Epson STYLUS CX3900 All-In-One InkJet Printer Logo
Posted on Jul 23, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
CX3900 - Configuration
Hello,Is there a way to enter the configuration of the printer as I could do when I originally bought my CX3900.I would like to set things like 'Economy', only black, no color.Thank you.- MacBook- Leopard 10.5.7
Anjazmoro Wicaksono
Level 3:
  • Epson Master 511 Answers
  • Posted on Jul 24, 2009
Anjazmoro Wicaksono
Epson Master
Level 3:
Answers
511
Questions
0
Helped
269434
Points
1600
Update driver refer to your OS. Find updater at Epson website. Some function and setting do not work with compatible driver.
How to print meter reading from hp laserjet pro400
Configuration page denotes total gape count..
Press menu button...scroll to information..enter...scroll to configuration page...enter..
How do you retrieve the meter reading on the HPLJP2035n?
enter the menu using the menu button press down till you get to information press enter move down to configuration and press enter (tick) select configuration page and print look for the term Engine Cycles ( this is how 'old' the machine is in copy count terms)
What is the default password for cisco
There are two main methods to return a Cisco router to its original factory defaults. These two methods are described below.
Method 1
1. uses the config-register 0x2102 command in global configuration mode.
2. Check the configuration register on the router by issuing the show version command.
3. The configuration register setting is displayed in the last line of the show version command output and should be set to 0x2102. If this is not the case, enter the config-register 0x2102 command once in global configuration mode.
router#configure terminal
router(config)#config-register 0x2102
router(config)#end
router#
4. If the show version command is issued again, the same line in the command output will have '(will be 0x2102 at next reload)' appended to the current register setting.
5. Erase the current start-up configuration on the router with the write erase command.
Reload the router with the reload command. When prompted to save the configuration, DO NOT save.
router#reload
System configuration has been modified. Save? [yes/no]: n
Proceed with reload? [confirm]
Once the router reloads, the System Configuration Dialog appears.
--- System Configuration Dialog ---
Would you like to enter the initial configuration dialog? [yes/no]:
The router is now reset to the original factory defaults.
Method 2
1. uses the config-register 0x2142 command in global configuration mode.
2. Enter the config-register 0x2142 command in global configuration mode.
router(config)#config-register 0x2142
This causes the router to ignore the start-up configuration on the next reload. If a show version is issued, the last line in the command output will have '(will be 0x2142 at next reload)' appended to the current configuration register setting.
3. Reload the router using the reload command in enable mode. It is not necessary to save when prompted to save the system configuration.
router#reload
After the router has reloaded, the System Configuration Dialog appears.
4. Enter no to the question "Would you like to enter initial configuration dialog?"
5. Change the configuration register setting to 0x2102 by entering the config-register 0x2102 command once in global configuration mode.
6. Issue the write memory command in enable mode to overwrite the existing start-up configuration with the current running configuration.
7. Reload the router with the reload command in enable mode.
Once the router reloads, the System configuration Dialog appears.
Note: The configurations below are stored in ROMMON, and cannot be reset to Factory Default Settings by the write erase or config-register 0x2142 commands.
warm-reboot
memory-size iomem <not default>
Help! I'm trying to print a configuration page on a WorkCentre M20i
Hi, you can print a configuration page on the M20i by following the steps below:
- Press the Machine Status button - Select Reports, then press Enter - Select Connect Page, then press Enter
The configuration page will print out. For configuration page instructions for other copiers or printers, visit the How to print config pages website.
3helpful
2answers
What are the options on HP laserjet 4250 menu, i want the one to enter IP configuration
Follow these steps
Menu
Configure Device
I/O
Jet Direct Menu
TCPIP
Configuration Method
1helpful
Stylus CX3900 won't turn on
Do you used ORIGINAL epson cartridges? I used false ones, the yellow one exploded (I'm NOT kidding) inside the printer, and it died. Too, may cause errors on the printer's motherboard, on each cartridge, have a chip who don't metter the ink inside, calculate an extimated value. When you put a false cartridge, the chip may send wrong/corrupted data to the printer system, making it dizzy, and stop working... Epson products have short lifetime, i rarely saw an epson printer go more than 6 years, the most ones die on the first year. Is what i know, good luck.
2answers
Cannot re-set network configuration.
Try 6482 or MITA as password
Try leaving password box blank
Try entering the IP address in the web browser and configure there. The firmware will have to flashed if this doesn't work.
Kyocera is pretty picky about resets. You might have to phone them.
1800-GET-MITA
3helpful
Counter info print out
Hi Beadworker,
This information can be found by printing a configuration page from your printer. Follow these steps to print out a configuration page.
Printing a Configuration Page
You can print a configuration page from the printer’s control
panel. Use the configuration page to view the current settings,
to help troubleshoot problems, or to verify the installation of
optional accessories, such as memory or an optional tray.
To print a configuration page:
1 In ready mode, press the Menu button on the control
panel until you see “Information” on the bottom line of the
display.
2 Press the Enter button to access the menu.
3 Press the Enter button when “Configuration” displays
on the bottom line.
A configuration page prints out.
Print out counter info
Hi Beadworker,
display.
on the bottom line.
1helpful
Epson STYLUS CX3900
hello lt-c- clarke
you can find the driver form epson here click you o/s and download them to pc.
Epson cx3900
riz.
Top Epson Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
NH TECH
Level 1 Expert
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
