Question about Nokia N95 Cellular Phone
Nokia N95 charging problem
Nokia N95 charging interface on board is short so, how come it will open?
  • mjayan450 Mar 01, 2010
    n95 charging porblem
I have a nokia n95 8gb ony white screen then off i try to flash my n95 8gb but error loading cmt.....pls help me?
Just do this tricks...but you should know that the flash file version should Rm -320 = 35.0.001 v7(EURo.MEA,APAC,LTA),Rm-321 =31.1.004 v2 (EDGE),Rm-421 = 35.2.002 v6 (AM)
If the CMT file doesnotmatch " error cmt will be shown" So, try to select the right file and follow this
You can choose the file from here .Open http://www.blue-nokia.com/index02.html and in the left side of the window there you will notice BB5 SUPPORT click there and you will again see various models of Nokia Mobile Handsets.Then, make a selection to 5220.Again there you'll see different download links.choose the last one by clicking to the download link you will lead a new windows.I think this is enough.......you can when you get there.Thanks
First download and install Pheonix from this link. Nokia Phoenix Service Software 2011 - Download secondly Download flash file from this link http://adf.ly/2WHa2 and install it to C / program files/pheonix.. after finished this installation open pheonix . Inside the interface at the> top left File" click there and choose "open file" and then select the approprait Product type i.e "which is written on the back panel inside the battery of every Nokia(Type RM-000).After doing this again at the left top count from "File"1..2..3..the 4th one is "Flashing" press there, when you click there you'll see three sub-menus, just select the "Firmware Update" again you'll see another interface. Look at the product code there should be blank and put your "mouse tool" at the straight end from the "Product Code" there is a Button and choose the code which is written in the back side of your phone. e.g CODE:0000000.if the same code does not found just take one which is higher. After this you can see "Dead phone USB flashing" click that box. Now this is the last stage... Connect your phone with the USB to your PC and let the driver install ...wait for a moment.(If your phone working).Lastly after just finished (In case your phone is Dead, unable to switch on in normal mode start from here) Connect the phone to pc without powering...insert good battery and Click the "Referbish" button after this, a message will prompt you "press power botton" etc. insert charger or press it and wait until the phone will Restart automatically in normal mode 10-15 minutes. If you cannot understand just leave a Comment /Click here1
. thanks for visiting fixya. Good luck.
Sep 05, 2011 | Nokia N95 Cellular Phone
My nokia n95 8gb camera is not ready
format ur phone
Enter the code: *#7370# and press Yes to confirm initialization.
Jan 27, 2010 | Nokia N95 Cellular Phone
Hi,my nokia n95 wont hold charge i have a new battery and new software,do you know what the problem could be,also when it charges it doenst cut out when it is charging it just keeps charging,thank you
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Dear user,
Such issue may appear when Nokia charger adapter CA-146C is used with incompatible charger to charge Nokia N97. Currently compatible chargers for N97 with CA-146C are Nokia Travel Charger AC-4 and Nokia Compact Travel Charger AC-5.
Spangley, just plug it into your PC. If your battery needs charging, it will charge slowly simply while being connected to your computer. Nothing else to do!
Goodluck :)
Dec 11, 2009 | Nokia N95 Cellular Phone
Battery won't charge after replacing flex cable n95 8gb
Re-check the connections between the flex cable and board. Your problem may be a cause of a shorted pins... Good Luck... ^_^
Mobile press navigation key from it self and open message without i press anykey
virus or bad contact.( short circuit.) try to remove the cap of n95. and try to remove the navigation key, to see what apends after.
if you don´t want that, contact nokia assistence.
hope i have helped
May 20, 2009 | Nokia N95 Cellular Phone
N95 made by nokia cell phone's imei has been changed
you can tell if its a clone, by is it touch screen? has it gps has it nokia maps? has it got NOKLA instead of NOKIA
Jul 29, 2008 | Nokia N95 Cellular Phone
Nokia n95 8g (chinese)
nokia n95 8gb is not a nokia is a fake.a real nokia it doesen't even work to charge the batery with usb.and nokia pc suite will never recognize this kind of phones.if u want to connect to pc suite buy a real nokia
Jun 04, 2008 | Nokia N95 Cellular Phone
Fail to charge
main-board could be faulty , or you could try and change the battery or reflash the firmware and see if that helps it.
Mar 17, 2008 | Nokia N95 Cellular Phone
Wont charge!
1. The charger may be damaged To check if the charger is damaged, use another functioning charger. The charger cable has a tiny wire that easily breaks when used without proper care. If the phone still does not charge with a functioning charger, try next step. 2. The battery may be damaged Change the battery and try charging again. If the phone still does not charge with a functioning battery, try next step. 3. The battery terminals may not connect properly with the battery connectors Check the battery connector to see if the battery and the connector connects well. The phone will indicate charging only when there?s enough power supply from the battery. click here Solution Procedure: If problem is confirmed, adjust the battery connector using tweezers to reach the battery terminal and establish connection. Or try next step. 4. The charging pin may be damaged or does not connect well with the board's interface Check the charging pins to see if they are well connected to the mother board. Sometimes the charging pins wear out or loosens from its connection with the mother board. Solution Procedure: Check if the pin is bent. Straighten the pin using tweezers. Make sure the board interface is also clean otherwise, you will need to clean it by rubbing its surface using an eraser or brushing it with a board solution. Or replace with a new charging pin. Make sure the charging pin touches with the board interface to establish connection. The CCONT IC for DCT3 or UEM for DCT4 or the "K" resister for non-Nokia models may be damaged If the phone still does not charge after adjustments are made, the problem is CCONT IC for DCT3 or UEM for DCT4 or ?K? resister for non-Nokia models.
Aug 19, 2007 | Nokia 6300 Cellular Phone
Nokia N95 Cellular Phone Logo
321 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
