Question about Maytag Neptune MDE5500AY Electric Dryer
Runs no heat
Dryer runs put will not heat or get hot
    President:
  • 1,776 Answers
This is caused by a blown thermal fuse or a faulty heating element. Both components can be tested using a multimeter or ohmmeter. Check for continuity. A lack of continuity indicates a faulty component. The thermal fuse is about one inch long and is located just inside the rear of the dryer and is usually attached to the exhaust duct. Hope this helped and best wishes.
Posted on Aug 08, 2009
    Problem Solver:
  • 10 Answers
Heat coil is probably your culperate
Posted on Jul 23, 2009
Kenmore elite electric dryer runs but then gets hot and then shuts off, replaced thermal fuse, dryer vent and tubing not plugged, dryer runs gets hot blows thermal fuse again.
DRYER OVERHEATING:
Heating Element
A defective heating element can make a dryer too hot. If the element partially shorts out, it can produce heat all the time, regardless of whether the dryer is calling for heat. Remove the heating element to inspect it. The coils should not be touching each other or anything else.
Other Causes and Conditions
Air Flow Problem
Dryers need good ventilation to work properly. If the vent is clogged it can make the dryer too hot. Clean all of the vent tubing thoroughly.
Cycling Thermostat
Although not common, a defective cycling thermostat can make the dryer too hot. The cycling thermostat is supposed to turn on and off the heat to maintain the proper temperature. If the thermostat is defective it may keep the heat on too long. The thermostat is not adjustable or repairable, it must be replaced.
Felt Seal
Most dryers have a felt seal at the front and rear of the drum to keep the heat inside the drum. If the felt seal is worn away or missing, the dryer may keep heating and make the dryer too hot. This is not common.
Blower Wheel
A defective blower wheel will not spin properly and will not vent the hot air, making the dryer too hot. Check to see if there is adequate airflow out of the dryer.
https://www.youtube.com/watch?v=3m5NZvY9V5Q
GOD IS still GOOD !!!!
Apr 28, 2015 | Kenmore Dryers
I have a Performa Maytag dryer it will sometimes turn on run a few seconds and then cut off and it will do this in consistently as I left it plugged in and left it on it was run and then cut off run and...
DRYER OVERHEATING:
Heating Element
Air Flow Problem
Cycling Thermostat
Felt Seal
Blower Wheel
Feb 20, 2015 | Maytag Dryers
Why is an Asko 7304 dryer running hot, so much so it melted fuse holder?
DRYER OVERHEATING:
Heating Element
Air Flow Problem
Cycling Thermostat
Felt Seal
Blower Wheel
Sep 16, 2014 | Asko Dryers
The timer will not advance and wont get hot
if the dryer is only getting 110v instead of 220v it will run but not heat check your power and breaker
Mar 23, 2014 | Crosley Replacement Clothes Dryer Thermal...
The dryer wont stay on the heating mode
how long does it run before quit heating . unhook dryer vent hose and try with vent discounected
Nov 29, 2013 | Haier GDZ5-1 Electric Dryer
Our kenmore eliite HE4 gas dryer keeps shutting off after a few minutes of running no mattter what heat setting we put it on. On air dry mode it works. Is this a high heat sensor problem? The unit is 4...
You didn't mention if the dryer is getting hot.
If is getting hot, then shutting off, I agree with you.
If it is NOT getting hot, I would suspect the IGNITER ASSY
Dec 13, 2009 | Kenmore Elite HE4 Electric Dryer
We have a Kenmore Gas dryer it runs but it doesnt get hot.. any ideas what it could be?
The heating element is most likely burned out. Try ordering a new heating element for your dryer and calling a repairman to put the new heating element in.
Jul 15, 2009 | Kenmore Dryers
Dryer got very hot when shut off,wouldn't heat up when running.
We took apart the dryer. the heating coil was broken in two. When the dryer was stopped it was not in off mode therefore the electricity was going through and the ends off the coil where it was broken was touching the metal and eating the dryer which made it hot to touch. We tested the 3 different fuses? the ohms were good. Ordered the part waiting to put it back together to be sure. Rule to remember even when dryer is stopped it should always be put in off mode.
Jun 02, 2009 | Frigidaire FSE748GF Dryer
Dryer not putting out warm to hot air. What is the issue?
Hope this info helps, ps don't forget to give me a rating thanks!!
For an electric dryer that runs but doesn’t heat, follow this repair roadmap:
Flip the circuit breaker off and then back on. Electric dryers run on a two-pole, 240v breaker. A common problem is for one of the legs to break which cuts the 240v that the elements need to heat up but it still supplies the 120v for the motor. The result is that the dryer runs but doesn’t heat.
If the breaker checks out, then it’s time to do some surgery. Unplug the dryer and open it up.
. Use your ohm meter to test the thermostats. All should show continuity.
Measure the resistance of the heating element with your ohm meter. Normal readings are in the neighborhood of 30 ohms.
In rare cases, the centrifugal switch in the motor can fail which breaks the power circuit for the heating elements. If this is the case, then the entire motor must be replaced since the centrifugal switch is built into the motor.
May 07, 2009 | Dryers
Maytag Neptune MDE5500AY Electric Dryer Logo
602 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
