Question about Pride Victory 4 Wheel Mid-Size Electric Scooter
When I switch my mobility scooter on lights etc all work but no drive
The batteries are fully charged.While i'm driving the scooter starts slowing.I have replaced the batteries & they are fine. Can anyone help with this problem?
Posted on Nov 09, 2009
  • Pride Master
  • 1,271 Answers
Hi, I first suggust you make sure that Freewheel is disengaged,
to test this try to push the scooter forward if it moves forward move the lever ,
Check the Wigwam or throttle controls to make sure they are not loose,
Check for reset switches under the seat or on the steering stem,
Check for car type fuses under the seat.
Posted on Jul 26, 2009
Mobility scooter lights wont turn off
It really can only be one thing. Somewhere on your scooter is a switch for the lights. Try turning it off. If that doesn't work the switch is faulty
Nov 01, 2016 | Invacare Health & Beauty
Status button flashes 5 times. Scooter is fully powered but will not move. Brake is off, lights work, etc.
BEFORE U RING TRY THIS TAKE KEY OUT PUT FREE WHEEL LEVER IN FREE WHEEL THEN PUT IT IN DRIVE PUT KEY IN & TRY OT. Hi again get in touch with pride www.pridemobility.com or ring them 1-800-800-8586. They might B ABLE to help cheers if the electronics r the same as celebrity put freewheel lever in drive & remove key then :::: put it back & try it out good luck
Apr 18, 2016 | Pride Revo 3 Wheel Scooter
The red light flashes 5 times scooter will not move
I would look at the freewheel lever. Disengage and then engage the freewheel and see if this corrects the problem. If not, you may have a bad freewheel switch.
Apr 10, 2014 | Drive Medical Phoenix 3 Wheel Compact...
Won't move when drive leaver pushed
go to my group page on facebook wac mobility scooter and i will message you.many thanks billy
Mar 19, 2013 | Pride Victory 4 Wheel Mid-Size Electric...
Scooter won't move
Things to check: Drive/Free wheeling switch, brake release lever (this activates an internal micro-switch that enable power to the drive system, battery box connectors (condition of contacts - corroded, missing, loose. etc.); main control cable (corrosion. lose or missing pins, etc). If all these are OK, could be controller or drive control potentiometers (speed, forward, backward) on the handle-bar (tiller).
Aug 09, 2012 | Electric Mobility Merits Electric...
Days Strider Midi 4 Plus faults
HOW DO GET THE REAR WHEEL OFF MY SCOOTER NUT VERY TIGHT
Jul 10, 2012 | Electric Mobility Mobility Electric Power...
Problems with my evolution 8 mobility scooter
i have never personally worked on a mobility scooter myself but i do know that my grandfathers had the same problem and his gear sprocket had worn down so when he was on flat ground it was fine but when he would go up inclines and it needed more power it would just spin and barely make it but this was also ten years ago so idk if there even close to anything the same anymore
Jun 12, 2012 | Health & Beauty
Why does my scooter drives for 10 to 15 feet then kicks the reset switch
Hello John.CIRCUIT BREAKER TRIPS FREQUENTLY.Possible Cause:Overload caused by exessive demand on motors (low tire pressure,sticky brake,seized wheel bearings etc).
Heavy load on steep incline.
Loose batteries terminal connections.
I hope this will help you get mobile again,have a nice day.
Oct 30, 2011 | Health & Beauty
My Lynx L4 4-Wheel scooter green light flashing but it said it is charge it wont go forward
the green flashing light indicates an error with the scooter. Count the number of flashes 4 flashes pause 4 flashes pause etc and your manual should give you the meaning of the flashes Check to make sure that you are not in freewheel move the lever at the back of the scooter up and down a few times and make sure you leave it in drive mode turn on the power and see if the light stops flashing and the scooter will operate correctly Hope this helps
Oct 03, 2010 | Activeforever Lynx L4 Portable Mobility 4...
1700 Fortress Scooter won't go forward or backwards. The beeping is continual and the driving light comes on if you turn it on. The brake is in brake release mode. The battery is charged up? What is the...
Hi. Has the machine been in regular use before the fault occured? You say that the brake is in brake release mode, this mode is only ever used if you need to push the scooter by hand. It releases the brake on the motor, and also operates a switch to disable the controller from driving the motor. It does this because it would be to dangerous to drive the scooter with the brake disabled.
Move the lever back to its correct position. If it still does not work, then the disable switch might be faulty, or it might be a different fault such as a stuck brush in the motor.
Is this machine produced by shoprider ( Phisang ) of Taiwan.
Please let me know how you get on. Neil.
Jun 07, 2010 | Electric Strider Maxi 4 Wheel Mobility...
Pride Victory 4 Wheel Mid-Size Electric Scooter  Logo
513 people viewed this question
Top Pride Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Colin Taylor
Are you a Pride Health and Beauty Expert? Answer questions, earn points and help others
