C
Christopher Jones Posted on Mar 11, 2017
I recently purchased a trust bluetooth speaker system which is faulty and need to return it
How can a Bluetooth mic be connected to speakers?
Connecting a Bluetooth microphone to a speaker system can be a useful way to amplify your voice without the need for messy wires or a complicated setup. Here are the steps to follow to connect a Bluetooth microphone to speakers:
  1. Make sure your Bluetooth microphone and speaker system are turned on and in pairing mode. Consult the instruction manual for each device to find out how to enable pairing mode.
  2. On your phone or other Bluetooth-enabled device, turn on Bluetooth and search for available devices. Make sure your microphone and speaker system appear on the list of available devices.
  3. Once you've found the microphone and speaker system, select them to pair them together. You may be prompted to enter a passcode or PIN number to complete the pairing process.
  4. Once the devices are paired, make sure that the Bluetooth microphone is set as the default input device on your device's settings. This will ensure that the microphone's signal is transmitted to the speaker system.
  5. Test your setup by speaking into the microphone and checking that your voice is being amplified through the speaker system.
It's important to note that not all Bluetooth speakers are compatible with Bluetooth microphones. Before purchasing a Bluetooth microphone and speaker system, check the manufacturer's specifications to ensure that they are compatible with each other.
KDM is a brand that offers a range of Bluetooth speakers, microphones, and other audio equipment. Whether you're looking to amplify your voice for a presentation or simply want to stream music from your phone, KDM has a variety of products to suit your needs.
Usb soundbar speakers
If you have a stereo system that is in the higher bracket area then just connect your TV to the TV input jacks on the back of your amp. Or use the "Phono" input jacks. Nobody listens to vinyl anymore anyway.
I have a 15 inch powered Technical Pro speaker with a damaged audio board from applying too much eat trying to remove a bad transistor where can I get a replacement audio board
Shop for 15 inch powered Technic... on Google
Eminence Kappa Pro 15...
$154.99
Google Trusted StoreMusicians...
(5) Eminence Kappalite 301...
$209.99
Google Trusted StoreMusicians... Eminence Kilomax Pro P...
$239.99
(3) Eminence Kappa Pro?15...
$169.99
(3) Technical Pro zxp18 18 in. 4...
$151.88
Jet.com Search Results
    I have a 15 inch powered Technical Pro speaker with ... - Fixya
    www.fixya.com/.../t26013584-15_inch_powered_technical_pro_speaker
    1 hour ago - I have a 15 inch powered Technical Pro speaker with a damaged ... to remove a bad transistor where can I get a replacement audio board.
    Technical Pro Speakers ' eBay
    www.ebay.com/bhp/technical-pro-speakers
    eBayFind great deals on eBay for Technical Pro Speakers in Speakers and ... Package: (2) Rockville RSG12.4 Single 12" Three-Way, 4-Ohm Pro Audio ... Pro STAGE-212XU 3,000 watts Powered Speaker + 8 channel Mixer System + ... Technical ProPSHAKE1500 Two Way 15" Active 1500W Speaker Bluetooth and USB / SD.
    SA-15T - Seismic Audio Speakers
Hi, I recently purchased a Samsung - 1000W 5.1-Ch. Blu-ray Home Theater System: Model: HT-C5500XAA and was wondering what I need to make the rear speakers "wireless?" I understand a module is...
HT-C5500XAA / HT-C7530W This system comes with wireless speakers... Maybe return this system and get the one with wireless included.... Retails for $999.95
www.samsung.com/us/video/home-theater/HT-C5500/XAA - Cached
Also try out this website....It is quite handy.... Cheers...Sincerely HDTV GURU JAY
The insignia cd/dvd ipod dock player was missing the speaker wire so i bought different speaker wire to connect it but it's not producing sound.what is the problem? is it the wire?
If your purchase was recent, I recommend contacting Insignia Product Support at 1-877-467-4289 to supply the missing part. If the problem persists using OEM parts, I would recommend returning the unit for an exchange if you're within the retailer's return period, or carrying it in to pursue service options.
1helpful
2answers
Recently purchased Sony 52 Bravia KDL52EX1
OK so its software problem? But how did you solve it?! Thansk!!
No surround sound
Since it is new and just purchased, you really should return it for a new one. If you have connected all the speakers right, which you have since the test tone plays in all of them, there is a problem with the receiver. Don't wait too long or they may insist that yu take it for repair. You usually only have a short ime after the purchase to get an exchange. Some are 7 days and others are as much as 30 days. But it does need to be repaired, it is not the way you set it up.
Midiland ir-hf1 right speaker broken
Hi evtan
The only thing I can suggest you do is to swap the right and left inputs to the transmitter base over whilst wearing the headphones. If the fault transfers to the other channel, then you have a faulty interconnect lead that needs to be replaced. If it stays with the same channel, then the headphones or the base staion will be faulty. Best bet then is to return it to the place you purchased it from and request a replacement unit,. Thanks for using FixYa....a FixYa rating is a great reward from you to me for helping out :) Cheers
regards
robotek
Top Trust Audio Players & Recorders Experts
 Grubhead
Grubhead
SmartAviator
SmartAviator
Are you a Trust Audio Player and Recorder Expert? Answer questions, earn points and help others
