Question about Bose Lifestyle 20 System
Bose cd cartridge will not eject makes noise even when the power off. I have to unplugg it in order for the sound to go away. Thank you, Tamar
  • Bill Weigold Nov 23, 2007
    It's amazing. My problem started Nov. 22, 2007. I found on the bottom of the receiver that there is a manual eject sign. I was able to stick a skinny knife in the slot and push it back. It ejected the cartridge but not enough to pull it out. Something is holding on that won't release. Once you find the thin slot, put your thin knife and pull backward. Shine a flashlight into the slot or the one next to it and you will see that your knife will be hitting a small piece of metal that slides back and forth. That will at least stop the noise. Maybe in your case, it may actually release the entire cartridge.
I just fixed mine tonight. Follow lytebrite's solution for removing the caddy.
Posted on Nov 12, 2008
Kenwood 10 Disc Cartridge won't eject
From your description it is likely that a CD is jammed in the player, preventing the magazine from being removed. Even though your Kenwood is hard to get to, it will have to be removed and disassembled to correct the problem
Feb 01, 2013 | Car Audio & Video
Bose multi cd player will not eject cd
Unfortuneatelly this must go the Bose, There is no authorized technicians outside of the factory, since this was a expensive machine they have the parts on hand to fix your player where no one else does.
May 14, 2012 | Bose Audio Players & Recorders
I can not eject a disc from the disc player. I've heard this is a common problem. Thanks. Curt Pasawicz
Hi curt730,
You're right, this is a known issue for years with Bose Lifestyle. You may try these steps to resolve the issue:
Note: You will need a flashlight and a small screwdriver.
1. First, disconnect the base unit from the system.
2. Turn the base unit upside down and find the access hole embossed with "Manual magazine release" on the CD player side.
3. Then, using the flashlight, look inside the base unit at those access holes and find the fine spring and locate where it fastens to the sheet metal of the CD player.
4. The moment you find the spring you should see that it connects to the CD player chassis at the forward end and a piece of sheet metal that is on top (actually underneath when the base unit is right-wide up) of the CD player chassis at the rear end. This is the manual release mechanism.
5. Finally using the small screwdriver, push the release mechanism rearward to release the CD magazine from the player. The magazine should pop out.
If the magazine is not released, then the CD that is still in the player has not been slid back fully into the magazine. In this case you'll need to plug the base unit back into power and hope that the CD is retracted, allowing you to push the release mechanism rearward. If not then you'll have to open the base unit to access the CD player.
Hope this helps.
Thank you for using FixYa.
Jun 08, 2011 | Bose Lifestyle 28 System
Cannot retrive CD , makes a noise and will not release
Not a solution, just confirmation that my system problem sounds like yours. Hit eject and it makes noises but will not open to release the CD.
Hope someone finds an answer.
Nov 15, 2010 | Bose Wave Music System CD Shelf System
Hello any cable or satelite tv show is now more comonly in high definition sound and video! and the techs are wrong because their are plenty of movies on tv including news channels that broadcast in surround sound ,but in order to get that surround sound you must either have a connection from the tv,s audio out or you can also out put the sound from the cable or satelite box out to your bose system as as the scritching sound where does it only happen when in surround mode or stereo mode ? if you play a dvd or cd does it still make noise? and can you be more specific on your terminology SCRITCHING not really shure what you mean by that word! thank you glenn mayer
Mar 06, 2009 | Bose Lifestyle 38 System - white Theater...
Cd magazine stuck in unit. you can hear the motor
There should be a tiny pinhole on the drawer. Put the end of a paper clip into the hole and push lightly. This will release the cd drawer.
Jan 12, 2009 | Bose Lifestyle 25 System
I gave the Bose Wave Radio and 3-cd player to a friend for
Unplug and plug back in. It should go through a automatic process, ejecting any discs that are inside. If all you hear is a mechanical noise, try this again only with the disc trays facing the ceiling.
Dec 29, 2008 | Bose Wave Radio
Hi, Underneath the unit you will see a small slot and "manual cd eject" embossed on the case , a jewelers screwdriver or darning needle or anything stiff and thin to pull down the wire lever inside the slot should do it.
Dec 28, 2008 | Audio Players & Recorders
Bose CD for Surround Sound System
First suggestion by Bose was to unplug the power cord for about 30 minutes and then plug it back and hit the Eject button...didn't work. Second suggestion was to unplug the power, tilt the unit up onto its left side and then "whack" the bottom of the left side a couple of good whacks. Worked fine and cassette would then eject.
Apr 20, 2008 | Bose 683-0127FB CD Shelf System
Cd changer
Could be some dirt on mechanism. Try to open cover, remove disc and clean it. Unplug it from power first, of course!
Oct 03, 2007 | Bose Lifestyle 25 System
Bose Lifestyle 20 System Logo
289 people viewed this question
Top Bose Audio Players & Recorders Experts
Level 1 Expert
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
