No monitor display
ACER T690 boots up, fan starts, but no monitor display. The fan is slow to start, red light comes on for a few seconds, but nothing shows up on my monitor anymore. I removed the RAM memory sticks and replaced. Even when I hit F8 and enter to go into VGA display nothing happens, either. The monitor connection is tight as well. Help please!!!
  • 724 Answers
Listen for beeps they are codes for wat is working or not on a boot. Go online with of course a different computer to find the defined code, The number of beeps and the durration of pauses between the beeps tells a story.
Sometime with power off, reseat the CPU of if the video card is not on board and occupies a slot reseat that too.
Posted on Jul 23, 2009
  • 70 Answers
Remove all data cables and external cards and press RAM than try again
Acer Aspire t690 Desktop Freezes or reboots with in minutes of start up...Running Windows Vista. Help???
It is possible that your computer is overheating and is shutting down to prevent it from doing any harm to itself.
Make sure that all fans are clean, there must be no dust present as it hinders airflow!!!
Install as many fans as possible. Computer temps should be in the region of 30-40 degrees centigrade. To avoid CPU throttling, where the CPU slows down to prevent frying itself.
Please take the time to rate my expertise.
Thanks
Nov 01, 2010 | Acer Aspire T690 (AST690UP820A) PC...
MY ACER LAPTOP 5535 WHEN SWTICHED ON, I CAN HERE THE FAN STARTED AND GREEN LIGHT SHOWS, BUT THE SCREEN IS BLANK, NOTHING DISPLAYING PLEASE HELP!
is sounds like the lcd display may be bad. try plugging a rgb cable into your laptop and another monitor to see if you get pic.
Aug 30, 2010 | Acer Computers & Internet
When I unplugged my Acer PC and plugged it back in, it would not restart. It did this once before, after punching it on and off repeatedly, it finally started. Not so this time...It makes the right noises...
It may be due to CPU Fan problem or other. If u can do, open the cpu cover and go to fan and Open the Fan or Sometimes hitting the fan may work. Don't hit it badly do gently okey. If solved thums up!
Jun 24, 2009 | Acer Aspire T690 (AST690UP820A) PC...
Cannot get new Motherboard to boot up in Normal Mode
what u may have done is wwhen u were installing the new board, gave a static shock to the system...that will cause only the fans to come on and nothing more...this is a bad problem bc u cannot fix it...if u figure out something else is wrong, and it gets fixed, let me know
Jun 20, 2009 | Gateway Computers & Internet
ACER 3100 does not boot
have u tried booting the computer with just the power supply hooked up and your battery out? iv'e had the same exact lab top and the battery went bad and the computer wouldnt do anything at all like your talking about. Even if i had the power supply hooked up and the battery. Remove the battery, and try booting it up.
May 23, 2009 | Acer Aspire 5100 Notebook
Emachine destop not recognising acer lcd monitor
It sounds more like the computer isn't starting up. The "no signal" message is coming from the monitor itself to tell you it's on but there's nothing coming in to display. Normally no special drivers are required for the monitor, and you'd see at least the computer maker's splash screen and BIOS messages if the computer was starting up properly.
You'll need to determine what is keeping the computer from starting up. Make sure it's getting AC power and that the power light comes on when you press the front panel power button. You may need a power supply. If the computer comes on but doesn't boot you may have memory problems or trouble with the motherboard. But your monitor is working properly.
May 10, 2009 | Microtek C593 15" Flat Panel LCD Monitor
Computer won't start up and has a constant tone.
If the noise is constant then it means the problem is either:
1: a Power supply issue
2: a motherboard issue
3: a keyboard problem
the latter of the three being the easiest to fix, try booting with your keyboard unplugged or even better if you have another keyboard try using it to see if that corrects the problem.
If the above does not work then you have a problem with 1 or 2, and in order to find out for certain you will need to test it, you can goto your local computer diagnostic store to see if they can check which it is.
and hope its not a problem with the motherboard.
Hope this helps, and Good Luck
Apr 13, 2009 | Computers & Internet
Acer 17 in. monitor
boot to safe-mode. (f8 pressed prior to windows starts) choose "safe mode" in this advanced boot menu. If the screen displays in this mode, it's a driver issue. If it fails, it's the screen or the vid card. Swap screens (CRT preferred) if it works vid card is good, screen is bad. If it fails you must use a known good vid card to isolate the point of failure
Apr 09, 2008 | Acer X221WSD Monitor
Acer Aspire T690 startup problem
MEMORY PROBLEMS Hi, FOR LONG BEEPS, ONE SHORT BEEP IN AN ENDLESS LOOP, BLUE SCREEN OF DEATH AT STARTUP Try using Memtest 86+ http://www.memtest86.com/ to diagnose your memory problem. You can also try the following methods. Turn off power, Unplug. Remove the cover of your PC. Remove the memory from the Motherboard. Note on the locks! Clean the memory contacts with an eraser yes that's right a rubber Pencil eraser. It should be shiny gold. Reseat your memory to the motherboard and Test! ====================== If you are having trouble with Newly bought items save your self from headaches by returning them and demand a replacement or a refund! You may have purchased a reconditioned\repaired\factory defect product.
Sep 19, 2007 | Acer Aspire T690 (AST690UP820A) PC...
Computers & Internet Logo
149 people viewed this question
David Payne
David Payne
