKEN - LOOKING FOR A SIMILAR ONE AND NOT QUITE SURE OF THE SPEED. THANKS.
    Novelist:
  • 169 Answers
The print speed of the T2155 when printing at 10CPI is 550 Charaters Per Second.
The direct repalcement for the T2155 would be the 2265Plus available from Dascom, for details see;
http://www.dascom.co.uk
Posted on Nov 07, 2009
Print quality - what is hsd, nlq, utl, ssd mean on the printer
Hi Teresa,
These are just print quality settings
Super Speed Draft (SSD) - 435 cps. High Speed Draft (HSD) - 390 cps. Utility ( UTL) - 300 cps. Near Letter Quality (NLQ) - 75 cps
Hope this helps!
Please don't forget to rate
Jan 21, 2011 | OKI MICROLINE 320 Turbo Matrix Printer
Printer TALLY T2155 error +0257 113----- 000032+0375+0268
This is a motor function select error.
It means the printer can not select the paper input, or does not detect it has selected it.
usualy the problem is caused by the dirt on the sensor located beneath the function select gear or on the function select gear itself (the gear assembly directly driving the paper feed tractor).
if you power off and on again it may work again, but the problem will come back again if the sensor and disc are not cleaned.
Dec 25, 2010 | Tally Serial Matrix T2155 Printer
Setting the cps
crank positioner is fixed ,but had a similar problem with a rover 45 ,put another engine in and done the same thing,the flywheel shapes on the inside of the flywheel engine side were different ,just slightly ,changed flywheel and away it run like a dream .the shapes i mean were the bits that sense the pick up sensor
Dec 15, 2009 | 2002 Jeep Grand Cherokee
Broken release button for back window
Hi:
You might want to check with a Chevrolet Dealer, because about 10 years ago, we had a similar problem with ours, and it was caused by a wire chaffing problem under the dash, feed thru area. Supposedly a Service Bulletin was written, and ours got fixed under warranty
Oct 26, 2009 | 1997 Chevrolet Suburban
BOOT displayed on LCD display
The 'Boot' message indicates the printer has switched to the firmware download mode as it has not been able to load the firmware.
This can happen because the firmware has become corrupt, in this case you can reload the firmware and the printer will be back working.
This problem can also be seen if flash memory has become damaged, this will not be recovered by reloading the firmware, the logic board will need to be replaced i you are unable to rectify the problem by reloading the firmware.
The firmware for the T2155 can be found on the Dascom website at;
http://www.dascom.co.uk/firmware/serial-matrix/188-t2155.html
Oct 08, 2009 | Tally Serial Matrix T2155 Printer
I need to see about getting the manual for this.please help if anyone knows how to get it.
If you are looking for a user's manual, go to retrevo.com. Enter the model number in the search box. They have tens of thousands of manuals. If, by some slim chance they don't have your exact one, there should be enough similar models to help you. The manuals are in .pdf format(Adobe Acrobat reader)--Hope I helped you!--Rick
Oct 02, 2009 | Samsung Video Cameras
87 bronco 302 auto speedometer
I used a couple broken off tooth picks shoved in and they worked for years
Jan 05, 2009 | 1987 Ford Bronco
Tally t2155 - Showing "Hardware alarm wrong board"
change the logic board. your problem will solve.
Jul 29, 2008 | Tally Serial Matrix T2155 Printer
Tally Serial Matrix T2155 Printer Logo
47 people viewed this question
Top Tally Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Tony
Are you a Tally Office Equipment and Supply Expert? Answer questions, earn points and help others
