Question about GE GTS16KBM Top Freezer Refrigerator
Snapping sound from back of fridge even though i do not have make
Periodic lound snapping sound from back of fridge thanks for help
  • 11,896 Answers
Could be water from the evaporator tray spilling a little on hot condensor, or a relay clicking
Posted on Jul 23, 2009
I have a 6 y.o. whirlpool fridge wbm 46 model that's started to make a loud buzzing/whirring noise every 15 minutes or so ( only lasts a few seconds each time). It's started doing that noise in the last...
Hi
The sound from your refrigerator can be caused due to various reasons,please check this link bellow to troubleshoot your problem:-
http://www.repairclinic.com/Refrigerator-Troubleshooting?red=Refrigerator-Repair-Help#itsnoisy
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Apr 02, 2011 | Whirlpool Refrigerators
Hello i have an lg refrigerator GR-620RW which
LG 620 RW water in fridge below crisper problem.
The issue is most likely a blocked condensate drain line at the back of the freezer. The purpose of the drain line is to take away the water from the end of the defrost cycle.
Task time, approx 2 hours.
Unplug fridge.
Empty out the fridge, let warm up & remove the back panel of the freezer. There is a 3" x 4" snap in door at the upper left corner of the back panel with a round snap in cover. Remove the snap in cover & remove the screw to take out the 3" X 4" panel, gently pull out the back panel from left to right. There is also an elect connector to the fan on the upper right corner, unclip this. The drain is at the back in the centre, it will likley be blocked with 2 or 3" of ice. You can let it melt or sparingly use a hair dryer on it, do not over heat or damage the coil/fin assembly. The fridge will continue to drip water for a day after the drain is cleared if the water has rin inside of it for any period of time.
There is also a fan/control assembly in the refrigerator section held up by 2 screws & snaps. This should be dropped down to ensure there is not ice buildup in the vents to the freezer or water inside it.
Finally, make sure you run warm water down the freezer drain tube to the pan underneath the fridge, this is accessible by taking of the rear compresser cover behine the frigde. Ensure the lower drain line is clear & back on the locater peg.
Of course if you want to do this the easy, & have the time, leave the fridge open, unplugged for 2-3 days & the ice will all melt.
Good Luck
Jun 12, 2010 | Refrigerators
GE profile refrigerator line freezes, fan blows but no cold air?
OK, I think I understand. Thing is we need to do a few things to see if your control board is the problem or if the fan or a freon leak is the answer. You need to tell me if this began suddenly or if over a period of time. I have been having trouble lately from Fixya if the customer (YOU) responds to my solutions. Let me know if you want my help and I will see if I get a email letting me know of your response, Thanks, Sea Breeze
Jul 12, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Frost free fridge freezing up
there used to be a schematic behind the front grill that you pull off to clean condenser try there. every appliance used to have a wiring diagram. . now your problem ; it sounds to me that a baffle between freezer and fridge is being hit or the knob next to the thermostat is being set for colder temperatures in refrigerator section. also if the fridge side gets close to empty that could cause items in fridge to ice up.
Jan 29, 2009 | Refrigerators
Sound messing up on TV
well this may not be that helpful, but if you decide to give up, you can always run the sound through your surround system or plain old stereo, and there are many ways of doing this
Oct 08, 2008 | RCA P52926 52" Rear Projection Television
Servis Fridge not cold enough
Hi ruthcart1,
I'm Harvey the Master Plumber.
Your problem is: You have a free standing fridge freezer from Servis (silver) and the fridge doesn't seem to be as cold as it should be. The freezer is absolutely fine just the fridge even though you have adjusted the thermometer inside.YouI've had it maybe 3/4 years.
You're still under warranty. Modification now voids the warranty. I would call warranty repair. This should be their headache not yours.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Sep 10, 2008 | Refrigerators
Inside Dsiplay Not Always on
Hi -
I haven't solved my problem, yet, but i have determined that it's beyond my scope and will require a pro's visit to my house.
thanks for the line.
b
Aug 17, 2008 | GE Profile PFS22 33" Artica French Door...
Fridge makes howling noise
Hi there!
Check at the back for any objects or packets that are in contact with a fan. This often causes unusual noises.
See if you can identify the source of the noise, ao I can help further.
Thanks.
Jun 21, 2008 | GE GSS25JFPCC / GSS25JFPWW Side by Side...
Fridge making loud snapping noises
we have much the same problem except ours was going on for some hours at a time and then off for short periods. contacted Comet engineer who says its the compressor and will cost almost as much as a new machine to fix it. we are disgusted as its only just over a year old and has been repaired twice already. we would also add that both
the fridge and freezer are now completely out of action and have been all over the Easter period which has caused us much inconvenience. we will take this matter further if no satisfaction is gained from Comet.
Feb 28, 2008 | Admiral 26 cu. ft. Side-By-Side...
GE GTS16KBM Top Freezer Refrigerator Logo
81 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Ilia Bichin
