Question about Sanyo Televison & Video
Remote control will not turn tv on or off?
I programmed my 6 in 1 remote control and it changes the channels. It does not turn the tv off or on and adjust the channels. Can anyone give me some advice? it is a greenbrier/ecircuit 6 in 1 universal remote control...silver. thanks
    President:
  • 1,734 Answers
You would need the user manual and the specific remote code for your TV to get this work properly. Just send the model numbers of TV and remote to http://manualfox.com/remote.htm and they will come back with a solution.
Posted on Jul 23, 2009
  • 3 Answers
Yeah the six in one greenbrier is iffy.. on one tv all the buttons will worked as allocated and on other tv the up and down channel will set sleep timer or somthing.. its wat u get for a dollar store remote.. i lost my manual will anyone post the greenbrier yv codes for the sanyo ...plseeee
Posted on Nov 15, 2011
I programmed my dish network remote to turn my tv on and off,and after I programmed it I cant change the channels on the satellite it just controls the tv. The remote has a 21.0 on the back of it and my tv...
You need to try a different code,505,506,516,523,526,566,573,612,627,647,652,653,654,655,656,658,659,664,665,667,669,670,679,680,704,717,730,738.....hope this was helpful....
Apr 25, 2010 | DISH Network IR Remote Control
My remote wont operate my sony TV volume
Here you go. This will work with most all universal remote controls. If you don't have the code do the following:
Automatic Programming
With automatic programming, the remote control tests all the codes available on the Code List and assigns the correct code for the selected device. Although this method can be more time-consuming, it eliminates the need to look up codes and enter them manually.
1. Turn off the device with which you want to use the remote control.
2. Press and hold the corresponding button on the remote control
(TV, VCR, SAT, DVD, CAB or AUD) until POWER INDICATOR illuminates. It should take a couple of seconds for the light to remain solid. The remote control is in programming mode.
3. Press and release power button. The POWER INDICATOR flashes once and stays on indicating the unit is in Power Scan mode.
4. Press CHANNEL up or CHANNEL down repeatedly until the device turns on.
5. When the device turns on, press OK to store the code.
Note:
• To exit without storing the code, press BACK.
• T he unit will search for the next code or the previous code if you press
CHANNEL up or CHANNEL down after the device turns on. (go slow you need to press OK when the TV turns on) if you mess up turn TV off and start over.
6. Press any other button. If the device responds, the remote control has been programmed. If the device does not respond, repeat steps 2-5.
Fill free to ask me questions about anything..........................
Sep 25, 2009 | Sony RMT-D155A Remote Control
My remote control will not operate anymore have changed batteries still wont work
Note:
Sep 24, 2009 | Televison & Video
I tried to program my remote control to power my sharp tv and it will now turn the tv on and off but I cannot get any directv channels and the screen is fuzzy.
PUT THE DIRECTV REMOTE BACK INTO THE TV MODE TURN THE TV TO CHANNEL 4 OR 4 THEN PUT REMOTE ON DIRECTV TO CHANGE CHANNEL ENJOY
Aug 24, 2009 | Directv RC-64 Remote Control
Ihave jumbo Brookstone remote but changed batteries and l
Try this, just be patient as it might take a couple of minutes to program.
Note:
Aug 07, 2009 | Brookstone 538744 Remote Control
I need to reprogram my rcr317w remote contact with manual
Turn the tv on. Hook up your components, turn them on, go in to tv menu and auto program the stations. It will see that there is a signal on channel 3 and lock it in for you.
Jun 30, 2009 | Universal Remote Control DIRECTV Universal...
Cannot find manual. need to program menu
Hi and welcome to FixYa,
The user manual for a Brookstone 538744 is available here. It is in pdf form and would need Adobe Acrobat Reader to view the file.
Good luck and thank you for using FixYa.
Jun 25, 2009 | Brookstone 538744 Remote Control
Harmony 880 Logitech won't change channels
Was it working before?  Is it possible you selected the wrong brand of TV when programming the remote?  Do you use a cable box or satellite dish with your TV (in other words, do you change channels by changing the channel on the TV, or on the digital box connected to your TV)?
Mar 30, 2009 | Logitech Harmony 880 Universal Remote...
Sky remote wont control on/off , volume, or terrestrial channels
Press tv on the Sky remote
press and hold select and red until the led blinks twice
type in 0 0 6 0
press the power button, if the tv turns off then the press select and the remote should work all the tv functions.
If the tv does not turn off then press tv then the power button and keep doing this until the tv turns off, once it turns off press select and it should work.
If you have any problems let me know
Dazz
Feb 15, 2009 | Samsung LW20M21C 20 in. LCD Television
Systemlink3
  1. Make sure the device you are programming is turned off.
  2. Press and hold CODE SEARCH.
  3. Press and release TV, VCR, or CABLE corresponding to the device to be controlled. The indicator light will flash once to indicate the search is enabled.
  4. Release CODESEARCH.
  5. Press OFF/ON repeatedly until the device turns on.
  6. Press CHANNEL V (channel down) for verification. DO NOT press any other buttons at this time.
If the channel changes on the device, the code is valid. Press ENTER to complete the search.
If the channel does not change, turn off the device (without attempting to use the remote). Then continue search by repeating steps 5-6. When all codes have been searched, the indicator light will flash twice and the remote will return to the normal mode.
May 03, 2008 | RCA Universal Remote 3 Device Remote...
Televison & Video Logo
691 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
