posted by mysticgohan on Nov 21, 2007
Hello. I've tried to install my external hard drive in 2 different computers. Once I plug the USB cable to the PCs an icon appears on the task bar saying the Simpletech drive is being installed. When this process ends it says the drive is ready to use. However, if I try to access the drive through MyComputer, it is not even visible. If I reboot the PC it will freeze when shutting down and also when starting windows if the drive is turned on and connected to the PC. However, it is visible in the Device Manager of the control panel. It shows no problems in its Properties when accessed through the Device Manager.
In a few words, although the drive is shown in the Device Manager, it isn't visible or accessible through My Computer. I tried with 2 different computers. One with XP SP2 and the other one with Vista.
I don't know what to do. Shouldn't it be almost as simple as using a pendrive?
Comment by mysticgohan, posted on Nov 21, 2007
Hello, AGKS and thanks for your reply. There's no intallation disk. I've followed the installation instructions. Windows has the driver needed, and I was able to verify that by accessing Device Manager. It shows a "Device is working properly" status for the hard drive. However, it shows it as Disk 0 which is weird because that's the C; drive number.
Also, when I open ''My Computer ---> 'Manage", I can only see the C: hard drive as Disk 0 and the CD Rom. The simpletech external drive isn't visible.
Comment by mysticgohan, posted on Jun 25, 2008
YURB and VREMOREZ got it right for me. The problem is an unplugged connector inside the case. It's the biggest connector (long, horizontally placed and with a lot of pins). Once you plug it to the disk it'll work perfectly. Openning it was my last resort because I didn't want to lose the warranty. However, I cannot claim it because I live outside the US (where I bought it), but the solution was soooo simple! If you've got the same problem I had, this is the answer.
19 Other Users Have The Same Problem
Comment by Guest, posted on Nov 19, 2008
I have the 1TB model and it no longer connects to my laptop. It makes a noise but no icon shows up and I even have gone into My Computer>Management and tried locating it the other way but it does not even show up that way.
Comment by alokkrishna, posted on Aug 29, 2008
hard drive is recognized by the computer, i'm reluctant to open the hard drive. do i connect to power? any other suggestion.
thank U
alok
alokk13@yahoo.com
Comment by yeshelalama, posted on Aug 08, 2008
My computer no longer recognizes my Simpletech 250 GB device when I plug it in. What do I do?
Comment by FlickChick, posted on Aug 03, 2008
I had the same problem. Mysticgohan had the right solution. On his suggestion I did the following
- opened the casing by removing the two recessed screws the bottom.
- Pry the casing open. I needed an extra set of hand for this. It doesn't open all the way, but rather sort of hinges open.
- The front of the skinny green electronic board is the USB connector, power connector, etc. On the back of the green electronic board, there is a long brown connector with gold contacts that plugs directly into the black hard drive.
- If unseated, it will not be completely perpendicular to the hard drive.
- Line up the contacts and plug back into the actual hard drive. You will have to press pretty hard.
- Make sure you push it down for the whole length of the connector.
- Before closing up the casing, plug in the power and the USB cable and taa daa, it should immediately recognize your drive.
Comment by soubriquet20, posted on Jul 26, 2008
Yurb, thanks a lot. Had the same issue, then opened the case, and the part you described really was disconnected from the USB. Works perfectly now!
Best Solution
posted on Dec 29, 2007
Rank:
Apprentice
Rating: 100%, 6 votes
Had same problems as above. For me it is a defective casing that is the only thing that holds the actual hard drive IDE connection to the convert to USB board. The connection was loose. After I removed the case and plugged the connection board directly into the hard drive, the problems went away and now it is better than new. An external case can be had for $20.
Ironically the selling point of this product is the problem. Hope this helps someone and lets the company know if it is a problem on their end. Yurb from Carolina
Rating Locked! (?) mysticgohan has rated this solution as FixYa!
Solution #2
posted on Jun 07, 2008
Rank:
Apprentice
Rating: 100%, 5 votes
i took my 250gb simpletech hardrive apart discconected the wires from the harddrive, re-hooked them, and it worked, hope this helps anyone who couldnt find another way
Was this solution helpful? Show your Appreciation by rating it:
Solution #3
posted on Jun 05, 2008
Rank:
Guide
Rating: 95%, 11 votes
I bought the Simpletech Signature Mini 250GB last week and had these same issues. I wrote to the company's tech support and the solutions works. It boils down to you having to create a drive letter & partition for this. It took a little time to format, but it's all good now. I agree we shouldn't have such a headache for such a simple piece of hardware, though. I will cut/paste the info below. Once it was done, I was able to go to My Computer and see it listed as Drive H (which was what I selected).
PROBLEM: I have followed directions re: plugging device in, still cannot see device in MY COMPUTER. I have also tried plugging both USB's into computer to no avail. Even tried using it on my laptop, still not showing. My desktop is XP & loaptop is Vista. When I go to remove the dirve, it DOES show as Fujitsu, but I cannot acces the drive or locate it elsewhere. I really want to like this, but will have to return it if this issue is not resolvable.
SOLUTION: You might need to initialize the drive.
Right click on “My Computer” or “Computer” on Vista.
Select “Manage”
On the next screen select “Disk Management”
In the lower middle section you should be able to find your drive.
It will show up as Disk 1 or Disk 2….depending on how many drives you have in your computer.
If you click on the area that says Disk # you should get and option to “initialize drive”.
Also to the right it should show the allocation information for the drive. If it says “unallocated” then the drive needs to be partitioned.
Right click on the white box next to the drive listing.
Select the option “New Partition”
This will bring up the partition wizard and you will need to step through this process.
Select a primary partition.
On the next screen accept the maximum size it will provide.
On the next screen you assign a drive letter.
On the next screen you will do the format and accept the default settings.
The formatting will start and will be busy until it is complete.
You can monitor this from the disk management window.
Regards,
SimpleTech Technical Support
Hope it helps!
Solution #4
posted on Feb 28, 2008
Rank:
Apprentice
Rating: 89%, 4 votes
same problem on simple tech 250 gb ext hd. normally very reliable so i have 4 of these, (lots of foreign movie dls) after working with this off and on for months as a last attempt before writing off all this data as lost i took apart this drive and one just like it and swapped the interface cards. (what i call it) not the actual IDE cable connector card but the one that it plugs into. simple 4 torx head screws. put it all back together and hooked up, presto, worked perfectly. i right away transfered all 200 gb of data to another hd just in case. this was last ditch but it worked. maybe a design flaw in this model but i would still buy another simple tech storage device
Solution #5
posted on Feb 11, 2008
Rank:
Apprentice
Rating: 81%, 7 votes
One thing to remember is the some of the Simple drives requires the USB mini to conect to the drive and the TWO USB connects to be plugin to the computer.
Solution #6
Rank:
Apprentice
Rating: 70%, 3 votes
You'd want to install the 'Installation and Driver disk' first before plug in the USB cable, normally.
Rating Locked! (?) mysticgohan has rated this solution as Thanks for Trying
Solution #7
posted on Nov 14, 2008
Rank:
Apprentice
Rating: 0%, 0 votes
I had the same problem when I bought a new laptop with Vista. I contacted SimpleTech but got no response to my issue.
I searched the internet and found some answers, but some were to take apart something and I did not think that was necessary. I also read one about security, but it gave information if the drive was on the network.
I thought the security thing sounded reasonable, since Vista had a lot of security enhancements so I put the hard drive on my old system. From Windows Explorer or My Computer I right mouse clicked on the drive and went to Properties. I then went to the Sharing Tab of properties and clicked the box to share the drive and clicked the box to allow all users to change files on the drive. I applied the changes, unplugged the drive from the old machine and plugged it into the USB of the Vista machine and presto chango it was recognized.
Hope this helps someone!
Solution #8
posted on Aug 09, 2008
Rank:
Apprentice
Rating: 0%, 0 votes
I tried to plug the thing into the USB hub and it wouldn't work. As soon as I plugged it into the USB port on the right side of my computer (I have a thinkpad), the SimpleTech Drive started right up.
JJ
Solution #9
posted on Aug 06, 2008
Guest
Rank:
Apprentice
Rating: 0%, 0 votes
thanks soo much i didnt even have this problem though. My problem was that i would power up and hav only the red light but never the blue one and would not show up. i tried what u did anyway and reset the thing inside and it works now even though i lost my casing but thats aprice im willing to pay instead of losing my thousands of music!!!!! :D :D:D:D
Solution #10
Rank:
Apprentice
Rating: 0%, 0 votes
Yurb, thanks for the solution you've postedon 6/25 - we had the same issue, followed your advice on taking the case apart, and making sure that the USB was connected firmly to the disk. It worked!
Solution #11
posted on Jun 22, 2008
Rank:
Apprentice
Rating: 0%, 0 votes
above solution doesn't work, because the drive will not show up. If it did for you, your lucky.
THE SOLUTION: first off, simpletech drives are meant for macs, work has to be done to make it PC compatible. Tjhe soltuion I employed is I connected it to a Unix computer running ubuntu (ALTERNATIVELY, find a friend with a Mac and connect the drive). You'll see it will work, then from the non-PC computer reformat the drive to NTFS. Should work.
www.uprisetv.com
Comment by UPRISEtv, posted on Jun 22, 2008
work.
www.uprisetv.com
19 Other Users Have The Same Problem - Continued
Comment by Guest, posted on Jun 29, 2008
Dear, Sweet, MYSTICGOHAN - you were sooooo right! I have so many precious pictures stored on my drive, and I could access nothing!
My computer froze every time I turned on my "F:" drive, the device manager said that it was working properly. I had searched for new drivers both on-and off-line. I had tried every USB port on my computer and different cables. After reading your solution I decided to void my warranty and take the chance. It WAS simple and it DID work. Thank you, thank you, thank you!
Now if you'll excuse me, I have to back up my pictures to CD's.
Comment by sonny168, posted on Jun 29, 2008
i have the 320gb external hard drive for about 6 months i was able to back up all my files.and now i hook it back up and i can't see it on my computer.i turn it on and off rebbot my pc still not see it in my computer.when i unplug and plug in the usb pop say found new hardware.also my hard drive say disc 0 when i go
to disc management in my computer.
Comment by Guest, posted on Jun 17, 2008
Same thing, not recognized under disk management at all so that solution doesn't work
Comment by tonyfromc, posted on Jun 16, 2008
same probelm but with mine in a disk management i see my external with black line over it ,while C: drive is in blue line ..i do see in device manager but not in my computer
Comment by Errbear, posted on Jun 12, 2008
Same problem, at first my computer at least recognized something connected, but wouldn't open. Now it won't even recognize that something is plugged in. Only thing I haven't tried yet is taking it apart. Will try that next.
Comment by indibush, posted on Jun 02, 2008
I have the 320GB model, and have the same problem. I have two laptops, XP and Vista, and no icon appears in either one, although the divice is recognized by Windows, since it allows me to "safely remove" it, and it is listed in the properties section of devices.
Comment by Guest, posted on Apr 23, 2008
the same problem
Comment by maris12345, posted on Apr 03, 2008
i have exact same problem
Comment by Guest, posted on Mar 26, 2008
I purchased your simple tech 250 external hard drive and my windows xp cannot detcet the drive. Please either send me a link to be able to download the drivers so that this will work If there is a cd please let me know . i would prefer your emailing me
jonessv@yahoo.com with your response
I have tried several times to have windows recognize it and have also gone to your website to see if the drivers are there but to no avail
sandra jones
Comment by Guest, posted on Mar 20, 2008
my buddy had the same problem, when he took it back to the store, they said the driver was fryied. he had to return it and get something else
Comment by Guest, posted on Mar 19, 2008
Hola. I've tried to install my external hard drive in 2 different computers. He intentado instalar mi disco duro externo en 2 diferentes ordenadores. Once I plug the USB cable to the PCs an icon appears on the task bar saying the Simpletech drive is being installed. Una vez que conecte el cable USB a la PC aparece un icono en la barra de tareas diciendo Simpletech la unidad se está instalando. When this process ends it says the drive is ready to use. Cuando este proceso termina se dice la unidad está lista para su uso. However, if I try to access the drive through MyComputer, it is not even visible. Sin embargo, si intento acceder a la unidad a través de MyComputer, no es aún visible. If I reboot the PC it will freeze when shutting down and also when starting windows if the drive is turned on and connected to the PC. Si he de reiniciar el PC cuando se congele el cierre y también al iniciar Windows, si la unidad está encendida y conectada al PC. However, it is visible in the Device Manager of the control panel. Sin embargo, es visible en el Administrador de dispositivos del panel de control. It shows no problems in its Properties when accessed through the Device Manager. No muestra problemas en sus propiedades cuando se accede a través del Administrador de dispositivos.
In a few words, although the drive is shown in the Device Manager, it isn't visible or accessible through My Computer. En pocas palabras, aunque la unidad se muestra en el Administrador de dispositivos, no es visible o accesible a través de Mi PC. I tried with 2 different computers. He probado con 2 diferentes ordenadores. One with XP SP2 and the other. Uno con XP SP2 .
Comment by Guest, posted on Mar 05, 2008
I, lost the cd rom to install the driver for my simpletech 250GB external hard drive. Can I down load it from the internet, and how.
Comment by Guest, posted on Feb 27, 2008
Simple Tech 250GB USB2.0 External Hard Drive designed by Pininfanina
Comment by Guest, posted on Feb 11, 2008
I'm trying to install my external simple tech drive and ii has been impossible.
it is supposed to be auto- installed , but whwn I try to open the 'my Computer"the drive does not appear.
what can I do?
Marcia Vital
mmmvital@sti.com.br
