Question about True 23 cu. ft. Commercial Freezer GDM-23FW
I need to know how a true GDM-23F freezer should function were can i get a owners manual i just want to know what should com on and when example evap fan is not on but the evap is below freezing should thier be power there now?
  • True Master
  • 1,253 Answers
Http://www.truemfg.com/pdf/InstallManuals/GDM/gdm_english.pdf
This should take you to the site for the owners manual. You may be looking for a technical manual inwhich True doesn't do that. I will be more than happy to answer any questions should this manual not have what you're looking for.
Good Luck.
Posted on Jul 25, 2009
My true cooler freezer in side fans dont turn on i run it for 15 min. the make is gdm-72f
first place to look is in the evap where the defrost/ fan delay is located. It is usually attached to the "U" tube on the evap and senses the temp. It prevents circulating warm are after a defrost. It could be bad and keeping the fans from running. Start there and let me know if I can be of further help
Jan 27, 2011 | True 72 cu. ft. / 2039 liter Commercial...
The fan on my true t 23f does not run. i check it is not getting power is there a fuzz or capacitor for this thanks
Are you talking about the fan inside the freezer? If yes, check the following items. The door has a switch that turns the lights off when the door closes, it also turns the fan off when you open the door. If it isn't working right the fan won't come on. There is also a round temperature senser on the coil inside the freezer called a "clickson" that keeps the fan from coming on until the coils are below 20 degrees, it may be bad. If you are low on freon, your coils may not be getting cold enough to trip the clickson. Feel of the small copper line going from the compressor to the coils on the outside of the freezer. It should be almost hot enough to burn your skin if you have enough freon. One other thing to check is the defrost timer. It is a box about 4 inches wide and 8 inches tall with a door on the front of it. Check the connections inside to be sure you are getting power through to the fan. Let me know how it turns out.
Oct 04, 2010 | True 23 cu. ft. / 651 liter Commercial...
Have a gdn-49 true freezer freezing in evap to compressor what could be the problems
low refrigerant, leak, evap fan inop, thermostat inop.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Sep 02, 2010 | True 49 cu. ft. / 1388 liter Commercial...
Light removal
get a screw driver and loose the light holder and replace it a new one bought .
May 03, 2010 | True 23 cu. ft. / 651 liter Commercial...
Timeclock Not going in defrost
http://www.truemfg.com/pdf/InstallManuals/GDM/gdm_english.pdf
Go to this web site and check out the owners manual. On pages 13 or 14, it discusses the time clock. If the time clock is not moving to begin a defrost cycle, I would say, replace it. It does have a mechanical motor and it can fail or lock up.
Hope this helps.
Dec 13, 2009 | True 49 cu. ft. / 1388 liter Commercial...
True Freezer- The 5 amp circuit breaker trips when the light on
I believe that breaker is actually for door frame heaters. Most true freezers have a resettable breaker for the door perimeter heaters only.
Sep 11, 2009 | True 23 cu. ft. / 651 liter Commercial...
Lights wont come on in the cooler
underneath the unit in the metal box there is a ballast for the lights check it to see if it is getting power and or producing power to the bulbs
Jun 15, 2009 | True 23 cu. ft. / 651 liter Commercial...
Kenmore commercial upright freezer not sealing well - thawing
If the door seal does not seal completely, replace it. This is very important for freezers.
Contact Rick at Restaurant Parts and More.
\1-888-814-1110. He can most likely get what you need. Just have model and serial numbers and he'll do the rest.
Home Depot and Lowes is a definite no.
Apr 04, 2009 | True 23 cu. ft. / 651 liter Commercial...
TRUE freezer model number GDM-49F.
Your unit should have a defrost timer.The timer may be stuck in a defrost.It should be located at the bottom of the unit next to the compressor.Open the door to the timer and observe the position of the timer.If you turn the knob and the unit starts up,it's the timer. If this is the case, you can purchase a new one at any local a/c supply.Let me know,Mike
Dec 13, 2007 | True 49 cu. ft. / 1388 liter Commercial...
True 23 cu. ft. Commercial Freezer GDM-23FW Logo
162 people viewed this question
Top True Freezers Experts
Dennis Boxerman
John Tripp
John Tripp
christian nielsen
Are you a True Freezer Expert? Answer questions, earn points and help others
