Question about Garden
Recoil problem! I've just changed the start cord on my mower but now it won't recoil. The inner of the coil is attached the plastic wheel although the other(outer) end of the coil appears to be free. I'm guessing this is the problem and the reason it won't recoil- each time I pull, I get more and more cord which cannot go anywhere! How do I fix this- I cannot see anywhere for it to go!
    Scholar:
  • 173 Answers
You will probably find, that the spring inside, is not being stopped by the lug.
Usually, these do fail,..
Even when made from metal!
You will more than likely, have to replace the broken part.
Hope that helps you.
Posted on Jul 23, 2009
Rewind starter cord
How To: Rewind a Recoil Rope (Fix a Broken ... - YouTube
? 2:52
https://www.youtube.com/watch?v=J0KJuqsJJ_k
Feb 16, 2012 - Uploaded by Champion Power Equipment
How To: Rewind a Recoil Rope (Fix a Broken Recoil Rope) .... Back off until rope hole in pulley lines up ...
How to Repair a Small Engine Recoil Starter - YouTube
? 4:49
https://www.youtube.com/watch?v=tmo6oYOJJ4U
Jul 15, 2011 - Uploaded by eReplacementParts.com
How to Repair a Small Engine Recoil Starter ... Would like to now use the pull cord on the mower but it won ...
Nov 28, 2015 | Garden
What to do when craftsman mower pull cord won't recoil?
Sounds like the spring inside the recoil has either broken or let go so it won't recoil. If you are lucky it could be the wheel that the cord goes on is seized or stuck. You can take the recoil off most mowers by taking out two or three screws and lifting it off the engine. They can be repaired but it takes time having to be careful the spring won't spin and hurt you. I have even taken a recoil off another engine and if the holes for the little screws don't line up just drill little holes beside the old ones and reinstall the little screws.
I even used a 18 volt cordless drill to crank the engine using the bolt on the fly wheel and the right size socket. Leaving the recoil off You have an electric start that way.
Aug 30, 2014 | Craftsman 21" 190cc Rear Bag High Wheel...
To much slack in pull cord on poulan pro push lawn mower
u need to remove the recoil assbly and restring.remove recoil and cut not out of string.remove line.rotat the coil assbley counter clockwish till spring presser is tight.hold it in place and reinstall cord threw eye whole tie new not and let off recoil slow.slack should go away.
Aug 19, 2013 | Poulan Pro PR550N22SH 22Inch Briggs ...
Lawn mower recoil spring
Remove mounting nuts, pry recoil off fly wheel. Purchase new recoil assembly at mower repair store.
Jul 10, 2013 | Garden
How to replace starter rope
Read through this completely before doing any work.
1) remove the plastic cover on the engine. Usually a couple of phillips head screws.
2) remove recoil housing. It will either come off as just the round part on top the sheet metal shroud or the entire shroud may need to be removed. You will need a rachet set for this.
3) remove any remaining pull cord from recoil pulley. You can do this by pulling the cords knot from the inside of the recoil pulley.
4) rewind the recoil in the direction of starter rope pull. Place a screwdriver once you have 7-9 turns made. The screwdriver goes between the spokes of the recoil pulley and the spokes on the recoil shroud. Align the hole in the pulley with the hole in the cover where the cord comes out. Then drop in the screwdriver.
5) get a new length of cord. *(check the old one for overall length as a guage) after melting and pointing the end of the cord push it through the outer hole till it shows at the inner hole.
6) tie a knot in the pulley end of the cord so it can be pulled back out and then remove the screwdriver while pulling tension on the recoil cord so it doesnt get totally sucked into the recoil. You should end up with about two feet of free cable dangling so you can put on the t handle and place it through the eyelet on the mower handles right side *(from operators position).
7) put the recoil cover back on the mower and try a slow pull to see if the cord has enough travel. If it doesnt, you will need to put more winds on it. Which might require more cord as well. You may want to go online and lookup your mower to see if you can find specs on how long the cord should be.
You should wear cut resistant gloves and eye protection at the very least while doing this procedure. Good luck and be careful!
Dec 04, 2011 | Toro Power Lawn Mower
When pulling cord to start mower there was a click sound and the cord would not rewind
Remove top cover to your engine with all other attachments. Be careful because loosening this part will most likely recoil the cord. The recoil is in the top of the cover. Turn cover over and put some oil on all the mechanical parts at center of unit. Pull the cord till your satisfied it has been lubricated.
Replace top cover along with all attachments, and you should be ready to mow. GOOD LUCK.
Jul 25, 2011 | Garden
Pull string won;t recoil
The recoil spring has broken. These are available at any lawn mower parts supply store. The process of changing the spring is tedious but can be done by anyone with average mechanical ability. If you removed the recoil assy (and air shroud if it is riveted on) and took the assembly to a Lawn Mower Repair shop usually they will change out the spring while you wait. If you can't get the recoil assy off take the mower with you to the repair shop. Again most shops will fix it while you if wait but if they are very busy usually they are serviced within 24 hours.
If you do attempt this yourself check in the tips section of FixYa on how to change the recoil stater rope after replacement of the spring.
I highly recommend you replace the pull rope at the time of the recoil spring replacement.
One final note... there is a possibility that the pull rope spool has been damaged where the spring attaches.
Thanks for using FixYa,
Kelly
Apr 28, 2010 | Mtd 22" Yard Machine Push Mower
Broken recoil start on tecumseh 6.5 hp
broken cord? remove bolts holding recoil housing.lift housing straight up,you may have to wiggle it a bit.turn housing over,remove any cord thats left,note how & where it connects to the spool.wind the spool [and consquently the spring under it]in the direction the cord would turn it as pulled when starting.hold spool tight.thread new cord through hole in housing.let spool turn back just enough to attach new cord.hold cord & housing,let spring "re-coil" cord slowly.check for smooth operation.replace housing.you may need to pull cord slightly to align 'square' shaft w/hole in spool.only after you are satisfied with the operation of it adjust length of cord by pushing excess cord through the handle,tie a new knot,then cut off excess,if any.
Sep 21, 2009 | Garden
Have a recoil pull start mower that won't recoil
the starter clutch probably needs cleaning. It is located right on top of the fly wheel. Pull the the pull rope housing off and you can see it
Apr 04, 2009 | Poulan "" Push Mower
Garden Logo
65 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
