Question about Homelite Mighty Lite Lawn Trimmer
Cant get string carrier assembly off to reload new string
Cant get carrier off
Posted on Aug 08, 2009
String stuck in vaccum cleaner
the question is how did the string get past the filter to get to the motor
vacuum motor units are sealed so consider a new unit
Feb 22, 2018 | Vacuums
I cannot reload with string
Please give more details.What you want to reload with strings. Also give exact brand and model number. Also give some details about the problem.Are you replacing any part or want to remove any part. Please keep updated with details.Thanks.Helpmech.
Jun 04, 2011 | Garden
I bought the phone from a friend and he forgot the password to it so i now have no access and cant use it
Reload the Operating system for the phone that will wipe out all memory on the phone and give it a complete new start for you, contact your carrier for specific steps on how to install software
Sep 19, 2010 | RIM BlackBerry Bold 9000 Smartphone
Echo trimmer srm-230 pull string to start trimmer is stuck. I try pulling on it and it only comes out about an inch.
The pull string is probably tangled up. There are usually vents which enable you to see into the machines pull string assembly. Loosen the fasteners and pull off the cover exposing the pull string. You can unwind and untangle and then it should recoil perfectly. If that does not work continue to dismantle the pull string assembly because you probably have a broken starter pawl which is located on the back of the pull string assembly.
Aug 10, 2010 | Garden
Reloaded string empties and shreds continuously in seconds
It sounds like you may need to replace the head. It is designed to advance and stop, but your's isn't stopping. Try this: Clean the inside of the head and connection to the machine well. Put some graphite inside the spool and where it connects to the machine; be generous with the graphite. Put the head back on with some line properly wound onto the spoo (note arrows on back of spool). With the machine off tap the head on the ground enough to disperse the graphite thoroughly in the head. Now, push the head as though to advance the line, and pull on the line. If it advances a little and stops, it is working. Do this several times to be sure. If you can get it working like this, you're good to go. If not, replace the spool. Even with the new spool, occasionally put some graphite in it to keep the line advance smooth!
Best regards, --W/D--.....Please feel free to rate this solution. Thanx!
Jul 25, 2009 | Black & Decker String Trimmer Cordless 12"...
String won't stop advancing and tangles around the unit
Hi
I would guess that your spring has got lost when you reloaded the string .
check and see if it exists if not put in new one .
Jul 19, 2009 | Homelite Mighty Lite Lawn Trimmer
I need to fix athe pull string on my toro push behind mower. it has an 195cc tecumseh motor. the string broke and i can't find anything on toro about how to fix it without buying the whole assembly.
remove bolts from cover and remove the cover. Should be able to access the assembly for the pull rope. Go to a local mower repair shop buy some new line. The old line should just be knotted up on the spring loaded wheel in there. You put a new piece on put in a new knot, put some turns on the assembly to basically wing the spring so it snaps back when pulled, put line through whole and attach to pull handle.
Jul 11, 2009 | Garden
Cant get the new string to go thru holes help cant find the book
This string comes in a number of diameters, it sounds like the string you chose is just too large for the holes. Take your trimmer to the hardware store and select a string that fits in the hole.
Jul 07, 2009 | Troy Bilt Tb70ss Gas Trimmer
Hourglass and no SMS
You may need to reload the Blackberry software.  This can be downloaded to a PC from RIM.  You will need to find your carrier and download the specific operatign system that your carrier and mobile device uses.
Jan 20, 2009 | RIM BlackBerry ® 8830 Cellular Phone
Homelite Mighty Lite Lawn Trimmer  Logo
177 people viewed this question
Top Homelite Garden Experts
Jim Parker
Jim Parker
roeb
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
