Replaced convergence IC's, auto converges great, but after turning off set, I have to auto converge again. ???
  • weiry1 Jul 23, 2009
    the model tv is JVC AV-65WP74
    I can't seem to enter manual convergence. Do you have a procedure or a suggestion.
  • 3,037 Answers
The convergence board still has a problem most likely even though the picture looks good. I would start looking for a faulty capacitor that will have to be replaced. Let me know what you find and how this turns out.
Benjamin
Posted on Jul 23, 2009
    President:
  • 2,777 Answers
What make / model TV are we talking about here? Let me know and I can help you figure out why it's not saving the configuration.
Thanks
Tim
  • Tim Grayson
    Tim Grayson Jul 23, 2009
    Ok, have you tried doing a manual convergence with this set? I've seen it where you do an auto converge and then turn it off to come back later and the manual convergence settings overwrote the auto settings. Make sure you go into the manual convergence and try to set it there first. Then you can do an auto converge after that and usually it will apply it to the manual convergence settings. If you don't do the manual first for some reason it won't take many times.
    Give that a try and let me know
    T
My lenses are misadjuted. how do i readjust them?
hello, do you mean the colours are all mixed up if the is down to the convergance ic try going in to the menu click on convergance setting try auto set up. but if this don't work your convergance ic may be faulty will need to be replaced hope it help
regards
shaun
Dec 25, 2010 | Toshiba 57H81 57" Rear Projection...
JVC AV-48WP30 convergence drifting after IC replacement
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony,Samsung, JVC, Philip Magnavox, Panasonic, Akai, Pioneer, Hitachi, Zenith, and others. You can get a convergenece repair kit wiith instructions from the links below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted or warped
  • No Audio/Video - makes a chirping sound.
Problem #2
Another common problem is dull or washed out video.
Your TV may have one or more of the following symptoms....
  • Dull looking picture
  • White looking picture
  • Halos around objects
  • Red/Orange looking picture
You can see some more examples and find a fix here
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Mar 16, 2010 | JVC AV-48WP30 48" Rear Projection...
SAMSUNG HCM4215W Rear Projection HDTV shuts down
Low ohm resistors are open or poor solder connections on the bottom of a convergence IC.
You need to look at resistors in good light with magnifying glass. Bad ones may show as discolored or burnt.
The repair needs someone that has the schematic for the convergence cct, and can replace the burnt resistors or replace the whole convergence board.
http://calgaryconvergencerepair.weebly.com/index.html
If you are near Calgary, call me, if not, find someone that has done it before, preferably many times.
easyab
Aug 12, 2008 | Samsung HCM4216W 42" Rear Projection...
Zenith R49W36 Rear Projection TV Convergence IC problem
Had the same problem with my Zenith TV. Convergence was all out of whack. I purchased a repair Kit from www.TvRepairKits.com. The kit had all the parts and simple step by step photos of the repair. I cant thank them enough for making this possible . At first the repair did not work so I emailed them and within an hour they told me to check two other items. Sure enough they were right! The set is now working perfectly.
Thanks Guys, I will spread the word.
Louis
Jul 27, 2008 | Zenith R49W36 49" Rear Projection HDTV
Red Convergence on JVC AV- 65WP74
convergence amp ic bad
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Sony Convergence
http://www.techlore.com/blog/entry/19694/Sony-Convergence-Repair-My-Sony-TV-has-a-distorted-picture-/
http://www.techlore.com/article/19631/Sony-Convergence-Procedure/
Jan 28, 2008 | JVC AV-65WP74 Rear Projection Television
Sony HDTV Convergence Issue
No, You will not solve the problem with only changing the convergence IC, associated resisters may also be required.
Beside of that, after spending time to get parts and replace the ICs, you need to make and adjustment the color lines (about 14 lines)
This adjustment without experience will take you about 3 to 4 times and 4 hours each to get thing right (if you areskillfull, most of people failed this adjustment).. The total time spend for this problem would take you full 24 working hours.
I successfully adjusted one set of my big TV (95%, need more more round)), on another set one I failed.
Nov 30, 2007 | Televison & Video
Samsung 52" rear Projection TV Convergence Problem
Replace both STK392-040 convergence IC's with OEM or better
quality = I use Panasonic with great success. They are soldered
in and requires at least PCB removal or perhaps entire chassis.
Please post response if you need more help...................T
Sep 03, 2007 | Televison & Video
Right side convergence
A convergence IC has burned out. If I remember correctly, those Pioneer sets have one huge convergence IC, but that IC only has 5 channels in it so they use another smaller dual STK IC and one half of it is used for the 6th channel and the other half is the vertical output. Look on the convergence board, find the blue convergence jack, identify the blue horizontal channel, follow the traces and replace the IC handling the blue horizontal channel.
Aug 28, 2007 | Pioneer SD-P50A5-K 50" Rear Projection...
Auto convergence not working 142cm LG rptv
If the colors will not line up in one corner of a standard projection set, it usually means that one of the convergence output IC's has burned out and needs to be replaced. This is very common. If you do not have experience replacing parts and soldering PC boards, then the defective IC should be replaced and the convergence circuits realigned by a qualified tech familiar with convergence circuits in projection sets.
Aug 26, 2007 | Televison & Video
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
