Question about Samsung RS2630SH Side by Side Refrigerator
Not cooling Everything seems to be working but the fridge doesn't seem to get cold at all. The compressor sounds like is working from the outside but can't hear anything inside.
  • crumpscott Jul 23, 2009
    It remains room temp inside. It pretty warm inside. Would that cost alot to fix the leak?
  • crumpscott Jul 29, 2009
    Apprentice,
    Thanks so much for your help on the fridge but it has been unplugged for a week. Could it be my compreesor and if so, how much can I get that fixed for and can I do it myself?
Cooling fan, behind internal plasic panel is frozen up, happens with me regularly, self defrost function not working properly, i'm just fixing mine as I write. I have found that bottom drain hole was all full of ice also. Have cleared with anti-freeze/hot water till runs through. Take out all shelves, remove back panel, there are screws behind chrome bezel and also inde-odoriser recesses (those two square plastic covers). Unscrew plastic water chiller, be careful not to damage pipes. Remove the back platic moulding, unclipping wire connectors and cooling fan is fastened to back, it will be frozen up with ice! I use hair dryer/ de-icer to thaw, dry off as much as possible. Beware, moulding is mainly polystyrene, i.e fragile. I suspect that I keep getting problems because I didn't clear out the bottom drain hole, so it did not defrost. Tell tale sign is noisy fan (hitting ice) which eventually freezes up and stops blowing cold air which causes fridge to stop cooling, compressor still works though!
Posted on Jul 29, 2009
    Problem Solver:
  • 5 Answers
I had this problem also. Similar to neil83 solution, my issue was solved by removing the panel in the back of the freezer. The difference was my fan was working fine, only the cooling element (the metal "radiator" directly under the fan) had become so encrusted with ice that no air was able to pass through the element and therefore no cold air was circulating through the fridge. Take off both panels in the back of your freezer and have a look, if it's frozen solid, leave a hair dryer pointed at it for a few hours until the ice melts, should fix your problem.
  • 65 Answers
You probably have a leake somewere ,means that there are no more gaz in compressor !!
one more question but! is your frig hot in the inside??
Posted on Jul 23, 2009
  • patrick martin Jul 23, 2009
    if repair need and reffill coolant gaz it should cost around 100$
Freezer stays cold but fridge has been warm. I turn the thermostat to off for a day and then everything is ok for a week. Sounds like the fan is frozen solid when fridge doesn't work( no sound) Th
If there is no cooling at all on the fridge section but the freezer works then it is confirmed that the compressor and gas pressure is OK. Now shut off the fridge and leave it powered off while you clean and check the evaporator for frost. If frost is seen it is a good indication as the compressor is working with sufficient gas within.
Now after about 6 hours plug in the fridge to start. Observe cooling to happen in about one hour and ice to from under three hours.
Earlier make sure that the thermostat was set to normal mode for freezer and fridge.
However if ice forms in the freezer then observe the fridge for about 24 hours for cooling to continue and the fridge to cut off . If not the auto defrost timer, or the thermostat must be checked. Frost formation without defrosting could block the air flow and so shut the air passage to the fridge. Also the blower fan must work and if this is not working then the fan can be faulty. Also a fault on the control unit is a suspect to non functioning of any one of these components.
If defrost timer works but frost keeps forming check while the compressor shuts if the heaters are working, check continuity of the heaters.
So try this test using a multi-meter on the defrost timer and the thermostat and make your observations so that we come to the solution.
Please check the link below for tips to remove the panels/parts: http://www.espares.co.uk/advice/fridges-and-freezers/a/2
Jan 11, 2013 | Refrigerators
Lg air condition doesn't work when it is cold outside
Sounds like the crankcase heater. This is likely hooked to a temp sensor that is activated when it gets below a certain temp. There is likely a short in the heater and it trips the breaker. The heater keeps the refrigerant warm inside the compressor when compressor not running. Find a different technician.
May 19, 2017 | LG Heating & Cooling
The fridge (kenmore) doesn't seem to be cooling but the freezer (on the bottom) seems to be working fine. Help! :((( Single mom
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Sep 01, 2011 | Refrigerators
I woke up the other day to find my fridge warm and everything in the freezer defrosted. The light comes on when I open the door and what sounds like a compressor starts up every few minutes but seems to...
What you are hearing is most likely your compressor cycling on the overload due to drawing excessive amperage, You will have to have it checked out by a tech
Jun 26, 2011 | Refrigerators
Hi, SAMSUNG SR L39 stops to cool, even if everything seems ok, the fridge is on, the display lit, but food is not cold. Then turn off and turn on the fridge by the power button and everything seems to go...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Apr 20, 2011 | Refrigerators
GE side by side. Freezer cold, fridge kinda cool
Generaly the control board controls everything sometimes you have a bad thermister GE has a help line I beleive it costs 20.00 bucks but you will need a meter and know how to use it and they willl talk you thru the repair .
May 30, 2009 | Refrigerators
Freezer isn't staying cold
What is the solution? What can we do to engage the refrig. again?
Mar 31, 2009 | KitchenAid (KSRD22FKST) Side by Side...
Not getting cool enough
this sounds like a compressor problem. if the outside coils are getting hot (and properly ventilated) but the inside of the unit is not getting cold then the heat is coming from the compressor.
Jun 28, 2008 | Dometic NDR 1292 Refrigerator
Fridge not cooling enough
Check compressor if it is working fine then check temperature thermostat. If they both are good then either your fridge has ran out of gas or the doors are not closing properly.
Nov 09, 2017 | Refrigerators
Freezer and Refrigirator not cooling
You didn't say if the compressor is running or not. If it is and all other things you stated are running then it has a sealed system problem. The sealed system comes with a 5 yr warranty in most cases (check owners manual). If the compressor is not running then listen for a click at the compressor. If you hear the click then I would replace the relay on the compressor. If you need further help I will need the complete model # off the sticker inside the fridge section.
Nov 09, 2007 | Refrigerators
Samsung RS2630SH Side by Side Refrigerator Logo
759 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
