Question about Yamaha Full-Size Keyboard
Yamaha DGX-620 blank screen or screen with vertical lines
Apparently I'm not the only person with this problem. It's gotten progressively worse. Basically, I have nothing on the screen except for a few tightly-packed vertical lines. Has anyone had any success fixing this problem? It's a 2 1/2 year old item that I bought at Costco. My guess is that there isn't any warranty or 'take it back' priveleges at this late date. Thanks for any input/advice.
    Novelist:
  • 123 Answers
I`ve had a similar problem with a Korg that I use at the club and on gigs, I don`t know whether Yamaha use a similar method or not but when I stripped mine down, I found that the glass LCD panel is connected to the PCB via a ribbon cable which gets sandwiched between the PCB and the LCD panel when screwed up, It`s not soldered or hard wired to the PCB, It was producing intermittent connections between the uPC and the display panel where parts of letters and symbols were missing. When I removed the panel, I found that it was oxidized so I used some switch cleaner which doesn`t leave a residue (Don`t use lubricant or WD40 as this will destroy the LCD panel by penetrating between the layers of Liquid Crystal rendering it useless) and gently cleaned the contacts on both the LCD and PCB panels (Don`t spray the panel or this could penetrate) by spraying a small amount onto a tissue then gently wiping this into the nooks and crannies with a nail brush then wiping off the excess with another tissue. I`ve had no problems since, (touch wood). Please use extreme caution when working with these panels as they are dedicated to your keyboard and therefore extremely expensive to replace. If yours has an extension lead from the LCD panel to a plug on the PCB, it should be a lot easier to clean this one cable where it enters the plug on the PCB than mine was, but still use extreme care. Best of luck, Ian
Posted on Jul 23, 2009
    Filmmaker:
    Uploaded 5 video answers.
    Scholar:
  • Yamaha Expert
  • 151 Answers
This is a know fault - Yamaha give a 2 year warranty from new so worth checking your purchase date.
The solution is to replace the whole screen assembly
The seal fails causing intermittent connection ( see photo )
Yamaha DGX-620 blank screen or screen with vertica - image1-hkvzf2teq5seftdrfl2ij2t0-4-0_1.jpg
Posted on Jul 11, 2018
I have a yamaha DGX-620 but the screen is blue with some lines Please tell me what to do !!!!
Could be bad connection of the LCD glass to it's socket.
You need a specialist to look at that, very delicate.
If not----
Change the screen, probably the whole board with driver chip. Check with Yamaha.
Nov 24, 2017 | Yamaha Music
Does it have an internal battery?
HQRP AC Adapter / Power Supply for Yamaha PSR ... - Fixya
www.fixya.com/search/...hqrp_ac_adapter_power_supply_yamaha.../60...
HQRP AC Adapter / Power Supply for Yamaha PSR-280 / PSR280 / PSR-290 / PSR290 Keyboards Replacement plus HQRP Coaster, 600 related issues. ... is there an internal battery to protect memory and if so, do i need to replace it? yes there ...HQRP AC Adapter / Power Supply for Yamaha DGX-620 / DGX620 / DGX- ...
www.fixya.com/...hqrp_ac_adapter_power_supply_yamaha_psr/adapter
HQRP AC Adapter / Power Supply for Yamaha PSR-280 / PSR280 / PSR-290 / PSR290 Keyboards Replacement plus HQRP Coaster, adapter related ... need a new one, you could try to get a replacement from casio or try to get an ... It MAY appear to operate on DC BUT it can't generate the +/- voltages internally for sound .
Musical Instruments - Keyboard Accessories on Pinterest ...
https://www.pinterest.com/.../musical-instruments-keyboard-accessories/
HQRP AC Adapter / Power Supply compatible with Fulltone CATALYST / CHORALFLANGE Guitar Effects pedals Replacement plus HQRP Coaster by HQRP. $7.91. ... The MS-90 is a column monitor stand that features three internal channels - .... Yamaha SK88 Survival Kit for 88-Key YPG Series Keyboards by Yamaha.
Dec 25, 2015 | HQRP AC Adapter / Power Supply for Yamaha...
Blue LCD screen
I had the exact problem, mine was a YPG 535 brand new in box I put everything together with stand and FC4 pedal. When i got ready to play just a blue screen and none of the red lights came on and no sound, I notice when i was messing with the on and standby button hopeing it would work the speakers would make a popping noise I personly thought it was a manufacturing defect.....i'm sending it back to have it replace. I never had problems with yamaha products but seems like more and more defects are happing with newer portable grand series!
Feb 24, 2014 | Yamaha DGX 640 Keyboard Arranger
Yamaha dgx 620
Which connector are you looking for?
If mains adaptor input then try here
http://www.beckettsmusic.co.uk/shop/scripts/prodView.asp?idproduct=17018
Jan 21, 2014 | Music
I require a complete set of fixing bolts for a DGX-620 Yamaha electric keyboard which have been mislaid following dismantling. Can you advise how I might obtain a replacement set please.
If you contact Yamaha keyboards and tell them the model of your keyboard they can tell you exactly what part numbers they are and tell you how to order them. Here is the link: yamaha24X7.com.
Aug 20, 2010 | Music
Right half of lcd screen on yamaha DGX-620 screen is blank
I have the same Problem since yesterday my granddoughter hit the keyboard too heavy. I have opened it (many screws...) but could not find any obvious reason. Nothing like a loose connector.
Oct 31, 2009 | Yamaha Full-Size Keyboard
No sound when piano keys are pushed on my Yamaha dgx-620
I'm sorry but it sounds like you will have to have it repaired professionally.
Apr 20, 2009 | Yamaha Music
Yamaha YPG625 screen shows only vertical lines
I brought the keyboard into a local service technician. He told me that he had to remove about 50 screws but the solution was simple. He unplugged and reconnected the ribbon connector. It apparently was not making good contact.
Oct 02, 2008 | Yamaha Full-Size Keyboard
Yamaha Full-Size Keyboard Logo
6,360 people viewed this question
Top Yamaha Music Experts
Mike
Are you a Yamaha Music Expert? Answer questions, earn points and help others
