Washing Machines Logo
Posted on Jul 23, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
LG Dryer not Drying clothes
I've been reading online several problems with LG dryers not drying and mine does not consistently dry since I purchased it in 2006. I've called repair people, Sears (where I purchased it) and checked duct work. Timer seems to be stuck and sensor not working so clothes are still wet. I have no clue what to do as I do not want to purchase another dryer when the brand new one never worked. Did anyone find a resolution to this?
Anonymous
Level 2:
  • Expert 153 Answers
  • Posted on Jul 23, 2009
Anonymous
Expert
Level 2:
Answers
153
Questions
0
Helped
41573
Points
362
Well there must be some problem with the motor engine you should get it checked.
LG WM3988HWA excessive water fill to dryer condenser. Soaked clothes 50% of the time. other times, no problem.
Hi there. In some cases if your dryer vent tube is bunched up behind the dryer and not extended properly or if vent tube is running up the wall to be vented to the outside it will cause water to build up in dryer vent tube. Make sure your flexible dryer tubing is not full of water or clogged with lint and make sure if you have an extended piece that goes to outside ventilation that that is not clogged with lint as well. Hope this helps you with your drying issues.
Cathy
Simpson autosensing 512 dryer
The Simpson Autosensing 512 Dryer is a type of clothes dryer manufactured by the Australian company, Simpson. It is a front-loading dryer that uses sensors to automatically detect when clothes are dry and stop the drying cycle, helping to prevent over-drying and save energy.
Some of the key features of the Simpson Autosensing 512 Dryer include:
  1. Autosensing technology: This dryer uses sensors to monitor the moisture levels in your clothes and adjust the drying time accordingly. This helps to prevent over-drying and damage to your clothes, as well as saving energy.
  2. Large capacity: The Simpson Autosensing 512 Dryer has a 5kg capacity, making it suitable for households with smaller laundry loads.
  3. Multiple drying programs: This dryer has several different drying programs to choose from, including cotton, delicates, and mixed loads. There is also a cool-down phase at the end of each cycle to help prevent wrinkling.
  4. Easy to use: The control panel on the Simpson Autosensing 512 Dryer is straightforward and easy to use, with simple buttons and LED indicators.
  5. Reverse tumbling: The dryer drum rotates in both directions, helping to prevent clothes from tangling and reducing creasing.
Overall, the Simpson Autosensing 512 Dryer is a reliable and efficient dryer that is suitable for smaller households. Its autosensing technology and range of drying programs make it easy to use and help to protect your clothes from over-drying.
Hi there, I've got a Whirlpool dryer that doesn't dry clothes anymore. The clothes get really hot, but they stay damp, never properly dry after several cycles and then smell mouldy. Oddly,...
If your dryer is not drying like it once did or if you just have nottaken the time to give yourself a clean dryer in a long time then youneed to do that. At least once a year the dryer cleaning should takeplace. Lint build up in the dryer duct is one of the main causesfor your dryer to fail.
Here is the rest of this tip about DryerMaintenance
heatman101
Sep 05, 2011 • Dryers
2answers
Not enough heat
You may need to adjust the air flow on your dryer vent.
When an LG dryer is functioning normally---the time required to dry laundry is determined by the *Sensor* located on the drum side of the lint filter housing and by the main control board.
When laundry is near dry--any Time Remaining on the control panel that is *not* needed will be eliminated---except for the last 6 minutes.
The final 6 minutes of any LG automatic cycle is for cooling down the laundry before the dryer ends the cycle.
If a dryer *counts down* to the last 6 minutes but the laundry is still not dry--the computer will allow the dryer to run until the laundry has dried or defaults (not drying within the additional time allowed).
Dryer vents that are longer than 8 feet with more than (2) 90 degree turns--can affect drying performance.
Setting the DRY LEVEL selector to *Very Dry* will solve most dryability issues. In homes with abnormally long vents--even the longer run time in the *Very Dry* setting is usually not sufficient to dry laundry loads.
Reducing the length of the vent or starting a second cycle becomes necessary to fully dry the clothing.
If a second cycle was started---only the amount of time that is needed to dry laundry will be used before dropping to 6 minutes and then the cycle will end with dry laundry.
LG gas dryers are more sensitive to venting length and air flow resistance. The gas burner can cause a rapid increase in temperature compared to an electric burner.
Rapid temperature rise in a gas dryer leads to premature burner shutdown (longer time required to dry laundry).
The gradual temperature increase of an electric element is more "forgiving" in homes where the dryer venting is less than ideal.
Problem:
The dryer has an auto dry feature which never fully dries the clothes so we wind up manually setting the dry time to an hour
Solution:
LG gas dryers are VERY temperamental in long vent set-ups. If fabric softener sheets are used in the dryer--clean the two stainless steel strips of metal on the lint filter housing with a SCOTCHBRITE PAD--scrub back & forth several times to remove the waxy residue from the fabric softener sheets. Most,if not all manufacturers do *not* recommend using sheets in dryers that have a moisture sensor (electrodes).
However--using a SCOTCHBRITE pad keeps the wax off those sensors which can be seen if looking *into* the dryer drum and at the lint filter housing.
If only *liquid* fabric softener is used in the washer--clean the dryer sensors once a month. Liquid softener also contains wax which can slowly accumulate on the dryer sensors from the laundry washed in the washer.
LG DRYER SERVICE MANUAL
LG PARTS
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Prolem drying clothes
I just contacted Samsung Tech Support for my wash/dryer combo WD-J1255C.
The reply.."it is not a full dryer ...and it is not sold as a full drier.. and don't expect it to be completely dry". I queried why it is advertised as a dryer and got the same reply.
Its a great washer but why did I pay extra for the dryer combo?
1helpful
2answers
Drying timer on auto dry
I called LG...they said to unplug the dryer for 5 min. to reset the timer ...this solved the problem.
They also said not to use dryer sheets during the sensor dry cycle as the coating on the dryer sheets causes the sensor to malfunction as it can't read the humidity level in the dryer.
Dec 28, 2008 • LG Dryers
Dryer LG 6DTD3120
You should change it back to regular gas the problem is in pressure reg gas come to your home at much greater pressure then propane that's why it takes longer to dry the other thing is to keep your lint trap clean because it can affect drying once in while blow out lint hose as well
Jul 26, 2008 • Dryers
LG DLEo332W electric dryer not drying full time
you have to change out the timer motor...
http://www.partselect.com/repair.aspx?appliance=dryer&part=dryer-wont-heat
Jun 08, 2008 • Dryers
Top LG Washing Machines Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
