Fax machine puts out extra blank pages with each incoming fax, & how do you turn off the key tone?
  • 3 more comments
  • jshelton669 Aug 10, 2009
    MinoltaFax 3800. Also, I want to turn the key tones off on it????
    Thanks
  • Nike Merritt May 11, 2010
    what kind of fax, make and model? They all program differently
    what brand and model no?
  • Norman  J Weimar Jr
    Norman J Weimar Jr May 11, 2010
    What model?
    What model?
  • 76 Answers
You must let the seperation pad get cleaned or you need a new pad. If you can tel me the model then i can help you.
Posted on Oct 08, 2009
Hp officejet 6500 instructions for receiving a fax? Thanks
You can receive faxes automatically or manually. If you turn off the Auto Answer option, you must receive faxes manually. If you turn on the Auto Answer option (the default setting), the device automatically answers incoming calls and receives faxes after the number of rings that are specified by the Rings to Answer setting. (The default Rings to Answer setting is five rings.)
If you receive a legal-size fax and the device is not currently set to use legal-size paper, the device reduces the fax so that it fits on the paper that is loaded. If you have disabled the Automatic Reduction feature, the device prints the fax on two pages.
NOTE: If you are copying a document when a fax arrives, the fax is stored in the
device memory until the copying finishes. This can reduce the number of fax pages stored in memory.
This section contains the following topics:
• Receive a fax manually
• Set up backup fax reception
• Reprint received faxes from memory
• Poll to receive a fax
• Forward faxes to another number
• Set the paper size for received faxes
• Set automatic reduction for incoming faxes
• Block junk fax numbers
• Receive faxes to your computer (Fax to PC and Fax to Mac)
When you are on the phone, the person you are speaking with can send you a fax while you are still connected. This is referred to as manual faxing. Use the instructions in this section to receive a manual fax.
NOTE: You can pick up the handset to talk or listen for fax tones.
You can receive faxes manually from a phone that is:
• Directly connected to the device (on the 2-EXT port)
• On the same phone line, but not directly connected to the device
NOTE: The automatic document feeder must be empty to receive a fax. If there are documents in the ADF, then the device will not be able to receive incoming faxes.
To receive a fax manually
1. Make sure the device is turned on and you have paper loaded in the input tray.
2. Remove any originals from the document feeder tray.
are documents in the document feeder, then receiving the fax will be
unsuccessful.
3. Do one of the following to answer a fax manually:
• Set the Rings to Answer setting to a high number to allow you to answer the
incoming call before the device answers.
• Turn off the Auto Answer setting so that the device does not automatically
answer incoming calls.
4. If you are currently on the phone with the sender, instruct the sender to press Start on their fax machine.
5. When you hear fax tones from a sending fax machine, do the following:
a. Press START FAX Black or START FAX Color on the device control panel.
b. When prompted, select Fax Receive.
NOTE: Depending on your country/region, the device might receive the fax
automatically when you hear fax tones from the sending fax machine.
6. After the device begins to receive the fax, you can hang up the phone or remain on the line. The phone line is silent during fax transmission.
Jan 30, 2011 | HP 1250 Plain Paper Thermal Inkjet Fax
How do I receive faxes with the 240c
Manual mode turns off all automatic answering functions unless you are using the Distinctive Ring feature or you are using an external answering machine on the same line as the Brother machine.
*Distinctive Ring is a function of your Brother machine that allows a person with one line to receive fax and voice calls through two different phone numbers on that one line. Brother uses the term "Distinctive Ring," but telephone companies market the service under a variety of names, such as Custom Ringing, Personalized Ring, Smart Ring, Ring Master, Ident-a-Ring, Ident-a-Call, Data Ident-A-Call, Teen Ring, SimpleBiz Fax & Alternate Number Ringing and BT Call Sign.
  1. Setting the Receive Mode
    1. Press Menu.
    2. Press the up or down arrow key to select Initial Setup.
    3. Press OK.
    4. Press the up or down arrow key to select Receive Mode.
    5. Press OK.
    6. Press the up or down arrow key to select Manual.
    7. Press OK.
    8. Press Stop/Exit.
Receiving Faxes in Manual Mode
  1. Lift the handset of a telephone that is on the same line as your Brother machine.
  2. When you hear the sending machine's fax tones (short beeps that occur at regular intervals), do one of the following:
    • If the telephone you answered is near your Brother machine or connected to its EXT jack(socket), press Black(Mono) Start or Color(Colour) Start.
    • If the telephone you answered is not connected to or near your Brother machine, press *51 (*91 for New Zealand) on its dial pad.
  3. Your Brother machine will produce receiving tones.
  4. Replace the telephone handset. Your Brother machine will begin to receive the fax.
< Easy Receive (Fax Detect) >
The Easy Receive (Fax Detect) feature allows you to receive faxes in Manual Mode by simply lifting the handset of a telephone that is on the same line as the Brother machine. Your Brother machine will automatically generate fax receiving tones, at which point you can replace the telephone handset and wait for your fax to be received and printed.
Your Brother machine's Easy Receive (Fax Detect) feature is turned ON by default. To adjust your Brother machine's Easy Receive (Fax Detect) setting, please follow these steps:
  1. Press Menu.
  2. Press the up or down arrow key to select Fax.
  3. Press OK.
  4. Press the up or down arrow key to select Setup Receive.
  5. Press OK.
  6. Press the up or down arrow key to select Easy Receive or Fax Detect.
  7. Press OK.
  8. Press the up or down arrow key to select On, Semi or Off. *In some brother machines, Semi may not be in the options.
    If you choose Semi, your Brother machine will only answer an incoming fax if you answer using its handset or by pressing the Hook, Hook/Hold, Hold, Speaker Phone or Tel/R key on its control panel.
  9. Press OK.
  10. Press Stop/Exit.
Note Here are a couple of points to keep in mind:
  • If Easy Receive (Fax Detect) is ON, but your Brother machine doesn't automatically answer the incoming fax when you lift the extension telephone's handset, press *51 (*91 for New Zealand).
  • If you send faxes from a computer that is on the same telephone line as the Brother machine and the Brother machine intercepts the calls, turn Easy Receive (Fax Detect) OFF.
Please post your feedback and Vote if the problem resolved as per your satisfaction.
Jul 14, 2010 | Brother Multi-Function Center MFC-240C...
Machine# 4800mfc With incoming faxes the machine prints 2 pages- the 2ND blank. It wastes one page for everyone it prints. Do you have a solution?
This could indicate that your "paper size" setting is not correct for the paper you are using or the "reduction" setting may not be correct.
Brother support suggests that the "Reduction" value be set to "Auto Reduction" = ON
To set "Auto Reduction" to ON:
1) Press the <Menu/Set> key
2) Navigate up or down to "Fax" - press <Menu/Set>
3) Navigate up or down to "Setup Receive" - press <Menu/Set>
4) Navigate up or down to "Auto Reduction" - press <Menu/Set>
5) Navigate up or down until "ON" appears - press <Menu/Set>
6) Press <Stop/Exit> to return to normal function
I hope this will help with your extra received page problem.
Mar 09, 2010 | Brother MFC 4800 All-In-One Laser Printer
Been receiving blank pages on random incoming faxes. Multiple error codes, but the one I can't find in the manual is code 212. This error code keeps reoccuring along with others.
Press the following keys:
Function
7
monitor key slowly 4 times
* star key
6
scroll down to SHIPMENT SET
set
wait for the machine to reboot.
Jan 08, 2010 | Panasonic Panafax UF-885 Plain Paper Laser...
Incoming Fax is blank
PRESS REPORTS IT WILL PRINT OUT A HELP PAGE LOOK AT THE SUB MENUE ON THE HELP PAGE MENUE SELCTION 3 FOLLOW THE PROMPT TO TURN ON THE RECEIVE OR IT MAY SAY EASY RECEIVE . GOOD LUCK BROTHER TECH / I HAVE THE SAME MACHINE AT HOME GOOD LUCK
Dec 04, 2008 | Brother IntelliFAX 4100 Laser Fax
Won't send faxes
did you put the originals page(s) in the machine FIRST to fax, then enter the number then press start?
If you enter the phone number 1st BEFORE putting your originals in the feeder, the machine thinks you want to make a copy.
The FAX Mode is the setting for incoming faxes.
Try that and let me know if it works.
There should also be a button called "Hook" or "speaker" or something that you hit and you will hear the dial tone.
Once you hear the dial tone, you can dial the number, (make sure the pages you want to fax is in the feeder.
Once you hear the fax high pitch noise, hit the start button.
Hope this helps.
Let me know if it does and also remember to leave a feedback and rating if I have helped you.
Thanks and good luck.
Mac =)
Feb 19, 2008 | Lexmark F4270 Plain Paper Inkjet Fax
67 people viewed this question
k24674
jasbo
jasbo
