Question about Dishwashers
Dishwasher not cleaning
Is there a ''Home Remedy'' to run through the dishwasher to clean it?
    Brigadier General:
  • 4,088 Answers
Try running it once with a box of baking soda and no dishes. Is the water HOT?
Posted on Jul 23, 2009
How to fix a dishwasher that will not drain!
good to know the cleaning procedure worked for you. You can also get good results by using Finish dishwasher cleaning kit available from supermarket and running dishwasher empty with it once in 3-4 months. Keeps dishwasher clean and free of draining problems.
Apr 14, 2014 | Dishwashers
Tip
Hard water Calcium white powder build up in dishwasher
Calcium and magnesium is present in a great number of homes today regardless of hardness or softness of the water. Water containing dissolved carbonates of calcium and magnesium can lower the effectiveness of the detergents you use and leave deposits on the dishware and tub of the dishwasher. When these deposits dry they become what some call lime scale.
To remove these deposits there are a number of cleaners on the market today. I will list them in the order of my preference. You can find them near the dishwasher detergents. If you use them read the instructions on the label, but basically you can run a cycle with no dishes and the cleaner. Some of the cleaners like Lemi-Shine can be used with a full load of dishware after you clean the tub. This helps keep the tub clean and deposits off the dishes. If you want a home remedy that seems to work pretty good, put a cereal size bowl upright in the lower rack (no other dishes in the dishwasher) fill the bowl with vinegar and run a normal cycle. The vinegar will wash out and clean some of the deposits away. If residue is still around run a second cycle of the vinegar wash.
- Lemi-Shine
- Finish Dishwasher Cleaner
- Glisten
- Glass Magic
Here are some links to other dishwasher tips I have put together.
Blinking Clean Light
Poor washing on the top rack or noisy
General Dishwasher Cleaning
on Apr 30, 2010 | Dishwashers
Dishes not coming out clean
Hello
There are some things you can try, however, if your Maytag dishwasher is not getting your dishes as clean as you would like. Maytag recommends several processes for fixing this issue with your dishwasher.
Do not run your Maytag dishwasher while hot water is being used in other parts of your home, such as washing clothes or showering. Hot water is needed for your Maytag dishwasher to properly clean dishes.
Run water in the sink in your kitchen until it gets very hot. Then, turn on your Maytag dishwasher. This will ensure that the water cleaning your dishes is the hottest possible temperature.
Clean your Maytag dishwasher to improve the cleaning results for dishes. Run your dishwasher on a short wash cycle and wait for it to fill up with water. Stop the cycle and add about 1/3 of a cup of rust remover to the dishwasher and finish the cycle. Run your Maytag dishwasher through one normal cycle with regular detergent to finish the cleaning process.
Check your detergent. Old detergent or those that have been exposed to moisture can be clumpy. This detergent will not clean your dishes as well when loaded into your Maytag dishwasher. Purchase fresh detergent.
Use extra detergent when washing dishes that have a lot of built-up grease or food particles. The extra amount of detergent is needed to get your dishes clean. Choose a long cleaning cycle to clean these dishes.
Fill your Maytag dishwasher properly. Dishes should not be stacked on top of each other or excessively crammed into your dishwasher. This will keep the dishwasher from adequately cleaning all areas of your dishes and from rinsing them thoroughly.
Sep 13, 2011 | Maytag Dishwashers
My Miele dishwasher is about 16 months old. Initially it was awesome. Now it doesn't get anything truly clean on any rack. Every item has scum and traces of food or drink left on it. I've cleaned the...
Hi bjw.... clean the dishwasher by putting 2 cups of vinegar into an empty dishwasher and running the longest and hottest cycle.
Repeat this washing as needed but generally at least once a month. Joe
Thanks for choosing Fixya!
Feb 27, 2011 | Miele G880 Dishwasher
Smelly dishwasher
there is a cleaning solution you can buy from sears or home depot called dishwasher magic it cleans the dishwasher. just open set it inside the dishwasher and let it run, that should fix that problem.
Dec 17, 2010 | Bosch 24 in. SGS45E02 / SGS45E08 Exxcel...
Calcium (white) buildup on wiring in bottom of my Whirlpool dishwasher...how can I remove this?
There a few good products to clean this. Purchase one of the following, you can find them at the store near the dishwasher detergents. I am listing in order of my preference. Follow the instructions on the package, but basically run a cycle with no dishes and the cleaner. A home remedy that works but not as well is to put a bowl of vinegar upright in the lower rack. Run through a normal cycle and the vinegar will wash out and clean the calcium away. You may need to do this a couple times.
- Lemi Shine
- Finish dishwasher cleaner
- Glisten
- Glass Magic
Apr 30, 2010 | Whirlpool 24 in. DU915PWP Built-in...
Glasses are not getting clean and sparkling
HI. Usually this will be the result of heavy calcium build up inside the unit. This will produce the film on the glassware and silverware, as well. To remedy this issue, i would advise to purchase a concentrated dishwasher cleaner. One of the best on the market that i use on my costumers units is call Dishwasher magic. There are others out there, but this one actually works well. Use this every month, if you do not have a water softener device attached to your home plumbing.
I would also advise to make sure that the fine particle filter is clear of all debris. Debris in this area will obstruct the recirculating factors of the unit, thus, producing poor cleaning and horrible drying results.
Apr 23, 2010 | Whirlpool 24 in. GU980SCG Built-in...
I have grit on my dishes after the wash cycle completes, jet dry seems to be working? Dishwasher is draining.
use only cascade complete cleaner, clean unit remove basket motor cover chopper cover clean and vac out trash washer all screens increase water temp. to 130 degrees if no children in home if children in home not over 125 degrees temp. monthly run dishwasher cleaner product through waser cost around 10 $ at lowes
Feb 05, 2010 | KitchenAid 24 in. KUDS01FLBL Built-in...
Bad smell
smell is not the fault of the dishwasher but your waste disposal unit - they stink!
it may be awkward, but arrange your drain so that there is a water barrier. better still. install a standpipe for the drain, again with a water barrier
Jul 09, 2008 | Bosch SHY56A02 / SHY56A06 Built-in...
Floor cleaner in jet dry resevoir
If you run the dishwasher it will produce suds coming out the door.You can take the door off and clean it all out. One remedy is to add a gallon of vinegar to react with the soap and prevent foaming, another solution is to add cooking oil.
May 26, 2007 | GE GSD5650D Dishwasher
Dishwashers Logo
60 people viewed this question
Top Dishwashers Experts
Owen Barnes
