Question about Dell Computers & Internet
I need to transfer files from an external hardrive
I need to transfer files from an external harddrive to a Dell Pc on which I am running Windows vista home premium. It has a built in file transfer program but I don't know how to use it for an external harddrive.
  • Steve Caulfield Jul 24, 2009
    Hello and thanks-My problem was that my computer was not recognizing the external harddrive when I opened "My computer" Another expert told me that it may need to be assigned a letter in disc managment. I went to disc managment in " my computer" and accidentally changed the external harddrive from dynamic to basic and the manager states that the data on the disc is lost.Is there any way that I can retrieve the data?
    thanks for the truth-that's the best answer
  • 3,037 Answers
Well you don't need to use a file transfer program. Just open "My Computer" then open the External Harddrive in one window and open the folder that you want to transfer to in another window. Then you can select the files you want and either drag them over to the folder. Or you can right click on each file then click on cut or copy and then paste them in the new folder. Or you can click on Edit at the top, select all, and then cut or copy and then paste them all in the new folder never needing the Transfer program. It is a pretty simple process, but if you have any further questions, please let me know. It is just like moving files from any other drive, such as flash or a cd.
Benjamin
Posted on Jul 23, 2009
  • Benjamin Patri
    Benjamin Patri Jul 24, 2009
    Its rather complex, you would be better off paying someone else to recover the lost data. I'm sorry to tell you this as its not something I'm sure you wanted to hear. Let me know how it turns out.
I got an old laptop and I bought a new toshiba laptop I just wanna ask how do I transfer my application and files from my old laptop to a new one using external hardrive,also wat external hardrive,and also...
You can transfer the data files only from the old laptop to the new one. You cannot transfer the installed applications/software. Software are required to installed again on the new laptop afresh.
To transfer the data you can use external portable hard disk, which can be connected to the PC using any USB port (just like pen drive) and you can copy - paste the required data to the external disk just like you copy data from one partition to another. After copying the required data, you can connect the external drive to new laptop and copy the data to the new laptop. You can use external drive of any brand/ capacity. However, it is better to have an external drive with larger capacity, so that you can transfer the data in one go.
Hope it helps! Good Luck! Thanks for using Fixya!
CreativeTECH
Sep 20, 2011 | Toshiba Computers & Internet
EMachines Recovery Discs
Hi Sandysue, As I understand your problem, 1. The error could be caused by: memory, video, hardrive or drivers; 2. Windows by asking you to run CHKDSK /F has detected a possible problem with your harddrive; 3. It is possible that the reason you cannot go to DOS mode is because your harddrive is formatted in NTFS and not FAT332. There are a couple of ways on how to go about this but all would require that you have access to second PC: 1. Run a third party software (BartPE) that you will have to boot from your CD Drive or USB and run a disk checking utility; 2. Remove your hardrive and install it as a secondary master in the 2nd PC and run chkdsk or scandisk; 3. Remove your hardrive and install it in an external HD enclosure and connect using USB to the 2nd PC and run chkdsk or scandisk; 4. Remove your hardrive and install it either USB or as secondary master to the 2nd PC. Copy all your important files to the 2nd PC, and repartition/reformat. Reinstall to the eMachine and reinstall Windows. There is a possibility that even if you were able to run CHKDSK or Scandisk eventually your best bet would still be #4. If you have gained access to the inside of your eMachine PC, it would also be a good idea to remove/reinsert any cards and the memory stick(s). A little housekeeping would also be nice. I hope that this be of some help and pls post again how things turn up or if you need further information. Goodluck and kind regards.
Jul 31, 2007 | AMD eMachines Desktop System w/ 17'' CRT...
My pc dell optiex gx270 when i attach 1 hardrive in computer in start up time in black screen message 0 seek failure , boot press f1 to stup press f2 when i press f1 message not boot drive find when go to...
once in the setup (F2 at boot) turn on Caps Lock, NumLock and Scroll Lock (all 3 keyboard lights on)
Press ALT + E (system should beep once) Press ALT + F (System should beep once) Press ALT + B (System should reboot and re-detect drives)
Aug 05, 2011 | Dell Dimension 3100 PC Desktop
My Dell desktop computer will not boot and it is too old to spend money on repairs. However, I would like to be able to get the files off my hard drive. If I buy a kit and turn the internal hard drive...
Nope. you cannot access your files. even if you use a external hard dive to access the files.
i suggest you install windows 7 in your computer but do not reformat the hard disk . in that way your files will still be saved in your harddrive.
Once you have access to your files i suggest you save them in a flash drive or external hard drive if you have one. then reformat your computer and install a windows xp.
here is a tutorial on how to install windows 7 without reformatting your harddrive.
Goodluck. If you have any success using my solution please give me updates.. Thanks
Nov 09, 2010 | Dell Dimension E521 (D10E16) PC Desktop
Optiplex GXS 240 Dell. After 6 years of hard work
Run the onboard diagnostics on the hardrives and system memory before doing the OS reinstall.
Instructions on how to run diagnostics are given below
http://tinyurl.com/lg7teo
Another workaround you can try is disconnect one hardrive from the computer and install the OS and then put the additional harddrive
proton
Sep 18, 2009 | Dell OptiPlex GX260 PC Desktop
I need to transfer files from anexternal hardrive tomy computer. The external hardrive is connected to my computer but is not showing up.I bought a casr for an internal hardrive that I had removed. I have...
It could be that the OS is not assigning a drive letter to your removable drive. To do this, go to disk management and assign one.
Right-click My Computer then Manage
Click on Disk Management
Right-click the removable drive and click on Change Drive Letter
Assign a drive letter and click OK
Your drive should now show up on My Computer
Hope this helps.
Jul 23, 2009 | Computers & Internet
No PBR3 or PBR4
The loading PBR descriptor error that you are getting could be because of two reasons. An invalid DOS partison on the harddrive and second a bad hardrive.
Use the following link to debug the harddrive ie. low level format of the hardrive. if the issue is still unresolved, it would require a replacement the harddrive.
http://support.dell.com/support/topics/topic.aspx/la/shared/support/dsn/en/alt_dsn_07302457082c47eda1a8f9619885f51f?c=us&l=en&s=gen
Proton
Apr 30, 2009 | Computers & Internet
Hardrive not working
Try the harddrive in an external case. If that dosent work the board on the drive is fried, and youll have to find an exact harddrive and transfer the board.
Jan 11, 2009 | CybertronPC AMD Sempron 2400+/ 128MB DDR...
Adding mor memory
A laptop can only have a single internal harddrive but you can replace your current drive with a larger one. The cost will depend on the size of the drive... goto the dell site and get your drive specs then goto a hardrive manufacturer site like Maxtor and see what size drives are avialble with the same specs ... you will have to backup and transfere all your files and also reinstall all of your applications and OS...
Apr 06, 2008 | Dell Inspiron™ E1505 PC Notebook
MY LAPTOP DOESNT DETECT HARDDRIVE!!!
I would say, without looking into it, your hard drive is dead. Yes, you can replace the internal harddrive for another one and just install Windows 2000.
Apr 03, 2007 | NEC Versa 2760MT Notebook
Computers & Internet Logo
22 people viewed this question
Alun Cox
