Question about Nokia Cell Phones
My handset restarts when the message memory is loaded
My nokia 2626 handset restarts regularly after 10 mins.
I intend to transfer all my messages from nokia 2626 phone memory to simcard
I'm sorry to say but there is no way to do that although you can transfer sim messages on to the phone memory
Mar 06, 2011 | Nokia 2626 Mobile Phone
A general: memory full close some applications and try again appears everytime i send a message
Hi....
Try the following... *Restore your Phone once (To restore Goto Menu>Settings>Restore Factory Settings>OK(default security code is 12345)
*Clear some memory of Phone and Memory
*Scan your Phone and Memory
If problem persists you need flash your phone
(formating delete all data including messages,contacts,etc... So i suggest you to back up all the files before formatting You can back up file using Nokia PC suit) To back up your files *Install the Nokia PC suit *open Nokia PC suit >Select Back up
To restore Backed up data *Open PC suit>Tools tab>Restore>Select Restore>select a restore point(restore point is file in which all data's are saved)>Ok and wait for 5-10 mins.
To flash you need
*USB cable compatible with your handset *A Computer *Nokia PC suite of your handset *Internet connection(Min speed 1Mbps) *Nokia software updater(you can download by using Nokia PC suit)
To flash *Install the PC suite *Connect to USB *Open the PC suit *Select UPDATE PHONE SOFTWARE(dowload the Nokia Software updater by selecting this option) *Install the "NOKIA Software Updater"*Select Update**....(It takes 10-30 Mins)
**Please don't disconnect while updation process
I hope this helps... Thank you have a nice day
Feb 03, 2011 | Nokia E63 Cell Phone
Actualy i want to format my 3110c mobile phone memory but i can't.please give me solution
Normally Nokia and other symbian devices can be reset with *#7780# or *#7370#. if not you should find master reset in the general settings.
Feb 03, 2011 | Cell Phones
I put a security code .. im truying to unlock my nokia E5 i get : code error .. what can i do ? i need to reset my security code please .. thank you a lot
Hi iba bob...
You can unlock by 2 methods 1)you can get master code from
http://www.unlock-zone.com/
or
http://www.nokialockcode.com/mastercode.php
and
superunlockcodes.com/unlocking-services/rs12wp6/ (You have to pay for these)
2)You can flash(format) your handset to reset code 12345
To flash you need
Try the follwing.... *check whether your phone or memory card memory full or not If memory is full clear some memory *Scan with a updated version of updated antivirus If problem persists you need to flash your handset
To flash you need
*A Computer
*PC suite of your handset
To flash
*Connect to USB
*Open the PC suit
*Select UPDATE PHONE SOFTWARE(dowload the Nokkia Software updater by selecting this option)
**Don't disconnect while updation process
Than you have a nice day...
Jan 31, 2011 | Nokia E5 Cell Phone
I cannot open messages from Inbox folder. Only able when I open it directly thru new message key shortcut shown on home page/screen once received. So I only get to read the message once and not able to...
Hi justinekaizz.......
You Problem is related to virus attack.
Try the following.
*Restore your phone once(To Restore Go to Menu>Settings>Restore Factory Settings>Ok(Default Security code is 12345)>Yes(It takes 1-2mins).
*Scan your phone and memory card from a updated anti virus.
At Last.... if Problem persists.....
You need to flash(format)your phone.
Formatting resets the security code to 12345
(formatting delete all data including messages,contacts,etc... So i suggest you to back up all the files before formatting You can back up file using Nokia PC suit)
To flash you need
*A Computer
To flash
*Connect to USB
*Open the PC suit
*Select UPDATE PHONE SOFTWARE(download the Nokia Software updater by selecting this option)
Jan 31, 2011 | Nokia E63 Cell Phone
My samsung sgh m-200 mobile problem 1Chalte Chalte hang ho jata hai.2. auto restart hota rahta hai.plz solv my problems thanks
For this you need to scan your handset and memory from a updated antivirus
if problem persists you need to flash your phone
To flash you need *USB cable compatible with your handset *A Computer *PC suite of your handset *Internet connection(Min speed 1Mbps)
To flash *Install the PC suite *Connect to USB *Open the PC suit *Select UPDATE PHONE SOFTWARE(dowload the Nokkia Software updater by selecting this option) *Install the "NOKIA Software Updater" *Select Update**....(It takes 10-30 Mins)
To flash you need *USB cable compatible with your handset *A Computer *PC suite of your handset *Internet connection(Min speed 1Mbps) *Software Updater
To flash *Install the PC suite *Connect to USB *Open the PC suit *Select UPDATE PHONE SOFTWARE *Install the "Software Updater" *Select Update**....(It takes 10-30 Mins)
Thank don't forget to rate
Jan 28, 2011 | Samsung Cell Phones
Music player does not open
Jan 27, 2011 | Nokia 3110 Cellular Phone
I have nokia 2690 handset. but i want to copy my inbox messages to memory card or pc. so can u give some inputs to solve my problem
sir in nokia 2690 phone.in the inbox message right click and mark the messages u want to copy.and then copy the message to the simcard [not in the memorycard will not accepted pc also not accepted] u copy the message in simcard
Nov 18, 2010 | Nokia 2626 Mobile Phone
How to restart nokia 2626
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} This is what happens.nokia 2626 hangs, gets switched off and restarts randomly. More often, it restarts around 3 times or so and then gets switched off.
Possible Causes and Solutions Cause 1 - Phone Memory Full - nokia 2626 mobile phone has got 9MB of internal memory.
Solution - Keep the free space between 350 to 500 KB, so as to keep things running smoothly on your phone and prevent nokia 2626 from restarting.
Cause 2 - Changing Themes - Some people have reported that the phone restarts automatically when they try changing display themes on the phone.
Solution - Don’t get your phone loaded with too many themes downloaded from the internet or atleast, don’t switch themes frequently. These themes, mind you, also load up things into your already falling nokia 2626 phone memory.
Cause 3 - Memory Cards - Some people have reported that nokia 2626 restarts due to some issues with the memory card.
Solution - Remove the card, get it formatted and then insert it back and then restore factory settings. This just might solve the issue.
Cause 4 - Transferring data via Blueooth / USB data cable (or) Updating Music Library - A few people have reported that their nokia 2626 mobile phone restarts when updating the music library.
Solution - Don’t try updating of music library frequently or don’t often transfer data in/out of your nokia 2626 phone.
Cause 5 - MP3 files
Solution - This may seem dumb, but consider converting all your MP3 music files to WMA and then store them on the memory card. Some users suggested this
Good luck
Jul 09, 2010 | Nokia 2626 Mobile Phone
What can i do to stop freezing in nokia 2626. if i power on my nokia 2626, the phone hangs after some seconds and i don't know what to do
Nokia models starting with 2 series are generally very slow. Once it is started it will be back to normal. It will take about 3 minutes to start up. Please wait during that period. Once it is started you can use everything except messaging, which will take another 10 more minutes to get ready. Till then it will show the message "Message storage memory not ready".
Jul 05, 2010 | Nokia 2626 Mobile Phone
Cell Phones Logo
37 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
