Question about Bell Lands Phones
Can't receive calls on landline due to water issue
I had a minor flood in my basement which got to a phone jack near the floor. Wasn't able to call out without a lot of static initially but that has rectified however I still cannot receive incoming calls. When the line connects there is quite a bit of static. It rings once and then nothing until the call is dropped approximately 11 seconds later. I was hoping when everything dried it would be ok? Can anyone offer some advice? I have a feeling this will be a costly venture.
Yes, the wiring might be fine, but the terminations and jacks that got wet will surely need to be replaced.
If you redo the affected terminals/jacks, it might be fine, but nothing is 100%
Posted on Jul 23, 2009
I'm receiving a "no line" message and cannot receive or make calls what can I do?
Replace the jumper cable between the wall jack and the phone. You've probably installed a "roll over" cable by accident.
Nov 13, 2014 | AT&T DECT6.0 1-Handset 2-Line Landline...
How do you disconnect the communication between the alarm panel and the receiver base. Do I need a alarm security technician or the phone landline company? Any other solutions? As I am paying about 5 phone...
Most alarm panels connect to the phone line near the "demarcation" where it comes into the house. You should see an RJ-31X phone jack there with an 8 wire modular plug. Unplug it and that should stop the dial out.
Oct 04, 2017 | Cars & Trucks
GE Gas Dryer DDG8280SAMWW runs, but does not heat. We had a minor basement flood (thank you, Hurricane Irene!) with about 4" or so around the dryer. We do not hear the "whoosh" that would...
Sorry to hear about the flooded basement ..here in Virginia i only had a couple trees down and power go off for 12 hrs but no flooded basement.
Their is no way to clean/clear the igniter persay..gotta check and see what shorted out due to the flood...this tip i wrote explains what to check on gas dryers when they dont heat. http://www.fixya.com/support/r10293028-gas_dryer_not_heating
Good luck i hope this help you to figure out why your dryer isnt heating,
GENE
Aug 31, 2011 | GE Dryers
We had a storm and now the phone lines in the house to not give a dial tone. We did have minor flooding in the basement. I checked the outside box and there is a dial tone there. Also our doorbell is...
Check to see if you "minor" flooding watered a jack or you have a cable lying in the water or got wet. Examine the pins on each jack and cord. Or, as an alternative if you can unplug all but the main phone from the jacks (assuming there are modular jacks for each extension) then plug them in one at a time until the problem comes back, you may be able to pinpoint the bad cable run.
Carl
Aug 21, 2011 | Lands Phones
Water leaks past the water pump filter gasket reseating the filter does not stop the leaking lg tromm Front Loading Washer
I regularly clean my filter of slime and debris (after not even realizing this needed to be done and having my pump give out of me). TWICE I have awoken to a flooded basement due to leaks in the filter area:
The first time, the plastic stopper was not in the small rubber drain hose properly and had popped off.
The second time, I had cleaned the gasket, inserted it tightly like I always do, and awoke to another flood! I thought perhaps the rubber gasket on the filter was on wrong, but it was fine. I inserted it tightly several times and water still poured out! It turns out there was a small stone lodged in the thread of the receiving end of the filter causing there to be a bad seal. Lesson learned. Another $2000.00 worth of flooring ruined.
May 15, 2010 | LG WM-1832C Front Load Washer
Dryer wet due to flooded basement
if it was p[lugged in you might have to replace the circuit board,, they can conduit electricity from one circuit to the other in water
Apr 30, 2009 | Kenmore 62602 Electric Dryer
Lands Phones Logo
183 people viewed this question
Top Bell Lands Phones Experts
RobertFonner
RobertFonner
k24674
guyvstewart
Are you a Bell Lands Phone Expert? Answer questions, earn points and help others
