Question about Plumbing
I installed a new Mark II .3 hp sump pump to replace one that is old but still works. The float doesn't automaticlly turn the pump on. The float works if I hold it completely upright. The flot goes up and simply floats on its side 4 inches below water level. Please help me.
  • 523 Answers
It would appear this float requires a steeper angle to operate. Is it possible for you to mount the float cord lower or shorten it? By doing so it will close at a earlier time starting the pump. THis may be done with the use of some electrical (zip) ties.
I hope this may have assited you,
Tom
Posted on Sep 25, 2009
Why wont the pump turn on
If the pump is plugged in through a float switch the switch may be bad- try plugging the pump in by just the plug for the pump itself if possible -if that works then you need a new float switch.
Jun 10, 2014 | Utilitech 1/3-HP Cast-Iron 95 GPM Sewage...
Tip
Fixing a Zoeller M53 Sump Pump that won't turn on. Turns on by tapping or...
Just wanted to share my fix story. A couple of years ago I had a problem with my zoeller sump pump to turning on but it would if I ever so lightly tapped it or the discharge pipe. Naturally I suspected the switch and replaced it with the same results. I ended up zip tying a piece of foam to the float and bingo! This worked great for awhile until the foam loosened and got stuck. So back to the drawing board. I noticed on a parts list that zoeller recommends changing the float arm when replacing the switch. Put in a new float arm and it works great! No foam needed. I never thought to replace it in the first place because the old one moved fine but when compared to the new arm the new one is much smoother. I was able to remove the old arm with channel lock pliers and the new piece is press fit with some loctite #609 that came with it. Hope this helps!
on Apr 04, 2012 | Zoeller M53 Mighty Mate Iron Body, Poly...
Sump pump doesn't shut off
The floats could be binding on the pump or may have developed leaks so they don't float. Another possibility is that the switch mechanism is defective
Apr 01, 2013 | Flotec 1 3 HP Submersible Sump Pump -...
Fixed! Zoeller M53 won't turn on. Will turn on with a slight tap.
I had the same problem of pump not turning on unless I tapped the pipe to create a vibration. I took the float off and cleaned the grime / buildup. The buildup changed the buoyancy of the float (made it heavier) such that it did not float high enough to trigger the switch. Once cleaned, the float floats much higher above the water line and triggers the switch.
My pump, #506158, will not shut off. what should I do? Is there anyway to fix the float if that is the cause of the problem? I read the suggestion you made to the previous question like this but I wa...
Hi vincent w wa...
Time to buy a new pump...there is no repair parts available for that sump pump sorry.
You could try replacing the faulty switch with a floating ball switch something like on the webpage below if you have room..just be sure to make a water proof seal on the wire connections.
Please take time to rate me
Float Switch;
http://www.grainger.com/Grainger/GENERAL-ELECTRIC-Float-Switch-4ZZF3?Pid=search
Sep 12, 2011 | Little Giant Submersible Sump Pump 2760...
I have a Zoeller Water Ridd'r II Model 48 Sump pump. The pump comes on okay, but will nit shutoff. The float is not impededd, it's just laying on the bottom of the sump. Is this a defective...
If I undrestand your description, when the resevoir is empty, the float lays on the bottom of the resevoir but, the pump doesn't shut off, after water is pumped out? You have to look at this as opposite of a toilet tank filling with water. In a toilet, the water rises and the foat turn the water flow off. In a sump the water will rise, and the float will turnthe pump on until the resevoir is empty, then it will open the system and turn off the pump. If the float doesn't rise, the resevoir will overflow and the pump won't come on at all. If the float rises and the pump comes on but, the float does "not" drop, the pump will continue to run after the resevoir is empty.
http://www.zoellerpumps.com/ProductByCategory.aspx?CategoryID=3
This is Zoellers link. I don't see your pump but they do have a support link. If the float rises and falls with the height of the water, turns pump on, then drops "all the way" and pump doesn't turn off, the switch is bad not the float. Make sure there is nothing in the way of the float dropping to it's full down position.
Jul 03, 2011 | Home
Sump pump float
The switch has failed. Replace it with a new mercury type rated to handle the pump.
Dec 29, 2009 | Water ACE SUBMERSIBLE SUMP PUMP 1/3 HP
Damaged plug on end of float switch
if it is just a small length of cord you can just attach any cord to it from any old appliance, if you feel that it needs to be waterproofed go to home depot and by one for wet areas
Sep 18, 2009 | Water ACE SUBMERSIBLE SUMP PUMP 1/3 HP
Same issue, one of two pumps
I'm assuming the switch in Question is a Float-switch that is positioned in-line of the Power-supply to the Pump. The hinge that activates the switch inside the Float could be faulty. You can check it by connecting a dif-
ferent device to the plug, activate the switch
(Float upright) and deactivate (Float horizontal)
Mounting the switch with zip ties is a good
idea.The Float should be dangeling about 3"
above the Pumphead, thus keeping it submersed. Hope it helps.
Jul 14, 2009 | Genius Wayne Submersible Sump Pump With ...
My 1/2 HP WaterAce sump (R5S-1) runs but will not shut off
I found a replacement switch which is placed in series with the pump power plug. However when I removed the original switch and plunged the new switch I discovered that the pump motor spins but it does not pump. I installed a new pump.
Thanks!
Jun 19, 2009 | Water ACE SUBMERSIBLE SUMP PUMP 1/3 HP
Plumbing Logo
50 people viewed this question
Top Plumbing Experts
Paul Carew
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
