Question about Sony Ericsson W300 Cellular Phone
W300i(Aust.) loss of antennae signal
Moved to a regional area, previously in this area I had some but poor reception. Upon return I have no signal anywhere except on about a 300m stretch of road several kilometers away ! please help. can it be fixed cheaply?
    Brigadier General:
  • 7,752 Answers
Try an antenna booster see if that helps
Posted on Sep 20, 2008
I have a Samsung tv, model # LN32A550P3FXZA. I've been trying to hook up an antenna but so far can't get good reception. Could the problem possibly by my tv tuner? Too old or bad?
Sounds like you're in the fringe area of the antenna. Depending on how far you are from the broadcast antenna, You may have to increase the length of the pole that antenna is on or get an antenna that has a greater range in miles. Digital signals are real picky about antenna aim. If you have a long cable between the antenna and the TV, you might try an inline amplifier.
Oct 19, 2017 | Samsung Televison & Video
No digital TV signal available how do I get it to work
You can try getting a better antenna (especially an outdoor antenna), move the antenna location, or move to an area with stronger television reception.
May 18, 2015 | Televison & Video
Very poor radio reception
FM reception depends upon having a good antenna matched to the radio. What type of radio are you using, and what are you using for an antenna?
May 02, 2015 | Golf
We have a Phillips flat screen tv with an outside digital antenna. We get great reception of certain stations and then poor fuzzy reception on occasion of others that all come out of the same general...
You are in somewhat of a fringe area and subject to the vagaries of proper reception. Hopefully you have a good outdoor antenna mounted as high up as possible. You might also consider adding an antenna amp to the downlead to boost up the signal.
Digital signals are not as strong or robust as analog ones and good reception can be thwarted by tree leaves in the path of the signal to your set!!!!!!!!! You should have as clear a line of sight to the transmitter as possible. Relocation of antenna is also another possibility.
Jun 12, 2017 | Televison & Video
Fm reception for weak stations poor. reception on car radio fine.
If there is no FM Antenna connection you can try to move the power cord to different positions and see if you get a better signal. If not then move the unit closer to a window or try various locations that might have better reception.
Nov 21, 2013 | Sony ICF-CDK50 Clock Radio
Samsung tab keeps dropping wgt624
You are losing the signal? If you move about the area reception will differ. I'm not sure what your question is? May things will cause a signal loss. The device location, device antenna, interference, Wireless Channel, etc. Is the wireless secured? Change NetGear Channels.
Jan 18, 2013 | NetGear : WGT624 108 Mbps Wireless...
Nextar GPS Never acquires GPS Signal
The only thing you can try is the external antenna for this unit.
You could be in an area that has poor signal.
If it where me, I would go to a place that I could return a unit,
I only use garmin, there hand-held unit's are the top rated for
the frequency of getting satellites.
So say you have a walmart, see if you can return a unit, buy a garmin
and see if it get better reception, and if it doesn't then its not the unit.
If it does,sell you old one on ebay.
Feb 12, 2010 | Nextar M3 Car GPS Receiver
!994 Park Avenue FM radio reception poor. AM signal OK
Check antenna connections at radio and antenna assy.. Poor connections will only receive AM and hardly any FM
Apr 06, 2009 | 1994 Buick LeSabre
Plasma TV Reception
Bro the reception in that area of the house must be poor, as you've said. The walls in that area of the house must be too thick, or some part of the house is blocking the signal that the attena emits. You should consider getting an antenna that can be placed outside the house, like on the roof top. Make sure it isn't being blocked by anything, like trees with large branches or whatever.
Jul 21, 2008 | Televison & Video
Lost satellite reception
This problem is not caused by poor solder joints. It's caused by a defective part. We sent a "marked" defective unit to the repair shop mentioned above and upon its return, disamantled the GPS receiver assembly and made the following evaluation:
1. The shop did NOT replace the defective component causing the initial problem in the 1st place. The defective part was STILL in the circuit.
2. The shop placed a wire jumper between the internal antenna and the external antenna port. This type of modification places a +2.5VDC bias on the internal antenna and essentially shorts the internal antenna to the external antenna (when connected), giving unpredictable results. It also affects the circuit impedance and signal strength. This is not the correct way to resolve this issue.
3. The defective part needs to be replaced with a higher rated part. This type of repair returns the unit to full functionality and allows the unit to properly switch between the internal and external antenna as it was intended to do by design
- Jim
SHARCNET-USA
Comments: I will aso add, as the part deteriorates, it becomes resistive and can eventually short out and shunt the incoming RF signal to ground......EVEN with the jumper procedure performed by the shop mentioned above.
- Jim
SHARCNET-USA
Jun 03, 2008 | Garmin nuvi 200W GPS Receiver
Sony Ericsson W300 Cellular Phone Logo
134 people viewed this question
Top Sony Ericsson Cell Phones Experts
Computer Repairing
Computer Repairing
270rexton
270rexton
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
