Question about HP PSC 1210 All-In-One InkJet Printer
Won't pull paper through
The printer makes the sound like it is going to pull the paper through to print on it, but never actually grabs the paper and prints on it.
    Problem Solver:
  • 6 Answers
In this case you have to clean the rollers of the printer.
Follow the link to get the steps how to clean the rollers:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=buu00697&cc=us&lc=en&dlc=en&product=90764
Posted on Aug 03, 2009
Won't print, says pull out paper tray and load paper
did you push the paper tray back in as far as it will go
Nov 21, 2015 | Office Equipment & Supplies
My CanonPC940 won't grab paper and push it through to print-also makes a a loud "grinding" noise. How can I fix this?
Sounds like a tire may have slid off of a wheel. Yes they have wheels. Also paper soaks up water like a sponge always keep your paper in the wrapper it comes in and the top side of the paper is where the seam is. Make sure you put the paper in so that the top side is the side going through the machine. I do how ever believe you have a wheel or gear out of place.
Oct 15, 2015 | Canon Office Equipment & Supplies
Everytime I send something to print the printer starts normally, it grabs the paper to start printing but then the paper never moves again. It sounds as though the document is actually printing but theres...
I don't know what printer you have, but this applies to all printers. The first paragraph is just for inkjets. The the whole is related to laser printers.
85% of paper jams are caused by worn rollers. The rubber treads in the rollers wears down, making them smooth, so they won't pick up the paper. Sometimes, they are aged, which also gives them a smoother rounded texture, causing jams. The quick fix is to liven up that roller with a mixture of alcohol and soap. Damp a rag with the solution and wipe the rollers clean with it. That's make them more pliable and the paper jams will cease.
Metal Tab Separation- Pull out your paper tray and examine either end where the paper sits in. If any of the corners are held down by metal tabs, this is your paper feed system. Chances are, you only have one rubber roller or one set of rollers arranged along side of each other. Reach in where the tray goes and feel up. You should feel some rollers. They might be completely round, or they might be shaped like a half moon. Clean whichever part of them you can with the solution, and this should stop your paper jams. It might be necessary to turn them, but don't force them if they don't move freely.
Pickup Roller and Separation Pad-
If your printer uses this paper feed system, you should see a small piece of flat or slightly curved rubber or cork. It would be towards the end of the paper tray, or deep inside the paper loading cavity on top loaders. This 'separation pad' rubs against the paper feed roller, so if you find the pad, you've found the roller. Clean it and your jams should stop.
Three Roller Paper Separation System- Pull your paper tray out, and look for a roller on either end of it. If you find one, clean it. Then look inside the printer where that roller would rest with the paper tray inserted. You'll find another paper roller there. Clean this one also. Finally, look further back or closer to the front of your printer (depending on which way your paper feeds) to find another roller or set of rollers. Clean all of these, and your paper jams will go away
Jul 15, 2011 | Office Equipment & Supplies
Hi - My daughters Canon MP 210 printer stopped pulling paper into the printer. I did not observe any spinning of the paper grab wheel therefore I'm wondering if a drive belt broke or something else is not...
hello there
you need to check the gear that trigger the paper to pull from the tray, if the gear is making a sound when you print then totally you need to open the gear coz it might be disconnected.
thanks
Dec 23, 2010 | Canon PIXMA MP210 InkJet Printer
Dear all, When I try to print on printer Magic Color 24300DL it does not "grab" the paper in the tray. It makes some tries, "rolling" but without any succes.Then I get a Media Jam Tray 1 error,...
I fixed the problem with the machine not grabbing the paper.....I simply opened the main lid and then reached in and pulled out the triangular insert (DRUM?) and then when you look inside all the way to the bottom....you will see the rubber tongue that actually grabs the paper.....more than likely it will be dried out or dirty. If you clean it VERY carefully with a soft moist towelette maybe very little soap....it should clean back to grabbing again...of course I went another step forward and put Take Hold fingertip grip and massaged it into the rubber.......been working great ever since. Thicker stock I have to help with my finger.....but all regular stock should work just fine.....
Aug 09, 2010 | Konica Minolta magicolor 2430 DL Laser...
Samsung printer CLP-350N wont print
Possibly a full waste toner container. I had the same problem, took pout the waste container, tilted it and tapped it to get toner away from the sensor window, and then it printed perfectly. I will empty the container ASAP before it overflows.
Jan 10, 2010 | Samsung CLP-350N Laser Printer
PAPER FEED DOESNT WORK KONICA MINOLTA COLOR PRINTER
This happened to me one time after I pulled out a jammed paper the wrong way. I pulled it from the paper tray. Heard the sounds, it tried to grab the paper, but couldn't. It happened a long time ago, so I'm fuzzy on which part I tinkered with...but I recall that because I pulled the paper (backwards) from the tray, it flipped a lever/feeder/roller/thing and that 's why it wasn't grabbing the paper. If you look in the paper tray as the rollers go down to grab the paper, you'll see what's not working......sorry, lame solution.
Mar 26, 2009 | Konica Minolta magicolor 2430 DL Laser...
Information on how to use rear feed
1. Prepare your doc/file for printing.
2. Insert card stock with narrow side of stock in slot in back of printer until it hits rollers and stops. Don't force in any card stock thicker than max. rated.
3. Change printer setup to feed from rear.
4. Print.
Depending on what software you print from, you may need to change this each time you print if you intend to keep printing from that "tray."
Mar 09, 2009 | HP Deskjet 1120c InkJet Printer
HP PSC 1210 All-In-One InkJet Printer Logo
136 people viewed this question
Seeker5211
Seeker5211
