If the amount of oil that was lost wasn't significant more than 500ml, then it would be safe to poke down to a mechanic, so long as its not 100kms away, vehicle unloaded and not driving at highway speeds.
Ac refrigerant is most likely low causing this, would need more info to tell u exactly. Other possible causes could be pressure switch, ac heat control unit, low refrigerant, bad compressor, wiring problem, if refrigerant is full would need to make sure your getting power and ground to compressor.
You can unlock your account by entering only your user Id and request to be sent a new password. Facebook will send you a temporary password to your email on file. The User ID and email much match, in order to receive the temp PW. Or you can sign up anew, and at time it says this email or user name is already on file, request the missing unknown.
sometimes because of non moving part inside of transfer case, elements stuck or gets slower to react against changes in mode. try to switch to another transfer mode in nuetral position and stopping. after switching to desired mode move few hundred meters.
if this does not help you may need to check linkage on transfer case.
please try to switch back to 2wd mode in neutral position. then move car for few hundred meters. if this wont help you need to check the linkage mechanism on np242 transfer case.
no not realy the best thing to do is take one off and go to a aftermarket place and get a nmew one if you go to the dealer youo will pay almost 2x as much and if you go to the store in off peak hrs they probly will help you get them off or at least show you how to do it usuly there is a clip on one end and just a ball joint on the other
good luck
Hi, Sorry to hear you're having problems with Yahoo. Did you email them? Did Yahoo remove the account? Did you share your password by accident? - think back hard Did you put your account information to see the 'adult pictures of a new member? Please check all of these - if no - then try again slowly - the last known configuration Try this as a last resort - try to get the account as a new user - as if the account user name wasn't taken ans see what Yahoo does then.
If nothing else works go to log in and when it ask 'can't get into your account' click on that and follow prompts and then email Yahoo customer service [ ya it's a joke but all you got now.
Beware! Its a scam. Do NOT give out any personal information. If you do, they (the senders) will probably ask you to deposit a small fee so they can send you the prize money. After receiving your cash they will move away! Just send this email to your spam folder. Just for your information, I also received one of these. Thank you.
