Question about Brother Office Equipment & Supplies
I have a Brother 8460N and need to change the speed dial numbers and/or delete. How do I do this?
  • 105 Answers
The fax on my brother MFC-8460N does not work. it does not pick up a dialing tone when sending and on receiving it rings once says receiving bit nothing comes through. Please help
Your modem setting probably is not compabile with the data rate your phone will support.
From the user manual --
If you are having difficulty sending or
receiving a fax due to possible interference
on the phone line, we recommend that you
adjust the compatibility setting to reduce the
modem speed for fax operation
Press a or b to choose Basic or
Normal (or High).
Basic cuts the modem speed to
9600 bps. Unless interference is a
recurring problem on your phone
line, you may prefer to use it only
when needed.
Normal sets the modem speed at
14400 bps.
High sets the modem speed at
33600 bps.
Press OK.
Press Stop/Exit.
The other thing to consider is do you have tone or pulse dial service from your telephone company?
Mar 23, 2011 | Brother MFC-8460N All-In-One Printer
I need to set up a number on speed dial and delete one.. i have a brother intellifax 4750e
Storing Speed Dial Numbers
1 Press Menu, 2, 3, 2.
2 Enter a three-digit Speed Dial number, and then press Set.
3 Enter a number (up to 20 digits), and then press Set.
4 Enter a name (or leave it blank), and then press Set.
5 Press Stop/Exit.
Changing One Touch and Speed Dial Numbers
If you try to store a One Touch or Speed Dial number in a location where a
number is already stored, the LCD shows the current name stored at that
location, then prompts you to either
1 Press 1 to change the number, or press 2 to exit without changing it.
2 Enter a new number and then press Set.
If you want to erase the number, press Clear when the cursor is to the left of the
digits.
If you want to change a digit, use left arrow or right arrow to position the cursor under the digit
you want to change, then type over it.
3 Follow the directions beginning at Step 4 for Storing One Touch Numbers or
Storing Speed Dial Numbers.
Feb 28, 2011 | Office Equipment & Supplies
How do i change a speed dial number on my brother mfc-7340?
Changes to the contents stored in the address book do not become effective in the stored speed dial numbers in Windows®. Description:If you have made a change to the contents stored in the address book, the speed-dial is NOT automatically updated.
If you change the address book entry, please follow the steps below to store the speed dial number again.
  1. Click on the setup button to open the Brother PC-FAX Setup dialog box.
    Notes:
    You can also access the Brother PC-FAX Setup dialog box by clicking start => Programs => Brother => MFC-XXXX or MFC-XXXX LAN (where XXXX is your model name) => PC-FAX Sending => PC-FAX Setup.
  2. Click the Speed Dial tab.
  3. Select the Speed Dial No. which includes the member or group you made a change in the address book, and then click Clear.
  4. Click the Speed Dial No. you want to program.
  5. Click the member or group you want to store on the Speed Dial again and click Add.
  6. The Speed Dial is now registered with the new entry. Click OK.
If you put the patch below, the message that prompts you to confirm the destination number or address will appear when you send a fax using the speed dial. Also the message that indicates changes in the address book do not become effective in the stored speed dial numbers will appear when storing a speed dial.
  1. Make a temporary folder on your HDD [hard disk drive] as the location to save the downloaded self-extracting file, e.g. C:\brodnt
  2. Please click here to download the patch. (7.07MB)
  3. The Brother End-User License Agreement will appear. If you agree to the terms, click I ACCEPT.
  4. Download the file to the temporary folder created in Step 1.
  5. Once downloading is complete, open the folder and double click PCFAXUPD.EXE.
  6. The installation will start. Please follow the on-screen installation directions.
Trust this is helpful. Please vote. :)
Dec 11, 2010 | Brother MFC 7420 All-In-One Laser Printer
How do I delete speed dial numbers on the Intellifax 2820?
Changing One Touch (For FAX Models Only) and Speed Dial Numbers
If you try to store a One Touch (FAX models only) or Speed Dial number in a
location where a number is already stored, the LCD shows the current name stored there, and then prompts you to either:
1 Press 1 to change the stored number-OR- press 2 to exit without making a change.
2 Enter a new number, and then press Menu/Set.
• If you want to erase the whole number, press Stop/Exit when the cursor
is to the left of the digits. The letters above and to the right of the cursor will be deleted.
• If you want to change a digit, use or to position the cursor under the digit you want to change, and then type over it.
3 Follow the directions beginning at Step 4 in Storing One Touch Numbers
(For FAX Models Only) and Storing Speed Dial Numbers.
Dec 03, 2010 | Brother IntelliFax-2820 Laser Fax
How do I delete a speed dial contact?
Hi
I have put a PDF files on my website for you to download.
Just click on the links it will download for you.
It got all you need to know in this file.
You can read it on site and print it strait off the website or save it to your PC then print it out.
Click LINK= http://www.4all2sell.com/pdf/Brother-DCP-8060-MFC-8460N-Manual.pdf
You will need a adobe reader to see this file If you not got an Pdf reader you can download it off this link free.
http://www.adobe.com/products/reader/
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Mar 05, 2010 | Brother MFC-8460N All-In-One Printer
IntelliFax-4100e
go into menu, arrow over until you see 2. Fax hit set, then arrow until you see 1. one-touch speed dial, then hit set. touch the one-touch button you want to change, then the number 1 to change it, it will display the number, hit clear to delete it then dial the new number hit set and you're done.
Feb 11, 2010 | Brother IntelliFax-4100e Fax
Need help changing the speed dial ID numbers
In order to change #01 to #21 its best just to program the number into #21 slot and then clear the memory for #1.
Start by trying to store a number at a location already used Press Menu/Set, 2 (Fax), 3 (Set Quick-Dial), 2 (Speed-Dial).
Use the dial pad to select the three-digit location (001 – 200) in which you want to erase the number and press Menu/Set.
The screen displays the name or number currently stored there, then prompts you to either 1. CHANGE or 2. EXIT.
Press the Stop/Exit key when the cursor is to the left of the digits. Everything above and to the right of the cursor is deleted.
Hit he menu/set key.
This should save the speed dial number as a blank.
Apr 29, 2008 | Brother IntelliFax-2820 Laser Fax
66 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
