Home | Creative Labs | ZEN V Plus MP3 Player | Won't turn on
Creative Labs ZEN V Plus MP3 Player
Problem for Creative Labs ZEN V Plus MP3 Player
Won't turn on
By dessikins on Nov 21, 2007
So my Creative V Zen won't turn on at all, even when i plug it into the computer. And the reset button doesn't work either. Any help?
Same Problem
May 21, 2009
-   it still will not work
-   Guest
May 14, 2009
-   I was recording and it froze then shut off and wont turn on-   Guest
Apr 13, 2009
-   i was tryuing to download my mp3 to the computer my mp3 player worked but when i took imy connection out it has now stopped working ive changed my batterys brought new ones and still does not work -   chantellehob
Mar 25, 2009
-   I charge the battery; it shows filled for about 5 minutes after, and then doesn't turn on anymore-   Guest
Mar 24, 2009
-   my zen wont switch on , i tried resetting it and pluggin it to the pc but a blue let just kept going on and off on top when i plugged it to the pc what should i do-   babiieehack3
Best Solution
posted on Jun 19, 2008
Very Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
That happened to me. It was weird though, as it turned out there was no battery. I had turned it on and was listerning to it, and it had full battery, and then suddenly all the power was drained from it. I left it 48 hours, and then connected it to the computer.
Now it works great.
Solution #2
posted on Feb 06, 2008
Very Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
Same Happened For Me I Just reset it And It Worked
Lambo U Rock =D
Solution #3
posted on Nov 29, 2007
Helpful)
0_Lambo_0
Rank: Apprentice
Rating: 93%, 141 votes
Ok I had same problem, Zen V Plus wouldn't switch on, when plugged into PC no lights came nothing, absolutly dead. Found this on another website and well i'll be jiggered it worked, hope it does for you too.
Plug it into the PC, hold the power switch in the 'on' position, THEN trigger the reset button, (hold it in for a few seconds). make sure you feel the reset button depress.
Good Luck
Was this helpful?
Yes
No
49 people thought this was helpful
Solution #4
posted on Aug 15, 2008
Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
hold reset + power button.
it happened to me just a minute ago, and now it's working perrrfectly. ^_^
Solution #5
posted on May 28, 2009
Very Helpful)
christinelin
Rank: Master
Rating: 81%, 8 votes
same problem here...none of the solutions worked...but this one I found....it's the computer not the zen (i didn't think this would work but after i did this it started charging and turned on right away)
posted on Feb 25, 2009 abeales
If you have windows set to do automatic updates, you most likely had a windows update installed that caused this conflict with Win Media Player 11. No fix has been posted by Microsoft yet, so the only workaround is to Uninstall/Rollback Windows Media Player 11. Goto <Control Panel<Add/Remove Programs and remove Windows Media Player 11. Follow prompts, restart computer when prompted to. Also uninstall Windows Media Player 11 Runtime application following same procedure above.
This will roll your Windows Media Player back to version 10 or 9, whichever you had installed prior to version 11. You will need to re-configure Windows Media Player again.
Your Zen should now be recognized by WMP and Creative software. You probably need to upgrade your firmware at this point, follow the instructions on upgrading your firmware, and you should be good to go.
This is a windows problem, not a creative problem. Dont blame Creative for the screwed up hotfixes that Microsoft puts out on a regular basi
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #6
posted on Feb 21, 2009
Helpful)
marv42
Rank: Apprentice
Rating: 91%, 8 votes
I fixed it!! Totally died and wouldnt turn on. ehen plugged in only flashing blue light from play button. Plugged it into charger, held down play button and switched power to on. hold it. a reboot screen will come up, select last option. working fine now just needs charging. didnt lose file either, yay!
Was this helpful?
Yes
No
5 people thought this was helpful
Solution #7
posted on Jan 29, 2009
Helpful)
amnondorf
Rank: Apprentice
Rating: 88%, 4 votes
WOW! Thank you guys for this info! This has happened to me twice and I had sent it in to the manufacturer under the warranty. Then it happened to me again not 2 months later. I was furious! Again, thank you so much! The company should be thanking you guys too! ;)
Comments:
Jan 30, 2009
- Did this power/reset thing earlier today, thought it was working. Came back later and it was back to no lights, absolutely dead, even after staying plugged into puter for several hours. Tried power/reset thing again, & now THAT doesn't even work. PLEASE HELP!!
Was this helpful?
Yes
No
2 people thought this was helpful
Solution #8
posted on Nov 08, 2008
Helpful)
gfonzi187
Rank: Apprentice
Rating: 83%, 3 votes
hold power and reset worked for me too....!!! Thanks, posters.
Was this helpful?
Yes
No
Solution #9
posted on Aug 17, 2008
Somewhat Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
WOOOoo thankyou, i had exactly the same problem too, and that worked!! i nearly had a heart attack when it froze going on holiday next week ha ha :)
Solution #10
posted on Sep 15, 2009
Not Rated)
mackenzie777
Rank: Apprentice
Rating: 0%, 0 votes
My creatice zen is compleatly dead. i tryed the reset button an pluged it in and even turn it on and had it plunged in and reset it all the same time. i havs froizen before but never like this. needs to be fixed. please help!!!!!! thank you!
Was this helpful?
Yes
No
Solution #11
posted on Aug 22, 2008
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
0_Lambo_0, thank you for your suggested solution. It worked for me.
Popular Solutions for Creative Labs ZEN V Plus MP3
Questions and Unsolved Problems for Creative Labs ZEN V Plus MP3
Do you recommend Creative Labs ZEN V Plus MP3 Player?
Answer
Answer
where could i download an installation and application cd for my zen vplus mp3 player at?
Answer
my creative zen was working perfectly, then the screen was white an it wouldnt show anything but i... (More)
Answer
My mp3 player comes up with only a white screen. It does not come up with any displays or anything.
36 Other Users Have The Same Problem - Continued
Comment by Guest, posted on Mar 11, 2009
how to reset this player
i put i the hol wire in 20 sec. but nothing hapend
the player turn off
Comment by mehakpreet_2, posted on Feb 23, 2009
my creative zen b plus has frozen.It is dead. I connected it to the pc,to the charger.Still it does not work.I tried the power and reset thing but that also does not work.What should i do??
my creative mp3 is dead!! it does not switch on. I tried all the methods written above. what should i do? PLease help me!!
Comment by DADALNJ, posted on Feb 18, 2009
Same thing for me The reset worked didnt even know it had a reset until I looked Thanks so much.
Comment by Guest, posted on Feb 12, 2009
when I connect my Zen to the pc it turns on and let me upload/but wen I take it off the pc it doesn't have a charge; it turns completely off..When I attempt to charge the Zen in the wall charger it doesn't charge at all/or turn on. what can I do? help!!
Comment by earlinebrwn, posted on Feb 09, 2009
wont charge with usb fairly, new mp3 player is dead!
Comment by Guest, posted on Jan 28, 2009
MY Zen V I have the same problem.. My computer does shows it connected to my computer, and The blue lights turn on, But it flashs, But the only I can't see the screen turn on.. Its looks like its dead but the blus lights come on and off. I was even to do more misic into it when its connect to my computer,
Comment by DanierA, posted on Jan 11, 2009
My creative zen will turn on if I hook it up to the USB or the wall, but when I turn it off, it won't cut on again unless I hook it up again.
It says the battery is fully charged, so what could the problem be?
It's frustrating.
I've tried the reset+power thing.
What else can I do?
Comment by rlfletcher8, posted on Jan 08, 2009
Won't turn on, Connected to computer, tried the reset, dont even know if it's charging.
Comment by Guest, posted on Jan 08, 2009
i tryed every thing nothing works i charged it i connected it to the computer and pressed the rest butten WHAT DO I DO?
Comment by Guest, posted on Jan 05, 2009
it wont turn on!
Comment by anushah911, posted on Dec 18, 2008
my creative zen won't turn on. i plugged it on the computer and no lights appear?
Comment by Guest, posted on Dec 16, 2008
My zen will charge up fully then after 10 minutes of use, the battery is completely drained! I have yet to figure out what's happening.
Comment by thyshee9, posted on Nov 03, 2008
my creative zen wont turn on no matter what
i even press the reset buttom and put try to charge it.
it still want come on
Comment by lover123, posted on Oct 01, 2008
mine wont turn on no matter what i do
Comment by Guest, posted on Sep 19, 2008
my zenw ont turn on either. even when its plugged into the computer.
Comment by Guest, posted on Aug 20, 2008
my player is stuck on the CREATIVE ... words when it appers in the beginning .... and it only says this when attached to a computer. if its not attached, the player just doesnt work. if any1 knows how to solve this plz reply.
i have tried to use the reset button.. but its not working
Comment by Technophob54, posted on Jul 20, 2008
My creative Zen M 30 would not do anything after leaving it plugged in for 24 hours. I hit the reset while holding the power button on and it all came back. It is fully charged and it is working. Thanks to all who have problem solved on this website.
Technophopic
Comment by Guest, posted on Jul 15, 2008
Zen will not turn on. This is the 2nd 4gb model I have purchased this year. The 1st works perfectly but I passed it on to my son. This (new) model is dead, or so it seems.
Comment by DMW731, posted on Jul 11, 2008
ZEN was on playing song from playlist...decided to switch to FM to hear a baseball game. Hit stop button and then went to use the back button and joystick to get to Menu. The unit froze, featuring a drop of water in a pond picture. Couldn't get it to do anything. Plugged into wall charger as well as trickle charger to see if I could at least shut it off, nothing. Left it on the wall charger over night, woke to a black screen but still no ability to turn it on. Plugged into computer, it stated the unit was not plugged in even though it was. Unit not responding to any on/off commands...now what?
Comment by Guest, posted on Jul 08, 2008
my zen v wont turnn on even when i turn on computer and my reset does not work.
Comment by imissmyZenV, posted on May 30, 2008
Mine is totally dead. The lights don't turn on, the screen is black, the reset button doesn't work. I hope it's not gone for life!
I'm going to try a few things and see if it works. Here, maybe you might want to try these things. I've got all of these from various websites.
(1) press the reset button (hole right below the on/off) with a pin.
(2) Make sure it's not on lock.
(3) Leave out UNPLUGGED for a few hours. Somebody said this worked.
(4) charge it for a good amount of time (like a whole 24 hours) --it's what I'm going to do. The only problem with this is...is that I don't know if it's getting the power supply because it says it's not connected! Ack!
(5) call them! at http://www.creative.com/support there's a few ways you can get help (I don't want to do this just yet)
(6) hold the on-button down, while pressing reset, while having it charged in.
(7) or do the same thing uncharged
these are just various solutions I found.
Comment by Guest, posted on Apr 03, 2008
lambo is right mine is fixed
Comment by tdhodge40, posted on Jan 07, 2008
wont turn on at all, isnt recognized when i plug it in, and is getting hot to the touch when i try to plug it in.
Comment by Guest, posted on Jan 06, 2008
when plugged in the computer recognizes the zen, but the unit won't charge. Reset button does not work
Comment by Guest, posted on Dec 21, 2007
In the middle of setting up this gift for our daughter, the player just died. The computer wouldn't even recognize it. We followed the hint below by Lambo and it worked. Connect player to PC, hold ON switch while pressing reset button for a few seconds. Thanks Lambo!!
Comment by Guest, posted on Dec 20, 2007
my creative zen v plus wont turn on what should i do
Comment by Guest, posted on Dec 03, 2007
Had same problem , looked totally dead thought it was "fried" , same day as trying to set-up the player for my daughter, was ready to return to store
and tried the suugestion below by o-lambo (reset while connected to pc) . It worked and now the PC actually now recognizes the player , it didn't before.
THANKS for your help. Would rate this solution a FIX ya but do not want to to register to yet another board
Comment by Guest, posted on Nov 29, 2007
Zen V Plus wont turn on
Comment by Guest, posted on Nov 27, 2007
MY zen has done this before twice, lucky me, after about 2 days of being off, i managed to turn it on again. I don't know what the problem is, but mine is doing it again.
Comment by efduran510, posted on Nov 24, 2007
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Creative Labs ZEN V Plus MP3...:
Top MP3 and Digital Med... Experts
Rank: Guru Guru
Solutions: 477
Experience: By using this stuff I know what I know when I know, but sometimes don't know how I know you know??
Ask Me
Find more MP3 and Digital Med... Experts
Top Audio & Video Equ... Repair
(888) 737-1752
XBOX360 & PS3 REPAIR EXPERT SERVICE We can...
xbox360 fixer
(888) 399-5512
EverGreen Electronics is the ONLY Apple iPod and...
Apple iPod Service
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
