Question about Acer AL1716 17" LCD Monitor
Acer 1716 seems to start but will not pick up signal from OS
I turn monitor and computer on
Picks up splash screen for computer (Dell)
Picks up splash screen for OS (linux)
Initially will pick up OS for a while (several boots)
eventually after the OS has updated a few times the monitor stops
recognizing the OS at all. Very confusing
I have tried unplugging the monitor in case it is overheating no change
I have tried going thru 'awake from sleep' actions just in case usually nothing.
Frustrated
  • 1 more comment
  • Norman Thom Jul 24, 2009
    Have not tried on my apple
    using linux (ubuntu 9.04) and/or Windows XP
    in both cases picks up computer splash screen
    then OS splash (start up) screens but will only shows black screen from that point on. I know that it actually boots up by the musical tones it plays.
    and the fact that with a little ( a lot actually ) of
    fudging I can occasionally get into the Linux Desktop
    BTW Both OSs boot to desktop using CRT monitors
  • tommya300
    tommya300 May 11, 2010
    is this apple power OS
  • 85 Answers
There probably is an error in the hard drive, since its not booting up. I would replace the hard drive, or take it to your local computer repair shop. I hope this helps!
Posted on Jul 23, 2009
My dell TFT monitor picks power, the power led is ...
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed DELL monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Replacement bd: www.lcdrepair.us
May 21, 2010 | Dell E173FP 17" LCD Monitor
I have a AL 1716 monitor and the on/off button is
More likely to be bad caps with bulginh tops in the power supply, common problems, see some example of failed monitors here: http://s807.photobucket.com/home/budm/allalbums
Jan 06, 2010 | Acer AL1716B 17" LCD Monitor
TURNS ON. I SEE "ACER" ON THE SCREEN AND THEN IT SAY NO SIGNAL AND GOES TO BLACK.
You are seeing the monitor's splash screen that tells you the monitor is OK. It is not receiving a signal from the computer. That's the problem
Dec 11, 2009 | Acer Computers & Internet
Acer monitor only display for about 3 to 4 second
Sounds like a busted syncing circuit, probably due to a condenser. It takes about that time to heat or overcharge, at which point a safety feature will turn off the display.
You just MIGHT get some more life hours out of the monitor by tuning it to a lower resolution, but it will buy you a month even in the best hypothesis.
I'm afraid the monitor is in for a repair/replacement.
Oct 30, 2009 | Acer AL1716 F Monitor
External display not displaying!
When you are able to view a video clip on the external monitor, We can rule out the issue with the software. Probably you need to check the connections and also the external monitor settings in the display. The reload might have changed the old setup
Feb 03, 2009 | Dell Latitude D820 Notebook
Acer 1716 17 inch LCD monitor, screen fuzzy w/white lines at rt
Common problem.
There are 8 small VRAM BGA chips.
1 or 2 of them needs REFLOW.
Basically board service.
Dec 16, 2008 | Acer AL1716 17" LCD Monitor
ACER AL 1716
Hi...there,
It's seems your backlight inverter are busted, need to replaced a new one or repaired it.
Oct 11, 2008 | Acer AL1716 F Monitor
No post (blank screen) after intial driver install Acer 1716 LCD monitor
Please clarify something for me, after installing drivers, system reboots, and you have no POST information or startup screens at all?
Dec 15, 2007 | ATI RADEON 9550 Graphic Card
Acer monitor
What do you mean by it takes awhile to come on? Sometimes with these monitors depending on the type you have it takes time for the PC to pick up the signal. I have my PC hooked up to a KVM switch and it takes about 10 to 20 seconds for my monitors signal to be recognized.
Nov 15, 2007 | Acer AL1916W 19" LCD Monitor
Acer AL1716 17" LCD Monitor Logo
386 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
