It could be one or more problems. The filter is likely clogged. It should be replaced at least once per year if you can find one. Clogged filters greatly reduce airflow which will cause dirt and debris to build up in other areas of the vacuum eventually causing it to have no suction. If you get the suction working make sure to install a new belt if using it on carpeted floors.
SOURCE: vacuums normally but no suction through the wand
Keep cleaning ... there is a clog somewhere.
Thanks for your intrest in FixYa.com
SOURCE: Model Fantom Thunder (quite old) still runs,no
sounds like you have something stuck in the air way you can flip the vac over and they had trap door you open to clean it you may have to use coat hanger straigten out with a small hook on the end
SOURCE: I was give a Fantom
You may have a plugged filter. If it has a rotating bar at the floor it may be plugged with hair etc..
