Question about Plantronics CS55 Wireless Headset
I need a manual for a CS55 Wireless offcie headset system
GOOD Morning, with all my clutter, i misplaced the manual for my CS55 Wirless Office Headset System. I need instruction for the system
    President:
  • 1,734 Answers
I did not found it on a quick internet search. So maybe ask a manual research service. They will find most manuals.
Posted on Jul 23, 2009
Plantronics CS55 Headset
Office was wired that way i have one tried several ways to use it without the lifter did't work had to buy a lifter the next problem is the phone not all will work Cisco uniden will work good
Jun 18, 2014 | Plantronics CS55 Wireless Headset
I was given a CS55 Plantronics head set. Looking for directions to set it up
If you click on the following page:
Towards the bottom of the page, click on the tab labeled ADDITIONAL INFORMATION. Within that section, you will see PLANTRONICS CS50/CS55 INTERACTIVE USERS GUIDE to click on. This will help you visually see how to setup and start using your CS55.
Good Luck from Headsets Direct!
Jun 15, 2011 | Plantronics CS55 Wireless Headset
We have numerouse CS55 headsets that keep cutting out when speaking on the phone. Choppy sound, missing parts of words etc. Intermittent, will be good for 5 -10 minutes, then bad again.
The first thing to try is resetting the CS55. We hear this a lot and once reset, it usually takes care of the problem. It's equal to a ctrl+alt+del on a computer. Click on the following for detailed instructions and photos:
How to Reset your Plantronics CS55 Wireless Headset
Apr 13, 2011 | Plantronics CS55 Wireless Headset
Plantronics CS55. When using the wireless headset
Echo is usually caused by the transmit (speak) level on the unit being set too high.
1. First, try lowering the volume of the telephone. If you still hear an echo, adjust the volume of the headset itself.
2. The master transmit controls of the headset are the ABCD switch settings on the bottom of the base. A is the lowest and D is the highest setting.
3. You can fine tune this setting with the plus (+) and minus (-) buttons on the back of the charging base.
4. If this doesn't fix the echo, try moving the configuration dial on the left side of the charging base. The recommended setting for most phones is 1.
Jul 10, 2009 | Plantronics CS55/HL10 Wireless Office...
I am getting feedback and an echo in my Plantronic CS55 wireless
Had similar issue.
This how I fixed it
1) set bottom mic to A
2) set dial on the side of CS55 to "Setting 1" most typical
3) set sound lever on the back to "1"
4) played with mic control on the back until quality became sufficient
Jun 26, 2009 | Plantronics CS55/HL10 Wireless Office...
Plantronics CS55/HL10 Wireless Office Headset System with Lifter won't lift headset
You may need to re-subscribe the headset.
NOTE: Before re-subscribing the system make sure the IntelliStand switch (on the right side of the charging base) is in the "_" position and NOT the "=" position.
To Re-Subscribe:
The headset and the base unit are supplied subscribed to each other. However, if you wish to use a replacement headset with the base unit (or if you lose your connection to the base unit), then you must re-subscribe as follows:
1. Return the headset to the charging base.
2. Press and hold both the + and - buttons on the back of the charging base until the red light on the front of the base starts to flash.
3. Let go of both buttons. The red light should continue to flash.
4. Press the mute switch (black wheel on the top of the headset) straight down until a green light appears on the headset, then let go of the wheel, and the light should remain on the headset.
5. Resubscription is finished when the red light on the base is fully illuminated and the green light on the headset disappears.
6. Remove the headset from the charging base lift telephone handset/press headset button if not using a handset lifter. The headset and base should now be connected.
7. If this procedure does not resolve your issue to try a system reset.
Jan 12, 2009 | Plantronics CS55/HL10 Wireless Office...
All of a sudden my CS 55 with plantronics stopped working. It shows that its on but the headpiece isnt charing and also doesnt work. Any ideas why?
If the Plantronics CS55 wireless headset shows that it is on, you have to make sure of the following things.
a. the green LED on the base turns on when you turn the call switch on from the headset.
b. the small green LED on the side of the headset is blinking.
c. the telephone headset is lifted from the cradle.
d. if the headset is not charging and the Amber light on the base does not blink when you place wireless headset on it; trying placing the headset more firmly.
e. If the headset is not charging and the Amber light on the base does not blink even after placing the wireless headset firmly on the charging cradle, you may need to change the battery.
Alternately you can try resetting the Plantronics CS55 wireless headset.
Reset Plantronics CS50, CS60 or CS55 Wireless Headset
If you have problems with the sound or connection of your Plantronics CS50, CS60 or CS55 wireless phone headset, you may want to try to hard reset it using the following steps:
Note: Ensure the IntelliStand switch (on the right side of the charging base) is in the - position and NOT the = position.
1. Press both the call control button and the listening volume/mute button for 5 seconds. When the indicator light blinks release both buttons.
2. Press the call control button again. The talk indicator light will again blink to indicate the headset is back to normal.
3. Disconnect the AC charger from the AC charging jack for 5 seconds.
4. Reconnect the AC charger.
Now give the Plantronics headset a try.
Jan 10, 2009 | Plantronics CS55/HL10 Wireless Office...
Phone doesn't ring in earpiece
Only if you have an HL-10 lifter installed... you will then be able to hear three short beeps in your ear to indicate the phone is ringing.
Jul 31, 2008 | Plantronics CS55 Wireless Headset
Plantronics CS55  Wireless Headset Logo
1,924 people viewed this question
Top Plantronics Radio Communications Experts
LeAnna Mathews
LeAnna Mathews
Level 1 Expert
shaun taylor
Michael Vincent Cruz
Are you a Plantronics Radio Communication Expert? Answer questions, earn points and help others
