Laptop dell inspiron 1545..when I turned it on. the power is working and the dell logo still appeared on the screen but after that, display in the screen remained blank as if it's still reading for windows but it remained like that and never continued to open windows vista.what seems to be the problem and what is the possible solution?
  • 374 Answers
  1. Take out your battery and the power button for about 60secs.
  2. Start the laptop using the Adapter [without the battery]
  3. Lighten up your laptop...remove any external device attached [printer,scanner,pen drives etc.].
  4. It could also be a RAM problem,try changing the RAM if you have two start with one and exchange them.
After that when the system starts you can do the system restore START--ALL PROGRAMS--ACCESSORIES--SYSTEM TOOLS--SYSTEM RESTORE to restore it back to an earlier date when laptop was ok. THEN LATER ON PUT THE BATTERY BACK IN.
  • Try restarting after an hour gap.
  • If this doesn't solve your problem call the company people.Their might be a Video Card problem or any other internal hardware problem.
Posted on Jul 23, 2009
I have a 18 month old inspiron 1545 and suddenly its display went to dead black. But still windows is loading up i can hear sounds and music but can't see a single blink on the display. Don't know...
Hi paramvirgull...
Hook your laptop to an external monitor and see if the screen comes on...if it does then your lcd screen is faulty and needs replacment.
If it does not come on then re-download your video driver/s. If that does not work.
Maybe your lcd inverter or backlight bulb is faulty and needs replacement.
Please take time to rate me thumbs up
Sep 16, 2011 | Dell Inspiron 1545 Notebook
I have a dell inspiron 1545.week before it showing time-of-date stopped. then I changed motherboard coin battery.now my laptop not booting up when I press start button the DELL logo come up on screen with...
hi
first off all open hdd screw and pulld hdd in laptop then check
if not stuck problems in hdd if stuck then check rams super drivewifi card and othere hardware
click yes for vote
Feb 22, 2011 | Dell Inspiron 1545 Notebook
When turning on Dell laptop, lcd screen turns gray
Maybe you have wrongly pressed the keys for turning down the brightness of Dell inspiron 1545 under a careless.Just back to the normal setting. Good luck!
Feb 17, 2011 | Dell Inspiron 1545 Notebook
Failing to load up now after crashing. Gave run series of tests and it mentions something of the hard drive My laptop is not the notebook tho
Run Dell diagnostics to see if your hard drive is faulty.
Connect power cable, turn on laptop and press F12 key when the Dell logo comes up.
Select Diagnostics and hit enter, if you get the windows splash screen, turn off laptop and repeat.
Feb 10, 2011 | Dell Inspiron 1545 Notebook
All i want to know is HOW DO YOU REBOOT A DELL INSPIRON 1545 TO FACTORY SETTINGS I DON'T HAVE THE MONEY TO TAKE IT IN.
Windows Vista: Dell Factory Image Restore
  1. Turn on the computer. When the Dell logo appears, press several times to access the Vista Advanced Boot Options window.
  2. Select Repair Your Computer.
The System Recovery Options window appears.
  1. Select a keyboard layout and click Next.
  2. To access the recovery options, log on as a local user. To access the command prompt, typeadministrator in the User name field, then click OK.
  3. Click Dell Factory Image Restore.
note.gif NOTE: Depending upon your configuration, you may need to select Dell Factory Tools, then Dell Factory Image Restore.
The Dell Factory Image Restore welcome screen appears.
  1. Click Next.
Nov 09, 2010 | Dell Inspiron 1545 Notebook
Blank screen on my Dell Inspiron 1545
if your getting your dell logo it means your disply is working fine
may be u r windows is not working properly just try to up-date your windows with any windows disk
Apr 25, 2010 | Dell Inspiron 1545 Notebook
I hit F1 key and screen is black...been in phone with Dell for over 45 minutes...help I am on another pc
when you hit F1 key it was on the Dell screen logo right? so after hitting the key F1 it just go straight black screen with a cursor?
since you where able to get display try. 1. turn off laptop make sure ac adapter is plug in. 2. while laptop is off press and hold on the Fn key then press power while pressing on Fn. 3. Check if a self-assessment will display and run on the screen. Just follow the prompt messages on the screen to guide you for the error messages which will help you to identify the problem.
Mar 27, 2010 | Dell Inspiron 1545 Notebook
Dell Inspiron 1545 Broken Screen?
The LCD is definitely shattered, looks like pressure was applied from the back of the screen (Pressed on, laid on etc) and the LCD will need to be replaced.
Several are available on Ebay
http://shop.ebay.com/?_from=R40&_trksid=p3907.m38.l1313&_nkw=Inspiron+1545+LCD&_sacat=See-All-Categories
Service instructions are here
http://support.dell.com/support/edocs/systems/ins1545/en/SM/display.htm#wp1183775
Feb 07, 2010 | Dell Inspiron 1545 Notebook
Dell inspiron 1545 won't boot turn on start up
Unseat and reseat the memory in the laptop one stick at a time in each slot one at a time. Turn on the laptop after each reseat of memory.
If that doesn't work then take out the hard drive and then the dvd drive.
Turn the laptop on again and if you still can't get video on the screen then the motherboard is defective and would need to be replaced.
Nov 30, 2009 | Dell Inspiron 1545 Notebook
Unexpected shutdown in dell inspiron 1545
it's not clear if the laptop shutsdown while in use or while its idle. it it shuitsdown while its idle meaning keyboard and mouse not touched for about 5 minutes this might caused by the power options from the control panel. try to turn off the power options make sure it is set to never.
if shutsdown happens while moving mouse and touching keyboard this might be cause a conflicting windows update. try to reboot computer the boot to F8 then select last known good configuration. if this fails try to run PSA test. power off the laptop then press and hold on the Fn key then press power button at the same time just one, this will run the pre-boot self assessment to check memory and hdd problems, once you see colors display press Y to continue testing, take note of any error code might display such as 0142 and 0146 this are hard drive issues and might needing to replace your hdd.
Nov 12, 2009 | Dell Inspiron 1545 Notebook
Computers & Internet Logo
395 people viewed this question
David Payne
David Payne
